#1 2022-11-02 23:00:20
dcolburn
[SOLVED] Devuan Raid 1 Install Steps
I read this thread a couple of times, hoping to extract a clear pathway to what I need, but it's just too case-specific ...
https://dev1galaxy.org/viewtopic.php?id=4795
I have a Dell OptiPlex 7050 SFF with two 400GB server-rated SSD's.
I'd like to set them up as Raid 1 to use in a light duty online server application.
I looked here https://www.devuan.org/os/documentation … all-devuan and don't see a Raid 1 Server install process.
I read about mdadm here ... https://linoxide.com/raid-mirror-disks-in-linux/
Thanks
#2 2022-11-02 23:31:42
Re: [SOLVED] Devuan Raid 1 Install Steps
It all happens in the partitioning step:
  1. first you declare partitions for use in raid setup
  2. then you set up the raid device linking it to its partitions
  3. and then you partition that into the filesystem partitions you want
#3 2022-11-02 23:40:42
If you want the full disks as raid members, then you skip to step 2 directly, and create a RAID device...
#4 2022-11-03 00:01:15
dcolburn
Any idea why the Download link isn't working, please?
I'm getting a "You've gone where no one has gone before" error.
#5 2022-11-03 00:31:52
which link?
#6 2022-11-03 00:51:51
dcolburn
https://www.devuan.org/get-devuan/
I can send you a screen shot ...
#7 2022-11-03 00:59:25
I don't really need screenshot;
that link, https://www.devuan.org/get-devuan seems fine to me;
are you saying that that link doesn't work for you, or
that there is a link on that page that doesn't work for you?
If the latter, which link?
EDIT: hmm you have a / at the end of it, and having that seems to not bring the right page.
EDIT2: where did you find that  bogus one, with a / at the very end?
#8 2022-11-03 01:14:29
dcolburn
I added the "/" because without it the Download link doesn't work at all - it just twitches the display then returns to the same page.
I'm using the Ghostery Dawn (Firefox shell, I believe) browser.
There's no indication of a pop-up block or anything.
#9 2022-11-03 01:16:32
maybe you can teach your browser something by adding  .html to the end instead of /
#10 2022-11-03 01:19:24
dcolburn
#11 2022-11-03 01:31:48
Well, https://www.devuan.org/get-devuan.html is the correct one which also references the actual html file; the abbreviation link (without .html) also works, but via server re-writes.
Obviously they don't work for you, which is slightly more difficult to debug. It'd be either your browser wanting to be helpful and intelligent, or something "environmental" relating to your Internet access.
Perhaps you can install "surf" and try with that?
#12 2022-11-03 01:43:58
dcolburn
OK, well, rather than fight with the button ... the other synapse fired and I realized that I could just go directly to the mirrors ... duh.
I'll burn "devuan_chimaera_4.0.2_amd64_desktop-live.iso" to a USB stick, make sure Devuan can see the Dell OptiPlex 7050 hardware (VOID could not) - then proceed to the install.
I'll probably be back here ... tomorrow ... with more questions.
Thanks for your patience!
#13 2022-11-03 02:28:33
dcolburn
Well ... Devuan is having the same problem as VOID - the wired connection cycles up and down.
I don't see an app in the menu to look at the hardware devices, so I just used "lspci".
I'm told that the probable reason for the instability is that the Intel I219-LM isn't recognized.
Any suggested solution, please? (I'm guessing I need a stable wired connection for the server-purposed install.)
Devuan also failed to recognize the USB nic (MX Linux handles it, VOID did not).
Need to sleep so will look here in the morning.
NOTE: I started a new thread for the LAN problem and the Intel I219-LM.
#14 2022-11-03 17:19:48
Doing a few tests I found the certificate seems to be expired. Which Konqueror doesn't mind but wget objects to:
$ wget 'https://www.devuan.org/get-devuan/' --no-check-certificate
--2022-11-03 17:12:15--  https://www.devuan.org/get-devuan/
Resolving www.devuan.org (www.devuan.org)... 54.36.142.179, 2001:41d0:8:732b::3624:8eb3
Connecting to www.devuan.org (www.devuan.org)|54.36.142.179|:443... connected.
WARNING: The certificate of ‘www.devuan.org’ is not trusted.
WARNING: The certificate of ‘www.devuan.org’ has expired.
HTTP request sent, awaiting response... 404 Not Found
2022-11-03 17:12:17 ERROR 404: Not Found.
