#1 2022-12-03 20:50:40
Devarch
[SOLVED] How to use ntfs-3g instead of kernel module?
How to find which ntfs driver is in use and how to use fuse instead of paragon?
#2 2022-12-03 21:48:05
sgage
Re: [SOLVED] How to use ntfs-3g instead of kernel module?
blkid will tell you what fs driver is being used.
Devuan has always used the fuse driver (ntfs-3g) by default, as far as I can tell.
#3 2022-12-03 22:34:30
Devarch
I did not find it with blkid, but I found that  ls -altr /sbin/mount.ntfs gives
/sbin/mount.ntfs -> mount.ntfs-3g
So everything is OK.
#4 2022-12-03 23:39:34
sgage
I might have meant 'cat /etc/mtab' instead of blkid - thought blkid gave the info. But glad it's all good...
