#1 2021-09-24 19:31:18
hagbard_
[SOLVED] Updating kexec-tools from chimaera to daedalus
That's what I get when updating kexec-tools (output after dpkg --configure kexec-tools):
Setting up kexec-tools (1:2.0.22-2+b1) ...
Error: argument 'restart' not supported
invoke-rc.d: initscript kexec, action "restart" failed.
dpkg: error processing package kexec-tools (--configure):
installed kexec-tools package post-installation script subprocess returned error exit status 1
kexec-tools
I this devuan specific, since it relates to init? Or should a bug be posted to debian (didn't find any relating to this so far)? Or is a devuan fork necessary?
"restart" seems to be weird for something that isn't a daemon.
#2 2021-10-21 20:51:17
hagbard_
Re: [SOLVED] Updating kexec-tools from chimaera to daedalus
The postinst script indeed tries to invoke the restart action, which does not exist for kexec.
Removing the following section from the postinst script seems to fix the problem.
# Automatically added by dh_installinit/13.4.1
if [ "$1" = "configure" ] || [ "$1" = "abort-upgrade" ] || [ "$1" = "abort-deconfigure" ] || [ "$1" = "abort-remove" ] ; then
    if [ -z "${DPKG_ROOT:-}" ] && [ -x "/etc/init.d/kexec" ]; then
        update-rc.d kexec defaults >/dev/null
        invoke-rc.d kexec restart || exit 1
    fi
fi
# End automatically added section
    if [ -z "${DPKG_ROOT:-}" ] && [ -x "/etc/init.d/kexec-load" ]; then
        update-rc.d kexec-load defaults >/dev/null
        invoke-rc.d kexec-load restart || exit 1
    fi
fi
#3 2022-09-14 15:59:16
mirrortokyo
I'm still stuck with kexec-tools 1:2.0.20-2.1 - Debian upstream doesn't appear to have addressed this problem.
#4 2025-01-01 00:56:13
mirrortokyo
Tried to get kexec to work again, maybe not possible on this hardware "AMD A10-6800K APU with Radeon(tm) HD Graphics".
In single user mode, I used the kexec-load-kernel script from kexec-tools 1:2.0.29-2. That appears to work.
In the /etc/init.d/reboot script I've tried both kexec -e just before the reboot -d -f ${netdown} line and also:
reboot -d -f -k ${netdown}
which is supposed to attempt a kexec load.
Still getting a hardware reboot.
Is anyone successfully using kexec on x86_64 architecture?
#5 2025-01-01 02:20:34
mirrortokyo
PS, on my old machine (Pentium 4 with Radeon CEDAR discrete GPU), I was able to successfully kexec via:
kexec-load-kernel
then edited /etc/init.d/reboot to add the -k option to the reboot command line:
and just selected reboot from the lxdm desktop login screen.
#6 2025-01-01 06:55:57
mirrortokyo
From what I could find on lore.kernel.org and past discussion on irc with AMD developers, the in-built GPU in APU's and newer amdgpu-using discrete GPU's have issues getting into the correct state from a kexec restart.
