#1 2019-06-24 10:21:25
Luddit
[SOLVED] FRESH INSTALL Dev1 (ASCII) and XFCE - Thunderbird
Hello,
i have a fresh installed ASCII - and i put back my Thunderbird Profil. I have 2 Browser installed (FF & Chromium)
I go to the XFCE Setting and set a Default Browser (I have test whit bit both!) At the Moment is Chromium my Default. Also in
update-alternatives --config gnome-www-browser
  Auswahl      Pfad                  Priorität Status
  0            /usr/bin/firefox-esr   70        automatischer Modus
* 1            /usr/bin/chromium      40        manueller Modus
  2            /usr/bin/firefox-esr   70        manueller Modus
and
xdg-settings get default-web-browser
chromium.desktop
I Search arround in TB Forum et'all
As a Workarround i make me a user.js File - I also make a empty / new Profile - no Link was working?!
But, nothing helps
TB can't open a Link anymore....
Any Idea?
"If you think technology can solve your problems you don't understand technology and you don't understand your problems." Bruce Schneier
#2 2019-07-01 08:13:30
Luddit
Re: [SOLVED] FRESH INSTALL Dev1 (ASCII) and XFCE - Thunderbird
Install new DEV1
Set up new Profil TB
Set up new Profil FF
Import yo Data ...
#mozzsucks :-(
