#1 2017-07-29 00:25:29
mtbvfr
[Solved] sha256 Checksum does not match
Hi All,
I just downloaded devuan_jessie_1.0.0_amd64_uefi_desktop-live.iso and the sha256 Checksum that was generated was the following.
4b359ea21f4798b0e6a00b154a202fdc2b61fc97846e824bbcf8d3c9db36cea7  devuan_jessie_1.0.0_amd64_uefi_desktop-live.iso
The Checksum, listed in the SHA256SUMS file that I downloaded, says the following.
65492da45f5def8b99d09d3fb5246eb1e21bddf490cc7efe3287ac770b665748  devuan_jessie_1.0.0_amd64_uefi_desktop-live.iso
I mounted the iso in Thunar and the structure appears correct. It was mounted with a label of ISOIMAGE.
Can someone confirm that the correct Checksum is what I generated in Terminal?
Thanks, MTB.
#2 2017-07-29 00:52:24
Re: [Solved] sha256 Checksum does not match
It starts with 65492d here. You should download it again.
#3 2017-07-29 01:16:26
mtbvfr
Ok, the checksum is ok this time.
The previous download produced a slightly smaller file but I didn't get any notification that the download had failed in anyway.
So, let's see how it boots up etc.
