#1 2021-09-06 14:40:36
mu
[SOLVED] no highlight of todays date in cal
I know this seems awfully petty. The cal command (with no arguments) produces a calendar but today's date is not highlighted. This happens both in urxvt under X and from the console.
man cal says -h Turns off highlighting of today, but cal doesn't recognize -h:
% cal -h        :(
Usage: cal [general options] [-jy] [[month] year]
       cal [general options] [-j] [-m month] [year]
       ncal -C [general options] [-jy] [[month] year]
       ncal -C [general options] [-j] [-m month] [year]
       ncal [general options] [-bhJjpwySM] [-H yyyy-mm-dd] [-s country_code] [-W number of days] [[month] year]
       ncal [general options] [-Jeo] [year]
General options: [-31] [-A months] [-B months] [-d yyyy-mm]
ncal does highlight today's date and -h does suppress it.
I am running chimaera and I installed it from the netinstall iso from 8/16. It is up-to-date. Just wondering if there is something else I should have installed.
Thanks!
#2 2021-09-07 02:37:32
durham
Re: [SOLVED] no highlight of todays date in cal
You made me curious. Ran cal in xterm. No highlight. Ran with -t, got the error message just as you did. Very odd.
edit: also running chimaera
A dangerous technology is one that is available only to an elite group  -- George M. Ewing, Analog, April 1977
#3 2021-09-07 11:28:42
#4 2021-09-07 11:46:30
mu
Thank you! Sorry I missed that in man cal.
#5 2021-09-07 12:56:19
I didn't find that in 'man cal'. It came from a bug report. The man page leads one to believe that those options work with cal. Not all of them do.
