#1 2021-10-04 14:42:31
macondo123
Runit problem - Devs heads up
I did a fresh install on a new computer and chose runit during the installation.
After reboot I could not do typing, could not enter X.
I wiped the partition, and reinstalled, installing this time Sysvinit, rebooted and no problems, everything was hunkydorry.
thanks,
#2 2021-10-05 09:35:28
xinomilo
Re: Runit problem - Devs heads up
last week i installed chimaera with runit + MATE using chimaera installer iso  (netinstall). no such problem after booting into new system.
you probably need to give some more info on the medium used for installation...
#3 2021-10-05 19:12:07
macondo123
Netinstall iso > Expert
the kbd did not work, reboot from the console did not work, etc
#4 2021-10-21 11:51:23
NicePics13
That sounds like my experience once trying to install from a beta debian netinstall on PowerPC wink
Have done plenty of Devuan Beowulf and Chimaera expert installs with runit and no problems so far - perhaps your ISO was faulty?
