#1 2022-08-28 07:47:35
Gregors
[SOLVED] Error: Package lsb is not installed ...?!
Hi there,
I have trouble installing my printer (Epson ET-M1140):
Searching epson support I found an
epson-inkjet-printer-escpr2
package that has „unmet dependencies“:
 epson-inkjet-printer-escpr2 : Depends: lsb (>= 3.2) which is a virtual package and is not provided by any available package
The following actions will resolve these dependencies:
     Remove the following packages:
1)     epson-inkjet-printer-escpr2 [1.1.49-1lsb3.2 (now)]
Accept this solution? [Y/n/q/?] n
When I try to compile that from source make complains about several „undefined references (e.g. „undefined reference to `ppdOpenFile'“)
So, what can I do to make my printer print?
TIA
Gregor
#2 2022-08-28 09:02:27
Re: [SOLVED] Error: Package lsb is not installed ...?!
You could use equivs to create a fake lsb package to satisfy the dependency. No idea if that would actually work though. I've never owned a printer. Thank "$DEITY".
EDIT: full quote to prevent globbing.
#3 2022-08-28 09:17:34
Gregors
You could use equivs to create a fake lsb ...
Thanks! I'll try that.
Gregor
#4 2022-08-28 18:37:24
Grumpy
I'm not sure if your printer is supported by the package but have you tried
# apt install printer-driver-escpr
If your printer is supported then you can add the printer to CUPS by pointing the web browser of your choice to http://localhost:631/ and selecting the add printer option
#5 2022-08-29 16:11:51
kapqa
#6 2022-08-31 14:58:36
Gregors
Thanks a lot!
It prove the printer drivers were not installed. Silly me ... as usual ...
Gregor
