#1 2021-11-12 00:09:10
GNUser
bind mounts show up on MATE desktop
I'm on Chimaera with MATE 1.24.1 and caja 1.24.0. When I used older Devuan ASCII + MATE, caja would not show bind mounts on the deskop. This is the desired, expected behavior (I used bind mounts extensively and having every one of them show up on the desktop creates clutter).
Does anyone know how to hide bind mounts from the MATE desktop? I found the org.mate.caja.desktop volumes-visible setting in dconf but I do not want to hide mounted devices from the desktop, I just want to hide bind mounts.
#2 2021-11-12 10:17:19
Re: bind mounts show up on MATE desktop
Does this help?
#3 2021-11-13 04:50:17
GNUser
Thank you, HoaS. Yes, that's helpful. I'll give patching caja a shot sometime.
Meanwhile, I'll let the MATE developers know about the issue and patch so that they can consider adopting it. It would be nice to have this without having to recompile anything.
