#1 2021-05-02 17:03:39
angstrom
[SOLVED] Installing roundcube from beowulf-backports
The context: a fresh installation of Devuan Beowulf, the backports repository is activated.
For example, I can install emacs from backports unproblematically using the following command:
apt-get install emacs/beowulf-backports
Suppose that I follow the same strategy to install roundcube from backports:
apt-get install roundcube/beowulf-backports
This results in an error message saying that roundcube can't be installed because one of its dependencies, roundcube-core, can't be installed, which puzzles me.
However, if I try to install roundcube from backports using the command
apt-get -t beowulf-backports install roundcube
then it works!
Does anyone know why there is this difference?
#2 2021-05-02 21:51:45
Re: [SOLVED] Installing roundcube from beowulf-backports
From the man page:
-t, --target-release, --default-release
This option controls the default input to the policy engine; it creates a default pin at priority 990 using the specified release string.
Using /beowulf-backports doesn't change the default release so APT can only attempt to draw the dependencies from beowulf.
apt install roundcube/beowulf-backports roundcube-core/beowulf-backports roundcube-mysql/beowulf-backports
angstrom wrote:
I can install emacs
That's just a metapackage. Try
apt install -s emacs-nox/beowulf-backports
#3 2021-05-02 22:11:28
angstrom
From the man page:
Thanks. Ah, okay, I see, so in general, it would seem preferable to use -t, which means that I've been doing it wrong. :-(
angstrom wrote:
I can install emacs
At the same time, the emacs metapackage did pull in the intended emacs version (27.1) from backports, which is why I thought that
did what I thought that it did. In other words, in the case of emacs,
seemed to me to do what
apt-get -t beowulf-backports install emacs
would have done (but it probably didn't do exactly the same thing after all).
#4 2021-05-03 10:05:26
angstrom
Just to qualify this statement (that I made), I guess that there are situations where you would want to install package X from backports while minimizing other changes to your existing setup, in which case
apt-get install X/beowulf-backports
would be the better strategy. However, the risk with this strategy (as I found out), particularly if X has a number of dependencies, is that one of the dependencies (which is not installed from backports) is too old or isn't fully compatible with X from backports.
This is why the safest strategy would be to install X from backports using
apt-get -t beowulf-backports install X
