#1 2022-11-26 00:30:16
AhmadRaniri
lximage-qt: missing a library though it's already installed.
lximage-qt :
- Version :  1.1.0-2.
- Package from unstable.
- missing library : libfm-qt.so.11.
[ahmad ~]$ ldd /usr/bin/lximage-qt | grep found
        libfm-qt.so.11 => not found
[ahmad ~]$
- package that possible has  *libfm-qt.so.11* : libfm-qt11.
[ahmad ~]$ apt-file find libfm-qt.so.11
libfm-qt11: /usr/lib/x86_64-linux-gnu/libfm-qt.so.11
libfm-qt11: /usr/lib/x86_64-linux-gnu/libfm-qt.so.11.0.0
[ahmad ~]$
- Check if libfm-qt11 is installed :
[ahmad ~]$ apt search libfm-qt11
Sorting... Done
Full Text Search... Done
libfm-qt11/unstable,now 1.2.0-1 amd64 [installed]
  file management support for pcmanfm-qt
[ahmad ~]$
- Check libfm-qt11 package list files :
[ahmad ~]$ apt-file list libfm-qt11
libfm-qt11: /usr/share/doc/libfm-qt11/AUTHORS
libfm-qt11: /usr/share/doc/libfm-qt11/README.md
libfm-qt11: /usr/share/doc/libfm-qt11/changelog.Debian.gz
libfm-qt11: /usr/share/doc/libfm-qt11/changelog.gz
libfm-qt11: /usr/share/doc/libfm-qt11/copyright
libfm-qt11: /usr/share/libfm-qt/archivers.list
libfm-qt11: /usr/share/libfm-qt/terminals.list
libfm-qt11: /usr/share/mime/packages/libfm-qt-mimetypes.xml
[ahmad ~]$
I already installed the package but lximage-qt still complain about missing that one library.
#2 2022-11-26 00:32:06
AhmadRaniri
Re: lximage-qt: missing a library though it's already installed.
Surprisingly I have *libfm-qt.so.12* instead.
[ahmad ~]$ ls /usr/lib/x86_64-linux-gnu/libfm-qt.so.12
[ahmad ~]$
#3 2022-11-26 00:37:39
AhmadRaniri
Linking libfm-qt.so.12 & libfm-qt.so.12.0.0 to libfm-qt.so.11 & libfm-qt.so.11.0.0 make lximage-qt run.
#4 2022-11-26 10:54:03
Don't do that.
Soname bumps are a "feature" of the development branches. If you don't know how to handle them correctly then you probably shouldn't be using those branches.
Relevant bug report: https://bugs.debian.org/cgi-bin/bugrepo … ug=1024687
Should be fixed soon so revert that "fix", downgrade the relevant packages and wait.
