#1 2022-10-03 00:42:45
sgage
apt-mark
There used to be a utility called apt-mark that easily let you mark packages that are marked for auto-removal as manually installed. It is not in the repos as far as I can tell (chimaera). A highly useful tool if you want to remove some undesirable package that depends on many other key packages that you don't want removed. I used it a lot back in the day, but it seems to have disappeared. Though if you 'man apt' and search for 'mark' it is mentioned.
It is an invaluable tool if you're trying to lean down your system, and I'd dearly love to have it back.. What happened to it, and where can I find it?
TIA
#2 2022-10-03 04:03:17
Re: apt-mark
Huh? apt-mark is included with apt, it's never been a separate package AFAIK.
cat /etc/devuan_version
chimaera
dpkg -S `which apt-mark`
apt: /usr/bin/apt-mark
#3 2022-10-03 11:22:37
sgage
Re: apt-mark
chimaera
Thanks for the reply. When I typed 'apt-mark' yesterday, I got 'command not found'. Today it's working. Not sure what happened, but thanks for making me look again...
#4 2022-10-03 15:01:16
Re: apt-mark
Note that apt install $package will change the status of $package from automatic to explicitly installed.
Also note that aptitude can do everything apt-mark can do; it even accepts the same options. I don't have a De{vu,bi}an system handy to check but I think apt unmarkauto $package might also work.
#5 2022-10-03 16:28:49
Re: apt-mark
From experience the most likely explanation is that you misspelt it yesterday. I've learnt to take a hard look at what I typed if I get that error.
Have you still got the screen output? Or does your command history show you what you really typed?
If it's not that could your PATH have been altered to not include /usr/bin?
#6 2022-10-03 23:03:40
sgage
Re: apt-mark
I will check the command history - I suspect a misspelling. My aging eyes are not what they used to be...
