#1 2017-07-27 17:14:57
γραφω λογον
[SOLVED] Suspend on Thinkpad T420
Okay, I give up.
My T420 has a bad case of insomnia or something. I've gotten suspend to work just fine on my X200 tablet that has no DE, just flux,JWM, and Awesome.  There was nothing to do with my T43 that has E17 because suspend worked out of the box.
I either can't remember what I did with the X200 tablet or else I need to do something different with the T420. It has MATE as well as all my favourite window managers that I also have on the X200.
Does anybody here have any ideas? Can you point me in the right direction?
TIA
My English is still a work in progress; no offense was intended.
#2 2017-07-28 15:05:08
Re: [SOLVED] Suspend on Thinkpad T420
I got suspend to work great in both Mate and Openbox, in my case system always had the capability, it was just some programs asking it wrong and others refusing to try.
I installed Obsession, it's just a simple shutdown program for Openbox, but it works great in Mate too, it has a gui but you can also use the cli portion by invoking various obsession-exit commands, I tied them to keyboard shortcuts to make it super easy, so to suspend on my machine I just hit alt+s .
FYI the Mate power manager doesn't do much of anything really, the xfce4 power manager works in any DE and still includes suspend and hibernate functions which the Mate PM does not.
#3 2017-07-28 22:38:12
γραφω λογον
That works. Much obliged. smile
