#1 2021-04-26 19:54:02
devujan
Badly missing uswsusp in chimaera
I set up an nice FDE laptop with chimaera (AMD 4700U working out of the box) - but I can not suspend chimaera.
Suspend works in principle somehow - but how do I unload and reload the realtek modules and how do I stabilize the graphic system?
After suspend the machine sometimes "freezes" and loses network connection - all erratically.
With uswsusp I was able to solve these problems in ascii and beowulf....
Are there newer, better tools in place, to help with suspend - or has just the only really working tool been abandoned?
#2 2021-04-26 20:28:37
Marjorie
Re: Badly missing uswsusp in chimaera
I can't speak about Chimaera, as I'll stick with stable/Beowulf, but at some point in my migrations I found I could no longer get uswusp to work but found that kernel suspend works OK.
I use pm (pm-utils package, pm-suspend or pm-hibernate commands) to suspend and hibernate and this has options for the power down methods:
#   kernel    The built-in kernel suspend/resume support.
#                 Use this if nothing else is supported on your system.
#   uswsusp   If your system has support for the userspace
#                 suspend programs (s2ram/s2disk/s2both), then use this.
#   tuxonice  If your system has support for tuxonice, use this.
You can also specify suspend and resume modules in the config (/etc/pm/config.d/defaults). I do this for my wireless ath9k modules as otherwise my atheros wireless card doesn't power down.
You'll also need a resume=[swap partition] parameter in your grub's linux /boot/vmlinuz line if you use hibernate.
Of course they may have removed pm-utils in Chimaera, which would mean I'd have problems upgrading too.
#3 2021-04-27 15:32:09
Is the AMD graphics firmware installed? The µcode package should also be installed but I'm not sure if there are any fixes for the Ryzen 4000 series yet.
#4 2021-05-04 16:24:55
devujan
The the AMD graphics firmware is installed and AMD Graphics works from the very start beautifully.
I guess I have to give GRUB_CMDLINE_LINUX in /etc/default/grub a closer look and have check for pm scripts to remove and reinsert kernel modules.
My problem is that my wife is using that particular notebook very productive in school now - and I have to wait for a timeslot to tackle that issue.
I'll report any news here.
