#1 2021-10-17 15:57:43
alphalpha
Forge OS
Forge  -  https://forge-os.sourceforge.io
  • formerly known as 'Michaels-Devuan-Edition'
    based on experimental Refracta nodbus iso
    uses Devuan Chimaera repos
  • Comes with 5 preconfigured window managers to choose from:
    JWM, i3, bspwm, spectrwm and exwm (the latter one is sort of a meme)
  • Has a ton of software installed and configured:
    Multiple browsers, office applications, audio and video production software, image editing and much more
#2 2021-10-17 23:06:08
andyprough
Re: Forge OS
Awesome! I'm going to download it now and take it for a spin.
#3 2021-10-18 21:52:48
LarryDC
Re: Forge OS
Michael,
I downloaded it last night as soon as it was visible on the site from here in USA. Nice touch having the sha256sum right there.
This morning I installed it and am using it right now. I went through all of the configuration steps just to see what was there.
The installation was unbelievably fast ... 10 minutes ... not counting my looking at things.
After boot up on a dedicated HD partition, the same quality software I've been used to was there again. I'm now tweaking the JWM keys and getting adding popups on the "panel [tray]" icons, a modified conkyrc across the bottom of the screen.
I'm going to try and stick to your zsh since you've got so much added to it.
Thanks again.
As an aside: Is there any way of getting a small donation to you? Or do I have to wait until you visit the Boston area And I can take you out to dinner? wink
Registered Linux User #305687 (Forge jwm, Obarun jwm, Crowz jwm, Voidlinux jwm, Sparky Testing jwm, Absolute icewm, PCLinuxOS plasma)
i5 8GB RAM & 3 HD + Lenovo Thinkpad T61 w/ 4GB RAM
#4 2021-10-18 23:31:43
alphalpha
Re: Forge OS
Hey Larry i am glad that you like it
If you would rather use bash, you could just try chsh to bash, i have not tested this very well but the files that get sourced by zsh, also get sourced by .bashrc
and all scripts use sh anyway, so it should be mostly the same in theory, i just prefer the zsh's tab-complete.
Thanks, i dont take donations, but if you would throw a fiver or something to someone who really needs it, that would be awesome.
Sadly i dont think i will be around Boston in the near or later future, but i will message you in that case
Let me know if there are any issues.
I personally have encountered 2 problems, that we could discuss here
I guess since this is not mentioned elsewhere i throw it in here
1) Scanning for wifi networks with Ceni now takes ages, it used to be a few seconds
i dont have a solution for this, but i also added setnet to the iso
2) i have one machine where i needed to manually setup the graphics driver in xorg.conf because it would not use the correct one although it is installed
but that machine is a strange beast anyway, it works great on all my thinkpads and my desktop
PS: Thanks to the person behind JWM-Kit! i forked you wallpaper tool and i love it
PPS: And also thanks to fsmithred for refracta and also to the whole Devuan team!
#5 2021-10-19 01:22:52
LarryDC
Re: Forge OS
Will do on the someone who needs it.
Too bad about Boston area.
You'll have a place to stay if you ever make it.
For my part I'm studying French not German (I'm only 1/8 German but 3/8 French). To do that I need to run google Chrome [Version 94.0.4606.71 (Official Build) unknown (64-bit)]. It is the only browser that duolingo.com will capture microphone input from. Now I have to find which of the 6 possible configurations for my microphone (Microsoft LifeCam Cinema) will work.
Update: The second one worked: It needed "all software conversions".
I use 50 foot Category 6 Ethernet cable from my upstairs router; there is no wireless on this old rig.
On the graphics front I tried just booting my 4.19 kernel and initrd from Michael Deuvan 4 since it uses nvidia-legacy-340xx which gives me 75Hz.
Naturally it didn't work because the nvidia drivers aren't installed on Forge.  It uses the nouveau driver  at 60Hz.
Thanks again.
#6 2021-10-25 05:35:27
tuxnoobfr
Re: Forge OS
please can you clone goodlifelinux? it was so lightweight and it only had a few programs installed by default sad I was never able to get wifi or wired working with all the derivatives on here, I know you guys don't spoonfeed newbies but jessie has been archived for a while
#7 2021-10-25 16:25:59
alphalpha
Re: Forge OS
Sorry i am not going to clone a distro that i never heard of, and lightweight in terms of disk usage is not my motto
you can easily make your own devuan iso with refractasnapshot
if you post some more details about that on irc or in the forum, i am pretty sure someone will help you
#8 2021-11-04 17:30:49
LarryDC
Re: Forge OS
Some observations:
1 - The wallpaper.sh script seems to have an error:
line 2 :
LINK="$HOME/.local/wallpaper"
should be:
LINK="$HOME/.local/wallpaper.png"
2 - update_qutebrowser.sh no longer finds LATEST_VERSION
My kludge is to insert the following as line 22:
LATEST_VERSION="v2.4.0"
If there are any nvidia-legacy-340 users out there it IS possible to get nvidia-340-108 to deliver 75HZ on Forge. per Matt Fletcher on the Devuan list:
Dng mailing list <Dng@lists.dyne.org> https://mailinglists.dyne.org/cgi-bin/m … stinfo/dng:
"I  have it working on chimaera after patching the NVIDIA installer with
patches from arch:
https://aur.archlinux.org/packages/nvidia-340xx/
Run The NVIDIA installer with --extract-only and apply the
000*-kernel-5.* patches, then run nvidia-installer from the extracted
directory."
