#1 2021-12-27 15:43:48
[SOLVED] Devuan Beowulf: can't get rid of AppArmor
I am in the process of building a (light as possible) Beowulf installation on a separate disk in my box.
root@devuan3:~# uname -a
Linux devuan3 4.19.0-18-amd64 #1 SMP Debian 4.19.208-1 (2021-09-29) x86_64 GNU/Linux
root@devuan3:~#
One of the things I do not want running is AppArmor.
I added the bit security=none to the kernel command line and purged it but I still get this in dmesg:
root@devuan3:~# dmesg | grep -i apparmor
[    0.328030] AppArmor: AppArmor initialized
[    0.569017] AppArmor: AppArmor Filesystem Enabled
[    1.257404] AppArmor: AppArmor sha1 policy hashing enabled
root@devuan3:~#
So I looked to see what was going on:
root@devuan3:~# apt list | grep -i installed | grep -i apparmor
libapparmor1/oldstable,now 2.13.2-10 amd64 [installed,automatic]
root@devuan3:~#
AppArmor is not installed but it left behind its crap, which seems difficult to get rid of:
root@devuan3:~# apt purge libapparmor1
Building dependency tree
 dconf-service : Depends: default-dbus-session-bus but it is not installable or
                          dbus-session-bus
E: Error, pkgProblemResolver::Resolve generated breaks, this may be caused by held packages.
root@devuan3:~#
So what is causing this?
root@devuan3:~# aptitude why libapparmor1
i   dbus Depends libapparmor1 (>= 2.8.94)
root@devuan3:~#
dbus is installed and up to date:
root@devuan3:~# apt install dbus
dbus is already the newest version (1.12.20-0+deb10u1+devuan1).
root@devuan3:~#
And dbus-session-bus can't be installed:
root@devuan3:~# apt install dbus-session-bus
Note, selecting 'dbus-x11' instead of 'dbus-session-bus'
dbus-x11 is already the newest version (1.12.20-0+deb10u1+devuan1).
root@devuan3:~#
I have a faint memory of having come across this before but I cannot find it in the forum.
Any ideas?
Thanks in advance,
#2 2021-12-27 16:59:01
Re: [SOLVED] Devuan Beowulf: can't get rid of AppArmor
https://wiki.debian.org/AppArmor/HowToU … e_AppArmor
EDIT: the AppArmor lines in dmesg are from the kernel module.
#3 2021-12-27 17:32:27
Thanks for the link, I'll have a look later on.
My main system is this one and as you can see it is Devuan Beowulf with a backported kernel:
groucho@devuan:~$ uname -a
Linux devuan 5.10.0-0.bpo.3-amd64 #1 SMP Debian 5.10.13-1~bpo10+1 (2021-02-11) x86_64 GNU/Linux
groucho@devuan:~$
AppArmor is not installed but like in the OP, libapparmor1 is there:
groucho@devuan:~$ apt list | grep installed | grep -i apparmor
libapparmor1/oldstable,now 2.13.2-10 amd64 [installed]
groucho@devuan:~$
But with this kernel it does not make itself known via dmesg like with the Beowulf kernel.
groucho@devuan:~$ sudo dmesg | grep -i apparmor
groucho@devuan:~$
Makes me wonder why ...
Thanks for your input.
#4 2021-12-27 17:49:19
... faint memory of having come across this before ...
Found it.
It was me bitching about AppArmor earlier this year:
https://dev1galaxy.org/viewtopic.php?id=4329
Now I have to re-check and see if it is really true that security=none disables both tomoyo and AppArmor, making apparmor=0 unneccesary.
#5 2021-12-27 21:29:58
dbus-x11 Provides: dbus-session-bus
#6 2021-12-27 21:53:39
$ apt info dbus-session-bus
Package: dbus-session-bus
State: not a real package (virtual)
N: Can't select candidate version from package dbus-session-bus as it has no candidate
N: Can't select versions from package 'dbus-session-bus' as it is purely virtual
N: No packages found
See also https://www.debian.org/doc/debian-polic … irtual-pkg
#7 2021-12-28 13:07:37
Why is there a dbus dependency on libapparmor1?
I don't understand what is going on.
ascii w/backported kernel installation:
groucho@devuan:~$ aptitude why libapparmor1
i   slim Depends dbus
i A dbus Depends libapparmor1 (>= 2.8.94)
groucho@devuan:~$
ascii VM:
groucho@dev-pihole:~$ sudo aptitude why libapparmor1
i   dbus-x11 Depends dbus
i A dbus     Depends libapparmor1 (>= 2.8.95)
chimaera VM:
root@chimaera:~# aptitude why libapparmor1
root@chimaera:~#
apparmor is not installed in any of these three Devuan machines.
