#1 2018-10-25 14:26:07
basati
a mirror how much space do you need?
Only with the amd64 branch, how much?
Gora gu ta gutarrok
8=þ
#2 2018-10-25 15:02:11
GNUser
Re: a mirror how much space do you need?
I have a local mirror of ASCII amd64. It requires 1.4 GiB for the devuan-specific packages, 57 GiB for packages that are used as-is from Debian Stretch.
It's up to you if you want to include the packages that are used from Debian as-is in your mirror or not. Details here:
https://pkgmaster.devuan.org/devuan_mir … hrough.txt
HTH,
Bruno