Still my main distro.  Thanks for all your work!
Larry
#9 2021-11-05 18:38:56
alphalpha
Re: Forge OS
LarryDC wrote:
Some observations:
line 2 :
should be:
Hi Larry,
thanks for helping to improve this project.
The file extiension for the wallpaper was dropped on purpose, when i made the new gui wallpaper chooser ( themes > wallpaper > select wallpaper )
but i see that i forgot to change that in the "old" way.
This command should fix it for now:
sed -i 's:WP=".local/wallpaper.png":WP=".local/wallpaper":' ~/.config/jwm/dynamic/wallpaper.sh
You should try the gui wallpaper changer if you have not discovered it yet, its way more elegant
I noticed the qutebrowser update problem too (and the one for shotcut), on monday i did upload a new iso where this is fixed
but no need to reinstall the whole thing, i uploaded all relevant scripts on gitlab just now.
Actually i did update more of the scripts so the best thing would be to just copy the .local/Script directory and overwrite everthing that has changed
git clone https://gitlab.com/_alphalpha_/forge-dotfiles.git
cp -R forge-dotfiles/.local/Scripts/* .local/Scripts
In the beowulf release this would be done automatically with 'update_all' but i decided to drop that feature.
From now on you will be able to see new gitlab commits in newsbeuter (super + , )
the rss feed should already be there, you can refresh the list with 'r'
Edit: also to get the calendar working, create .config/kalendar directory
#10 2022-01-13 00:04:43
LarryDC
Re: Forge OS
Forge-2022_01_B install:
All went well. I'm happy you've included keepassxc which I have happily used for years. If you use an Android phone be sure to install Lonely Cat's X-plore on it. That way you can easily copy your password file back and forth without having to trust the cloud. Just have both phone & computer on the same network and click on WiFi file sharing in X-plore.
I did prefer my compiled [to /usr/local/bin/] claws_mail 4.0 to the 3.17 that devuan still uses. It runs flawlessly and all I needed to add to get it working on Forge were:
libcompface1 and libetpan20
Again my old NVIDIA GT218 card to run at 75HZ instead of nouveau's 60HZ was to run the nvidia-installer in the correct extracted and patched directory as I wrote previously.
Hopefully the kernel stays put. Otherwise I'll have to re-install the nvidia 340-108 driver.
It's still my main distro. And yes the new xwallpaper app is very nice.
Now to get Remind set up so my extended family birthdays and anniversaries repeat each year. Then to update the entries in Gramps.
Thanks again, Michael, for all your work.
#11 2022-03-11 18:22:12
alphalpha
Re: Forge OS
@devujuanaluvver
Sorry i cannot reply to your emails
I'm sorry to have to inform you that your message could not
be delivered to one or more recipients. It's attached below.
For further assistance, please send mail to postmaster.
If you do so, please include this problem report. You can
delete your own text from the attached returned message.
The mail system
The old isos are no longer available,
Forge is basically the same, but upgraded to chimaera and with improvements on the installer and other scripts
if you are looking for a specific script or config file, you can find them here on gitlab
#12 2022-03-27 05:08:03
devujuanaluvver
Re: Forge OS
Sorry, I just updated my email. That's why you couldn't send the email. I really wish you still had the old color scheme or a way to get the old color scheme from your original Michael Devuan Derivative version. Perhaps you can have a theming option to return that color and font scheme?
#13 2022-04-01 08:39:48
alphalpha
Re: Forge OS
if you are using jwm, there is a theme option in the right-click menu
if you do mean the darkpurple/orange theme, that is still there
or do you mean the terminal theme?
i am not really shure which theme yoou want
i did change the qt theme from yaru to adapta, because yaru looked different in chimaera
the gtk theme has always been snowblind-sunset
if you can tell me exactly what you are looking for or have a screenshot, i will see what i can do
#14 2022-04-14 14:54:16
alphalpha
Re: Forge OS
I just uploaded version 22-04
There is no complete list of changes, but here are the highlights:
  • alacritty replaced urxvt
  • lossless-cut replaced vidcutter
  • antimicrox replaced qjoypad
  • yt-dlp replaced youtube-dl
  • magnifiqus replaced xzoom
  • qps is the default task manager again
  • new emulators: visualboyadvance-m, bsnes and bsnes-plus
  • and rom patchers flips and lazy_ips
  • Cardinal as new virtual modular synthesizer lv2-plugin
  • there was a bug in the installer that got fixed
  • /usr/local/bin/datetime.sh now has a '--auto' option, to automatically set the system time
  • some scripts in the jwm menu got fixed and i added new ones (set date format, change conky color and toggle to maximize all windows)
  • syslinux bootloader now looks for the symlink /boot/vmlinuz, it will update automatically when a new kernel is installed (/etc/kernel/postinst.d/yy-bootlink)
  • OBS will now start, if your pc does not support GLSL >3.3
  • other new applications are zbarcam-qt to scan qr-codes and crazydiskinfo to check s.m.a.r.t parameters
  • qutebrowser will delete .local/share/qutebrowser/webengine before it starts, this prevents a rare case where it will always freeze
  • conky will now only show battery and wifi info, if those are present on your system
more changes can be seen here https://gitlab.com/_alphalpha_/forge-do … cd98499bd1
