#1 2021-11-05 10:25:36
alsen
[SOLVED] Binding eth0, eth1 change after reboot on Chimaera
Hi to all
i have noticed that after some reboot on a DELL T420 server with 3 nic (2 on motherboard e 1 on bus) the binding of eth0, 1,2 with fisical NIC change
What is the problem ?
Can i bind et0,1,2 with the mac address ?
Thank to all
Alberto
Maker and a fun of Devuan and enthusiastic about Aquinas
#2 2021-11-05 18:27:08
Re: [SOLVED] Binding eth0, eth1 change after reboot on Chimaera
#3 2021-11-12 14:20:25
alsen
Thanks a lot
