Pages: 1
Hi @all,
If your try to use ifupdown2 in Chimaera, you will discover that it will not work.
In the actual version 3.0.0-1 there is no /etc/init.d/networking init script.
I just borrowed the initscript from beowulf, works fine.
The ifupdown package provides /etc/init.d/networking, if that helps.
Perhaps consider filing a bug report against the Debian ifupdown2 package to add support for non-systemd init systems. The maintainer isn't compelled to act but they might see reason...
EDIT: there is an init script provided by the upstream source:
https://github.com/CumulusNetworks/ifup … networking
So it looks like this might be a packaging mistake.
Pages: 1