Yet, from ascii on, there seems to be a constant apparmor infiltration.
This is the apparmor stuff I have in my main installation:
groucho@devuan:~$
groucho@devuan:~$
groucho@devuan:~$ locate apparmor
/etc/apparmor.d
/etc/apparmor.d/local
/etc/apparmor.d/usr.sbin.tcpdump
/etc/apparmor.d/local/usr.sbin.tcpdump
/lib/x86_64-linux-gnu/libapparmor.so.1
/lib/x86_64-linux-gnu/libapparmor.so.1.6.0
/usr/share/doc/libapparmor1
/usr/share/doc/libapparmor1/changelog.Debian.gz
/usr/share/doc/libapparmor1/copyright
/usr/share/lintian/overrides/libapparmor1
/usr/src/linux-headers-5.10.0-0.bpo.3-amd64/include/config/default/security/apparmor.h
/usr/src/linux-headers-5.10.0-0.bpo.3-amd64/include/config/security/apparmor
/usr/src/linux-headers-5.10.0-0.bpo.3-amd64/include/config/security/apparmor.h
/usr/src/linux-headers-5.10.0-0.bpo.3-amd64/include/config/security/apparmor/hash
/usr/src/linux-headers-5.10.0-0.bpo.3-amd64/include/config/security/apparmor/hash.h
/usr/src/linux-headers-5.10.0-0.bpo.3-amd64/include/config/security/apparmor/hash/default.h
/var/lib/dpkg/info/libapparmor1:amd64.list
/var/lib/dpkg/info/libapparmor1:amd64.md5sums
/var/lib/dpkg/info/libapparmor1:amd64.shlibs
/var/lib/dpkg/info/libapparmor1:amd64.symbols
/var/lib/dpkg/info/libapparmor1:amd64.triggers
groucho@devuan:~$
This is what I have in one of my VMs:
groucho@dev-pihole:~$ uname -a
Linux dev-pihole 4.9.0-17-amd64 #1 SMP Debian 4.9.290-1 (2021-12-12) x86_64 GNU/Linux
groucho@dev-pihole:~$ apt list | grep installed | grep -i apparmor
libapparmor1/oldoldstable,now 2.11.0-3+deb9u2 amd64 [installed,automatic]
groucho@dev-pihole:~$ locate apparmor
/etc/apparmor
/etc/apparmor.d
/etc/apparmor/init
/etc/apparmor/init/network-interface-security
/etc/apparmor/init/network-interface-security/usr.sbin.ntpd
/etc/apparmor.d/tunables
/etc/apparmor.d/usr.sbin.ntpd
/etc/apparmor.d/usr.sbin.unbound
/etc/apparmor.d/local/usr.sbin.ntpd
/etc/apparmor.d/local/usr.sbin.unbound
/etc/apparmor.d/tunables/ntpd
This is what I have in another one of my VMs:
groucho@chimaera:~$ uname -a
Linux chimaera 5.10.0-9-amd64 #1 SMP Debian 5.10.70-1 (2021-09-30) x86_64 GNU/Linux
groucho@chimaera:~$
root@chimaera:~# apt list | grep installed | grep -i apparmor
libapparmor1/stable,now 2.13.6-10 amd64 [installed,automatic]
root@chimaera:~#
root@chimaera:~# locate apparmor
/etc/apparmor
/etc/apparmor.d
/etc/apparmor/parser.conf
/etc/apparmor.d/abstractions
/etc/apparmor.d/lsb_release
/etc/apparmor.d/nvidia_modprobe
/etc/apparmor.d/usr.bin.man
/etc/apparmor.d/abstractions/X
/etc/apparmor.d/abstractions/apache2-common
/etc/apparmor.d/abstractions/apparmor_api
/etc/apparmor.d/abstractions/aspell
/etc/apparmor.d/abstractions/audio
/etc/apparmor.d/abstractions/authentication
/etc/apparmor.d/abstractions/base
/etc/apparmor.d/abstractions/bash
/etc/apparmor.d/abstractions/consoles
/etc/apparmor.d/abstractions/cups-client
/etc/apparmor.d/abstractions/dbus
/etc/apparmor.d/abstractions/dbus-accessibility
/etc/apparmor.d/abstractions/dbus-accessibility-strict
/etc/apparmor.d/abstractions/dbus-network-manager-strict
/etc/apparmor.d/abstractions/dbus-session
/etc/apparmor.d/abstractions/dbus-session-strict
/etc/apparmor.d/abstractions/dbus-strict
/etc/apparmor.d/abstractions/dconf
/etc/apparmor.d/abstractions/dovecot-common
