#1 2020-03-30 14:53:20
shiztivr
Issues with Broken Packages and Updating
I am testing out Devuan 2.1 ASCII on a virtual machine.
I installed it from the Installer ISO via Expert Install with full disk encryption.
I did NOT install any non-free software and I installed OepnRC as my init software.
Upon my first bootup, I tried to update the OS through the terminal but got this error message (at the very bottom of the code down here).
johndoe@devuan:~$ sudo apt-get update && sudo apt-get upgrade
Ign:1 cdrom://[Devuan GNU/Linux 2.1 (ascii) amd64 DVD1 - 2019-12-21 07:24:54 UTC] ascii InRelease
Ign:2 cdrom://[Devuan GNU/Linux 2.1 (ascii) amd64 DVD1 - 2019-12-21 07:24:54 UTC] ascii Release
Ign:3 cdrom://[Devuan GNU/Linux 2.1 (ascii) amd64 DVD1 - 2019-12-21 07:24:54 UTC] ascii/contrib all Packages
Hit:4 cdrom://[Devuan GNU/Linux 2.1 (ascii) amd64 DVD1 - 2019-12-21 07:24:54 UTC] ascii/contrib amd64 Packages
Ign:5 cdrom://[Devuan GNU/Linux 2.1 (ascii) amd64 DVD1 - 2019-12-21 07:24:54 UTC] ascii/contrib Translation-en
Ign:6 cdrom://[Devuan GNU/Linux 2.1 (ascii) amd64 DVD1 - 2019-12-21 07:24:54 UTC] ascii/contrib Translation-en_GB
Ign:7 cdrom://[Devuan GNU/Linux 2.1 (ascii) amd64 DVD1 - 2019-12-21 07:24:54 UTC] ascii/main all Packages
Hit:8 cdrom://[Devuan GNU/Linux 2.1 (ascii) amd64 DVD1 - 2019-12-21 07:24:54 UTC] ascii/main amd64 Packages
Ign:9 cdrom://[Devuan GNU/Linux 2.1 (ascii) amd64 DVD1 - 2019-12-21 07:24:54 UTC] ascii/main Translation-en_GB
Ign:10 cdrom://[Devuan GNU/Linux 2.1 (ascii) amd64 DVD1 - 2019-12-21 07:24:54 UTC] ascii/main Translation-en
Hit:11 cdrom://[Devuan GNU/Linux 2.1 (ascii) amd64 DVD1 - 2019-12-21 07:24:54 UTC] ascii/non-free amd64 Packages
Ign:12 cdrom://[Devuan GNU/Linux 2.1 (ascii) amd64 DVD1 - 2019-12-21 07:24:54 UTC] ascii/non-free all Packages
Ign:4 cdrom://[Devuan GNU/Linux 2.1 (ascii) amd64 DVD1 - 2019-12-21 07:24:54 UTC] ascii/contrib amd64 Packages
Ign:13 cdrom://[Devuan GNU/Linux 2.1 (ascii) amd64 DVD1 - 2019-12-21 07:24:54 UTC] ascii/non-free Translation-en_GB
Ign:8 cdrom://[Devuan GNU/Linux 2.1 (ascii) amd64 DVD1 - 2019-12-21 07:24:54 UTC] ascii/main amd64 Packages
Ign:14 cdrom://[Devuan GNU/Linux 2.1 (ascii) amd64 DVD1 - 2019-12-21 07:24:54 UTC] ascii/non-free Translation-en
Ign:11 cdrom://[Devuan GNU/Linux 2.1 (ascii) amd64 DVD1 - 2019-12-21 07:24:54 UTC] ascii/non-free amd64 Packages
Hit:15 http://deb.devuan.org//merged ascii InRelease
Hit:16 http://deb.devuan.org//merged ascii-security InRelease
Hit:17 http://deb.devuan.org//merged ascii-updates InRelease
Hit:18 http://deb.devuan.org//merged ascii-backports InRelease
W: The repository 'cdrom://[Devuan GNU/Linux 2.1 (ascii) amd64 DVD1 - 2019-12-21 07:24:54 UTC] ascii Release' does not have a Release file.
N: Data from such a repository can't be authenticated and is therefore potentially dangerous to use.
Building dependency tree
Calculating upgrade... Done
  linux-image-amd64
0 upgraded, 0 newly installed, 0 to remove and 1 not upgraded.
In case you're wondering, I got my ISO image from this mirror.
https://mirror.leaseweb.com/devuan/
I tried installing some apps but I got an error message in the Synpatic Package Manager saying "Could not apply changes! Fix broken packages first.".
So I tried to fix the broken package in question, which was firejail-profiles, but then I got another error...
An error occurred.
The followin details are provided:
E:Unable to correct problems, you have held broken packages.
E:Error, pkgProblemResolver::Resolve generated breaks, this may be caused by held packages.
#2 2020-03-30 18:04:59
Re: Issues with Broken Packages and Updating
Disable the cdrom repository and enable the following repos:
deb http://deb.devuan.org/merged ascii          main
deb http://deb.devuan.org/merged ascii-updates  main
deb http://deb.devuan.org/merged ascii-security main
You can either do it in Synaptic or manually edit /etc/apt/sources.list. Then update/refresh the package cache.
