Pages: 1
I am trying to get SmoothWall to run on Devuan.
In which I'm trying to make a /boot/grub/custom.cfg that boots to /dev/harddisk.
Is this possible ??
Haven't had much luck yet .. ~
Is this possible ?
Share your efforts then. Post exact configuration and commands though, vague descriptions will just lead to confusion and bad advice.
But having said that you should get better support here. Your money should buy you that, at least, right?
“Et ignotas animum dimittit in artes.” — Ovid, Metamorphoses, VIII, 18.
My garbly-gook so far is
# https://www.gnu.org/software/grub/manual/grub/html_node/Simple-configuration.html
# nano -w /boot/grub/custom.cfg
# cp -v /boot/grub/custom.cfg /root/swe/coretree/coretree/boot/grub/custom.cfg
menuentry 'SmoothWall Express GNU/Linux' --class smoothwall --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-simple-955e45ca-5142-4cc4-89d1-bbae49bf512c' {
#splashimage=/grub/express_boot_protect.xpm.gz
#foreground=cfcfcf
#background=222222
load_video
insmod gzio
insmod part_msdos
insmod ext2
set inittab /etc/inittab-swe
#set root='hd0,msdos1'
unset root
unset device
#set
set device 'hd0' /dev/harddisk
set root 'hd0,0'
setup (hd0)
#quit
##kernel /vmlinuz-${Kernel_Version}${KERNEL_TYPE} root=/dev/harddisk4 ro quiet
#kernel /vmlinuz-${Kernel_Version}${KERNEL_TYPE} root=$(UUID) ro quiet
search --no-floppy --fs-uuid --set=root 955e45ca-5142-4cc4-89d1-bbae49bf512c
echo 'Loading/Starting Linux 5.10.0-9-amd64 ...'
#linux /boot/vmlinuz-5.10.0-9-amd64 root=UUID=955e45ca-5142-4cc4-89d1-bbae49bf512c ro quiet
linux /boot/vmlinuz-5.10.0-9-amd64 root=/dev/harddisk1 ro quiet
echo 'Loading initial ramdisk smoothwall.initramfs.gz ...'
initrd /boot/smoothwall.initramfs.gz
Try something like this:
menuentry 'SmoothWall' {
search --fs-uuid --set=root 955e45ca-5142-4cc4-89d1-bbae49bf512c
That presumes the SmoothWall system is installed on a partition with the stated UUID, that /boot is on the root partition (ie, it does not have a separate /boot partition) and that the kernel image is at /boot/vmlinuz-5.10.0-9-amd64 with the initramfs at /boot/smoothwall.initramfs.gz.
If SmoothWall is Debian-based then you may find symlinks from the kernel image & initramfs to /vmlinuz & /initrd.img, which can be quoted in the menuentry to avoid having to update the configuration file whenever the kernel version changes.
EDIT: be sure to place the file at /boot/grub/custom.cfg on the system from which GRUB reads it's configuration. Use the set command (with no options or arguments) from the GRUB command line to see the $configfile parameter which dictates this.
This is how i do it, legacy bios only. I bypass the uuid and use a label.
exec tail -n +3 $0
# This file provides an easy way to add custom menu entries. Simply type the
# menu entries you want to add after this comment. Be careful not to change
# the 'exec tail' line above.
menuentry "Artix (loader)" {
insmod msdos
insmod ext4
search --no-floppy --label --set=root ARTIX
configfile /boot/grub/grub.cfg
It is not on a different partition.
It's just a different startup, as it uses rc.d and /dev/harddrive.
But it really sounds like you should be taking advantage of the support for which you have paid SmoothWall money.
what is this smoothwall, how does it coexist alongside the devuan linux os?
It is a free open source Linux Firewall GUI
https://smoothwall.org/
https://community.smoothwall.org/forum/index.php
So there is no "Paid for Support"
Ah, my apologies. I thought you were referring to https://www.smoothwall.com/
A shame you didn't provide a link in the OP. That would have prevented us wasting our time, eh?
And as you appear to be reluctant to engage beyond cryptic utterances I'll bow out of this thread now. Good luck!
Pages: 1