/etc/apparmor.d/abstractions/dri-common
/etc/apparmor.d/abstractions/dri-enumerate
/etc/apparmor.d/abstractions/enchant
/etc/apparmor.d/abstractions/exo-open
/etc/apparmor.d/abstractions/fcitx
/etc/apparmor.d/abstractions/fcitx-strict
/etc/apparmor.d/abstractions/fonts
/etc/apparmor.d/abstractions/freedesktop.org
/etc/apparmor.d/abstractions/gio-open
/etc/apparmor.d/abstractions/gnome
/etc/apparmor.d/abstractions/gnupg
/etc/apparmor.d/abstractions/gvfs-open
/etc/apparmor.d/abstractions/hosts_access
/etc/apparmor.d/abstractions/ibus
/etc/apparmor.d/abstractions/kde
/etc/apparmor.d/abstractions/kde-globals-write
/etc/apparmor.d/abstractions/kde-icon-cache-write
/etc/apparmor.d/abstractions/kde-language-write
/etc/apparmor.d/abstractions/kde-open5
/etc/apparmor.d/abstractions/kerberosclient
/etc/apparmor.d/abstractions/ldapclient
/etc/apparmor.d/abstractions/libpam-systemd
/etc/apparmor.d/abstractions/likewise
/etc/apparmor.d/abstractions/mdns
/etc/apparmor.d/abstractions/mesa
/etc/apparmor.d/abstractions/mir
/etc/apparmor.d/abstractions/mozc
/etc/apparmor.d/abstractions/mysql
/etc/apparmor.d/abstractions/nameservice
/etc/apparmor.d/abstractions/nis
/etc/apparmor.d/abstractions/nvidia
/etc/apparmor.d/abstractions/opencl
/etc/apparmor.d/abstractions/opencl-common
/etc/apparmor.d/abstractions/opencl-intel
/etc/apparmor.d/abstractions/opencl-mesa
/etc/apparmor.d/abstractions/opencl-nvidia
/etc/apparmor.d/abstractions/opencl-pocl
/etc/apparmor.d/abstractions/openssl
/etc/apparmor.d/abstractions/orbit2
/etc/apparmor.d/abstractions/p11-kit
/etc/apparmor.d/abstractions/perl
/etc/apparmor.d/abstractions/php
/etc/apparmor.d/abstractions/php5
/etc/apparmor.d/abstractions/postfix-common
/etc/apparmor.d/abstractions/private-files
/etc/apparmor.d/abstractions/private-files-strict
/etc/apparmor.d/abstractions/python
/etc/apparmor.d/abstractions/qt5
/etc/apparmor.d/abstractions/qt5-compose-cache-write
/etc/apparmor.d/abstractions/qt5-settings-write
/etc/apparmor.d/abstractions/recent-documents-write
/etc/apparmor.d/abstractions/ruby
/etc/apparmor.d/abstractions/samba
/etc/apparmor.d/abstractions/smbpass
/etc/apparmor.d/abstractions/ssl_certs
/etc/apparmor.d/abstractions/ssl_keys
/etc/apparmor.d/abstractions/svn-repositories
/etc/apparmor.d/abstractions/ubuntu-bittorrent-clients
/etc/apparmor.d/abstractions/ubuntu-browsers
/etc/apparmor.d/abstractions/ubuntu-browsers.d
/etc/apparmor.d/abstractions/ubuntu-console-browsers
/etc/apparmor.d/abstractions/ubuntu-console-email
/etc/apparmor.d/abstractions/ubuntu-email
/etc/apparmor.d/abstractions/ubuntu-feed-readers
/etc/apparmor.d/abstractions/ubuntu-gnome-terminal
/etc/apparmor.d/abstractions/ubuntu-helpers
/etc/apparmor.d/abstractions/ubuntu-konsole
/etc/apparmor.d/abstractions/ubuntu-media-players
/etc/apparmor.d/abstractions/ubuntu-unity7-base
/etc/apparmor.d/abstractions/ubuntu-unity7-launcher
/etc/apparmor.d/abstractions/ubuntu-unity7-messaging
/etc/apparmor.d/abstractions/ubuntu-xterm
/etc/apparmor.d/abstractions/user-download
/etc/apparmor.d/abstractions/user-mail
/etc/apparmor.d/abstractions/user-manpages
/etc/apparmor.d/abstractions/user-tmp
/etc/apparmor.d/abstractions/user-write
/etc/apparmor.d/abstractions/video
/etc/apparmor.d/abstractions/vulkan
/etc/apparmor.d/abstractions/wayland