$ wget 'https://www.devuan.org/get-devuan' --no-check-certificate
--2022-11-03 17:12:25--  https://www.devuan.org/get-devuan
HTTP request sent, awaiting response... 200 OK
Length: 25326 (25K) [text/html]
Saving to: ‘get-devuan’
get-devuan                              100%[============================================================================>]  24.73K  --.-KB/s    in 0.003s
2022-11-03 17:12:25 (7.03 MB/s) - ‘get-devuan’ saved [25326/25326]
$ wget 'https://www.devuan.org/get-devuan.html' --no-check-certificate
--2022-11-03 17:13:25--  https://www.devuan.org/get-devuan.html
Saving to: ‘get-devuan.html’
get-devuan.html                         100%[============================================================================>]  24.73K  --.-KB/s    in 0.003s
2022-11-03 17:13:25 (7.02 MB/s) - ‘get-devuan.html’ saved [25326/25326]
@dcolburn, what browser are you using? And does it check for expired certificates?
#15 2022-11-03 19:00:21
dcolburn
I'm using the Ghostery Dawn browser. In Settings I found this
Certificates
Query OCSP responder servers to confirm the current validity of certificates
#16 2022-11-03 20:46:41
Note that the certificate was Issued On Friday, October 21, 2022 at 10:55:06 AM and it Expires On Thursday, January 19, 2023 at 10:55:05 AM, so something strange is happening here.
Please do the following to download the certificate complained about
echo -n | openssl s_client -connect www.devuan.org:443 -servername www.devuan.org \
    | openssl x509 > /tmp/wwwdevuanorg.cert
and then upload that to pastebin.debian.org for us to review.
#17 2022-11-03 21:10:31
dcolburn
depth=2 C = US, O = Internet Security Research Group, CN = ISRG Root X1
verify return:1
depth=1 C = US, O = Let's Encrypt, CN = R3
verify return:1
depth=0 CN = www.devuan.org
verify return:1
DONE
pastebin.debian.org doesn't work either.
Is that URL "http" or "https"?
#18 2022-11-03 21:50:58
sorry; I wrote it while doing something else, it's of course https://paste.debian.net
#19 2022-11-03 22:38:37
dcolburn
Any special settings I should select there?
Does it need to have the same Member name as here - for you to identify it?
#20 2022-11-03 23:02:00
No, nothing special or strange.
You post the link for the paste here, and then anyone can follow it  while it's valid.
#21 2022-11-03 23:43:11
dcolburn
OK, cool ... if I've used this before it's been years ...
paste.debian.net/1259462
#22 2022-11-04 02:10:58
right. so pasting that int openssl x509 -text gives me (among other things):
        Serial Number:
            04:63:9c:cc:d4:86:e8:46:e0:95:f9:c7:31:93:fb:36:87:06
        Validity
            Not Before: Oct 20 23:55:06 2022 GMT
            Not After : Jan 18 23:55:05 2023 GMT
which looks all fine and dandy.
Is your clock ok?
#23 2022-11-04 02:15:54
dcolburn
Clock is correct.
Headed to bed but will check back here in the morning.
Thanks for looking at this.
#24 2022-11-04 03:21:06
Is anyone (still) getting those warnings from
wget --no-check-certificate https://www.devuan.org/get-devuan
The certificate was updated 2 weeks ago, and is valid some 8 or so weeks more. So there shouldn't be or have been any warnings.
#25 2022-11-04 17:12:05
I'm still getting them. On two different systems (one Devuan ascii, one openSUSE Leap 42.3).
I also tried echo -n | openssl s_client -connect www.devuan.org:443 -servername www.devuan.org     | openssl x509 > wwwdevuanorg.cert, that gets different screen output:
On devuan:
$ echo -n | openssl s_client -connect www.devuan.org:443 -servername www.devuan.org \
verify return:1
verify return:1
verify return:1
DONE
On openSUSE:
depth=3 O = Digital Signature Trust Co., CN = DST Root CA X3
verify error:num=10:certificate has expired
notAfter=Sep 30 14:01:15 2021 GMT
DONE
chris@vega:~/primo/progs> ll wwwdevuanorg.cert*
-rw-r--r-- 1 chris users 2025 Nov  4 16:57 wwwdevuanorg.cert
Though the certificates downloaded were identical on both systems.
I doubt it's cached, the openSUSE box isn't used for web browsing so has probably never downloaded the certificate before I first tried yesterday.
But on a web server I can log on to via ssh (I do some of the admin on it) wget is happy:
--2022-11-04 17:04:43--  https://www.devuan.org/get-devuan
get-devuan                              100%[============================================================================>]  24.73K  --.-KB/s    in 0.005s
2022-11-04 17:04:44 (4.50 MB/s) - ‘get-devuan’ saved [25326/25326]
And:
$ echo -n | openssl s_client -connect www.devuan.org:443 -servername www.devuan.org     | openssl x509 > wwwdevuanorg.cert
verify return:1
verify return:1
verify return:1
DONE
And the cert appears to be the same too.
I'm now wondering if my ISP is caching something. Have you any ideas?
