#1 2022-01-21 13:12:04
devlan
[SOLVED] screen is not locked when suspend is activated by closing the lid
Hello,
if the laptop lid is closed, then the laptop is put into standby mode, but the screen is not locked. I.e. after opening the lid, the screen is not locked.
But when the standby button is pressed, the screen is locked and the laptop goes into standby mode.
Could this be a bug in elogind, which does the job of monitoring lid closure?
~$ cat /etc/devuan_version
chimaera
~$ xfconf-query -c xfce4-power-manager -l -v
/xfce4-power-manager/brightness-switch                  0
/xfce4-power-manager/brightness-switch-restore-on-exit  1
/xfce4-power-manager/critical-power-action              3
/xfce4-power-manager/inactivity-on-battery              46
/xfce4-power-manager/inactivity-sleep-mode-on-battery   1
/xfce4-power-manager/lid-action-on-ac                   1
/xfce4-power-manager/lid-action-on-battery              1
/xfce4-power-manager/lock-screen-suspend-hibernate      true
/xfce4-power-manager/logind-handle-lid-switch           true
/xfce4-power-manager/power-button-action                3
/xfce4-power-manager/show-tray-icon                     false
~$ xfconf-query -c xfce4-session -l -v
/general/FailsafeSessionName          Failsafe
/general/LockCommand
/general/PromptOnLogout               false
/general/SessionName                  Default
/sessions/Failsafe/Client0_Command    <<UNSUPPORTED>>
/sessions/Failsafe/Client0_PerScreen  false
/sessions/Failsafe/Client0_Priority   15
/sessions/Failsafe/Client1_Command    <<UNSUPPORTED>>
/sessions/Failsafe/Client1_PerScreen  false
/sessions/Failsafe/Client1_Priority   20
/sessions/Failsafe/Client2_Command    <<UNSUPPORTED>>
/sessions/Failsafe/Client2_PerScreen  false
/sessions/Failsafe/Client2_Priority   25
/sessions/Failsafe/Client3_Command    <<UNSUPPORTED>>
/sessions/Failsafe/Client3_PerScreen  false
/sessions/Failsafe/Client3_Priority   30
/sessions/Failsafe/Client4_Command    <<UNSUPPORTED>>
/sessions/Failsafe/Client4_PerScreen  false
/sessions/Failsafe/Client4_Priority   35
/sessions/Failsafe/Count              5
/sessions/Failsafe/IsFailsafe         true
/shutdown/LockScreen                  true
Thank you!
Kind regards
Klaus
#2 2022-01-21 14:59:42
devlan
Re: [SOLVED] screen is not locked when suspend is activated by closing the lid
Maybe the developers can provide a way for pre/post hooks for the devuan version of elogind?
#3 2022-01-22 11:50:26
See https://www.linuxquestions.org/question … ost6214885 — is that setting enabled for the screensaver?
#4 2022-01-22 15:00:29
devlan
Hello,
thanks for your reply!
the package xfce4-screensaver as mentioned in the post is not present on my system and cannot be installed. The existing version of xfce4 uses xscreensaver as a screen lock.
Kind regards,
Klaus
#5 2022-01-22 15:57:10
I have xscreensaver disabled and let xfce4-power-manager handle suspend and lock when lid is closed.
#6 2022-01-22 16:11:44
devlan
when i uninstall xscreensaver, the screen is not locked at all. Could it be that you have installed another package that locks the screen?
#7 2022-01-22 16:21:40
xscreensaver is installed and set to run in the desktop's startup applications. It is disabled in the Screensaver settings.
xfce4-power-manager is set to suspend on lid closing. It is not set to lock the screen.
Closing lid puts computer into suspend and locks the screen. When I raise the lid, I get the xscreensaver login screen.
This is in Chimaera.
#8 2022-01-22 18:38:12
devlan
Hello and thank you for the settings.
I think it is a different problem. If I set the settings as you suggested, then the screen does not respond to input after the lid is opened again.
I see the screen with all programs open, but I can't make any input. I notice that I can only move the mouse in a very small rectangular area in the middle of the screen.
I then noticed that the area is the same size as the xscreensaver window, which is the unlock screen. Only that it is not visible. If I then "blindly" enter my password, the screen gets unlocked.
Who has an idea what else I could check, why the screen does not go black and the xscreensaver unlock screen is not visible?
Many thanks!
Klaus
#9 2022-01-22 22:18:41
I don't know if this is helpful:
$ dpkg -l |grep input
ii  libinput-bin                         1.16.4-3                               amd64        input device management and event handling library - udev quirks
ii  libinput10:amd64                     1.16.4-3                               amd64        input device management and event handling library - shared library
ii  libxcb-xinput0:amd64                 1.14-3                                 amd64        X C Binding, xinput extension
ii  xinput                               1.6.3-1                                amd64        Runtime configuration and test of XInput devices
ii  xserver-xorg-input-libinput          0.30.0-1                               amd64        X.Org X server -- libinput input driver
$ dpkg -l |grep evdev
ii  libevdev2:amd64                      1.11.0+dfsg-1                          amd64        wrapper library for evdev devices
#10 2022-01-23 11:17:40
devlan
I was able to solve my problem with the following setting:
lspci|grep VGA
00:02.0 VGA compatible controller: Intel Corporation UHD Graphics 620 (rev 07)
Created /etc/X11/xorg.conf.d/20-intel.conf
Section "Device"
  Identifier  "Intel Graphics"
  Driver      "intel"
  Option      "TearFree" "true"
EndSection
Thanks a lot for your support!
Kind regards
Klaus
#11 2022-01-23 13:39:04
The DDX driver shouldn't affect the screensaver locking hmm
And note that the recommendation is to remove xserver-xorg-video-intel and use X's builtin modesetting driver instead. The Intel version is known to be buggy, especially for modern chips.
Use Wayland to manage tearing. X is useless for that.
#12 2022-01-23 15:25:26
devlan
Yes, you are right. It only turned out during testing that it has nothing to do with the function of xscreensaver, but with a display problem.
If I disable /etc/X11/xorg.conf.d/20-intel.conf, then the screen is not blacked out and the xscreensaver locking screen is not visible. See my post #8
Thanks for the tips on the display driver. But if I uninstall xserver-xorg-video-intel and modesetting_drv.so is loaded, then I have the same problem again. Maybe there is also an option needed for the modesetting driver?