/etc/apparmor.d/abstractions/web-data
/etc/apparmor.d/abstractions/winbind
/etc/apparmor.d/abstractions/wutmp
/etc/apparmor.d/abstractions/xad
/etc/apparmor.d/abstractions/xdg-desktop
/etc/apparmor.d/abstractions/xdg-open
/etc/apparmor.d/abstractions/apparmor_api/change_profile
/etc/apparmor.d/abstractions/apparmor_api/examine
/etc/apparmor.d/abstractions/apparmor_api/find_mountpoint
/etc/apparmor.d/abstractions/apparmor_api/introspect
/etc/apparmor.d/abstractions/apparmor_api/is_enabled
/etc/apparmor.d/abstractions/ubuntu-browsers.d/java
/etc/apparmor.d/abstractions/ubuntu-browsers.d/kde
/etc/apparmor.d/abstractions/ubuntu-browsers.d/mailto
/etc/apparmor.d/abstractions/ubuntu-browsers.d/multimedia
/etc/apparmor.d/abstractions/ubuntu-browsers.d/plugins-common
/etc/apparmor.d/abstractions/ubuntu-browsers.d/productivity
/etc/apparmor.d/abstractions/ubuntu-browsers.d/text-editors
/etc/apparmor.d/abstractions/ubuntu-browsers.d/ubuntu-integration
/etc/apparmor.d/abstractions/ubuntu-browsers.d/ubuntu-integration-xul
/etc/apparmor.d/abstractions/ubuntu-browsers.d/user-files
/etc/apparmor.d/local/README
/etc/apparmor.d/local/lsb_release
/etc/apparmor.d/local/nvidia_modprobe
/etc/apparmor.d/local/usr.bin.man
/etc/apparmor.d/tunables/alias
/etc/apparmor.d/tunables/apparmorfs
/etc/apparmor.d/tunables/dovecot
/etc/apparmor.d/tunables/global
/etc/apparmor.d/tunables/home
/etc/apparmor.d/tunables/home.d
/etc/apparmor.d/tunables/kernelvars
/etc/apparmor.d/tunables/multiarch
/etc/apparmor.d/tunables/multiarch.d
/etc/apparmor.d/tunables/proc
/etc/apparmor.d/tunables/run
/etc/apparmor.d/tunables/securityfs
/etc/apparmor.d/tunables/share
/etc/apparmor.d/tunables/sys
/etc/apparmor.d/tunables/xdg-user-dirs
/etc/apparmor.d/tunables/xdg-user-dirs.d
/etc/apparmor.d/tunables/home.d/site.local
/etc/apparmor.d/tunables/home.d/ubuntu
/etc/apparmor.d/tunables/multiarch.d/site.local
/etc/apparmor.d/tunables/xdg-user-dirs.d/site.local
/etc/init.d/apparmor
/etc/rcS.d/K88apparmor
/etc/systemd/system/apparmor.service
/etc/systemd/system/sysinit.target.wants/apparmor.service
/usr/lib/x86_64-linux-gnu/libapparmor.so.1
/usr/lib/x86_64-linux-gnu/libapparmor.so.1.6.3
/usr/src/linux-headers-5.10.0-9-amd64/include/config/default/security/apparmor.h
/usr/src/linux-headers-5.10.0-9-amd64/include/config/security/apparmor
/usr/src/linux-headers-5.10.0-9-amd64/include/config/security/apparmor.h
/usr/src/linux-headers-5.10.0-9-amd64/include/config/security/apparmor/hash
/usr/src/linux-headers-5.10.0-9-amd64/include/config/security/apparmor/hash.h
/usr/src/linux-headers-5.10.0-9-amd64/include/config/security/apparmor/hash/default.h
/var/cache/apparmor
/var/cache/apparmor/c08a2770.0
/var/cache/apparmor/c08a2770.0/.features
/var/cache/apparmor/c08a2770.0/lsb_release
/var/cache/apparmor/c08a2770.0/nvidia_modprobe
/var/cache/apparmor/c08a2770.0/usr.bin.man
/var/lib/dpkg/info/apparmor.list
/var/lib/dpkg/info/apparmor.postrm
/var/lib/systemd/deb-systemd-helper-enabled/apparmor.service.dsh-also
/var/lib/systemd/deb-systemd-helper-enabled/sysinit.target.wants/apparmor.service
/var/lib/systemd/deb-systemd-helper-masked/apparmor.service
root@chimaera:~#
See what I am referring to?
Then there's what happens when you add apparmor=0 to the kernel command line.
