#1 2021-11-22 19:05:45
uther
[SOLVED] Xorg update and broken GPU drivers in daedalus
Today's Xorg and mesa AMD driver update broke OpenGL parts of xfce desktop and other applications in daedalus.
Updated among others:
xserver-xorg-video-amdgpu:amd64 (19.1.0-2, 21.0.0-2),
liobdrm-amdgpu1:amd64 (2.4.107-8, 2.4.108-1),
I'm running two screens and there is a lot of issues after this update:
- certain windows on main display are giga-sluggish and leave that funny trace of itself, but only for a brief moment
- navigation in some app is broken, menus are closing after moving cursor inside them (Firefox), clicks are not registered (Mullvad)
- the only title bars that are visible are fat, Gnome ones, rest are not rendered
- can't maximize/minimize windows
- system don't recognize shortcuts like Alt+F4 (but Ctrl+Q works)
- Alt+RMB windows resize don't work
- mouse cursor is displayed as 'x' symbol/icon
- can't switch between workspaces
- in xfce panel there are no application bars although apps are opened
... plus a lot more
Running Blender from CLI reveals:
libGL error: MESA-LOADER: failed to open swrast: /usr/lib/dri/swrast_dri.so: cannot open shared object file: No such file or directory (search paths /usr/lib/x86_64-linux-gnu/dri:\$${ORIGIN}/dri:/usr/lib/dri, suffix _dri)
libGL error: failed to load driver: swrast
Error! Unsupported graphics card or driver.
A graphics card and driver with support for OpenGL 3.3 or higher is required.
Is rolling back an option here? INB4 - yes, to Chimaera :^)
Thanks for any advice.
ED: I reinstalled all mesa packages including libgl1-mesa-glx and mesa-utils, but no effect.
ED2: glxgears gives identical output as Blender plus: Error: glCreateContext failed
ED3: After checking there is no /usr/lib64 directory, but in /usr/lib/x86_64-linux-gnu/dri there is swrast_dri.so
soystemd-free diet
#2 2021-11-23 13:52:41
Re: [SOLVED] Xorg update and broken GPU drivers in daedalus
Can we see
glxinfo -B
No, that is not supported.
You would be better switching to ceres IMO — the mandatory 10-14 day transition delay to testing means that breakage is fairly common (hence the name "testing") and also that if things are broken they can stay broken for a while. If you can't troubleshoot this sort of thing yourself then you probably shouldn't be running testing.
#3 2021-11-23 15:46:24
uther
I found the temporary fix.
Uninstalling proprietary AMD GPU drivers fixed the problem. Also I tested previous drivers back to 20.40 and installing any versions from 20.40 onwards brings the problem back, so this is probably some conflict with mesa and/or xorg.
soystemd-free diet
#4 2021-11-23 16:23:49
Why are you using AMDGPU PRO? It performs worse than the open source driver for everything and it is unsupported for De{bi,vu}an. Installing the Ubuntu package will uninstall the native graphics stack unless you follow this guide and even that might not work.
And most importantly: why didn't you mention the PRO drivers in your OP? Are we supposed to be psychic? Please include *all* relevant information in future threads.
#5 2021-11-23 18:47:50
uther
Sorry about that. Won't happen again.
I know they are shit, but you can't compute 3d rendering on a AMD GPU in Blender without them. That's why I have installed only OpenCL parts of proprietary driver. OpenGL and display is handled by mesa.
I do it that way because there is no better alternative to have both smooth display and compute stack for 3d rendering.
ED:
Wait. I was wrong. I thought that installing PRO drivers with --headless installs only compute part of the driver. But I followed the link you provided and voila I have working OpenCL and no problem described in the first post! Did I ran this machine for so long only THINKING that I'm using mesa as a display driver? LOL if true.
So the problem seems to be a conflict between mesa and PRO display drivers when they are both installed.
Marking as solved.
soystemd-free diet
#6 2021-11-24 16:50:42
Ah, excellent, that is good news. Perhaps consider informing the author of the linked guide so that they can declare Devuan as a working configuration.
#7 2021-12-22 16:54:18
uther
Will do as soon as I make GitLab account.
On a sidenote. There is an ongoing effort between Debian maintainers and AMD of packaging opensource AMD compute drivers under the name ROCm for Debian. ROCm and particularly HIP replaces OpenCL as a compute stack in modern AMD GPUS.
Look for it on this mailing list:
https://lists.debian.org/debian-ai/2021 … html#00054
The goal is the ability to install compute driver stack for AMD gpu with sudo apt install rocm or something similar.
soystemd-free diet
