#1 2026-09-09 18:13:41
acogia
[SOLVED] Login with Links2 browser
Login with Links2 browser gets forwarded back to the register page.
Pale Moon, with javascript disabled, works ok.
Is this an HTML5 problem (Links2 doesnt 'see' some HTML5 code)?
Or is there a workaround for this, coz I use Links2 as my primary/only browser on my bare-bones OS
Thoughts? Suggestions?
All sigs are tedious after one read, including this one.
#2 2026-09-09 20:13:33
acogia
Re: [SOLVED] Login with Links2 browser
Fix #1 = Allow cookies in Links2 (had this set to no)
Fix =2 = Ignore the forwarding link and just select Index
Now logged in and can post.
Ta-daaah! smile
#3 2026-09-09 21:28:02
Thanks for figuring that out! I am sure someone will benefit from your findings.
#4 2026-09-10 22:16:46
acogia
Bonus! :)