Only the ascii VM reports it as being disabled:
groucho@dev-pihole:~$ sudo dmesg | grep AppArmor
[    0.286356] AppArmor: AppArmor disabled by boot time parameter
The chimaera VM does not:
root@chimaera:~# dmesg | grep AppArmor
root@chimaera:~#
Not does the ascii installation with the backported kernel:
groucho@devuan:~$ sudo dmesg | grep AppArmor
groucho@devuan:~$
I fail to see what an apparmor library has to do with dbus.
Or why the chimaera file system has acquired all these apparmor related files if it is not installed or has been purged.
Anyone know or have comments about this?
#8 2021-12-28 13:14:26
Because the dbus package has been built with AppArmor support enabled for architectures that support it:
https://salsa.debian.org/utopia-team/db … re.ac#L200
The AppArmor libraries won't ever be used if AppArmor is disabled so you should be able to remove them manually without breaking your system if you're that bothered by them.
#9 2021-12-28 15:02:46
Because the dbus package has been built with AppArmor support ...
I see.
... AppArmor libraries won't ever be used if AppArmor is disabled ...
... should be able to remove them manually ...
Sure.
I know well enough not to muck with stuff in /etc so I will let that be for the moment.
But it isn't so much that I'm bothered by them.
I'm bothered by the fact that they are quite obviously* apparmor files and not dbus files.
* /etc/apparmor/*, /etc/apparmor.d/*, /etc/apparmor/init/*
In my "non-expert/developer/programmer" opinion, they should not be there unless apparmor is actually installed and enabled.
ie: What do I need them there for? They got there because apparmor is installed and enabled by default.
How come they are not removed/purged when apparmor is removed?
apparmor and tomoyo should not be foisted onto your installation unless you actually want to install them.
I have the idea that something is not right here.
For whatever reason it reminds me of how MS wove IE into Windows 95 so as to make it almost inoperable if it was pulled out*.
* to be able to choose an alternate browser.
Eventually MS were found out and exposed, but by then the damage was already done.
#10 2021-12-28 16:53:26
See https://wiki.debian.org/WhereIsIt#A.22I … g_to.3F.22 to find out which package(s) own(s) those files.
Debian make several separate packages so that you can uninstall the main apparmor package without breaking the dependency chain for packages that make use of those files if AppArmor is enabled. Arch lump everything together in their apparmor package so in that distribution you *must* have the AppArmor user space utilities installed to satisfy the dependencies of any packages that are compiled with support. This is not the case in Debian, which seems like an improvement to me.
It is important to note here that the AppArmor functionality is actually provided by the kernel itself so if you really want to be rid of it you'll have to roll your own kernel with CONFIG_SECURITY_APPARMOR disabled. The apparmor package only provides the user space utilities to control the kernel space functionality.
Reference: https://www.kernel.org/doc/html/v5.10/a … armor.html
#11 2021-12-28 19:01:31
See ...
... which package(s) own(s) those files.
Thanks for the link.
Quite useful.
Debian make several separate packages ...
Arch lump everything together in their apparmor package ...
... *must* have the AppArmor user space utilities installed ...
... not the case in Debian, which seems like an improvement to me.
I'm not in a situation to argue for or against.
But to me it seems like an unwarranted excess on behalf of the Debian crew.
Just like having apparmor installed and enabled by default.
Or ignoring the fact that it is disabled in the kernel command line to reinstall and enable it again when upgrading the kernel.
But Poettering seems to be in charge, so I'm not at all surprised.
My point is that if you want to install apparmor, then do it installing all the needed dependencies/utilities with it.
No need to fill up the system with files I won't be using.
It's like going to the cinema with a bathing trunk under my trousers.
Just in case I decide to go for a swim at the beach.
The nearest one being 400 km. away.
... the AppArmor functionality is actually provided by the kernel itself ...
I'm quite aware of that.
Thank you very much for taking the time to explain this. 8^ )
#12 2021-12-28 19:08:18
Don't be silly. Massive, faceless, psychopathic corporate entities took control of the kernel quite some time ago.
https://linuxfoundation.org/our-members … erpower-2/
#13 2021-12-28 22:59:01
Don't be silly.
Tsk, tsk ...
No name calling ... 8^D !!!
But Poettering massive, faceless, psychopathic corporate entities seem to be in charge.
Better?
So, if not Potty, then it is the MFPCEs but the issue (for me) stands.
ie:
You don't go to the cinema with a bathing trunk under your trousers, just in case you decide to go for a swim at the beach, 400 km. away.
Whoever decided this apparmor setup is a dick should seriously reconsider.
Thanks for taking the time to explain all this and for the humour.
