#1 2026-05-11 19:41:54
soulstenance
New to Devuan
As a long time Debian user and former Linux Mint user, I finally decided to give Devuan a try, as I face the reality of Debian 12's stale package base. I love that there are still distros that care about user choice, even in something as obscure as our choice of init. The fact that I can change file manager, text editor or even my whole DE but I can't choose a different init without the entire system collapsing on itself is kind of wild to me. Alas, I am preaching to the choir.
First impressions of Devuan are very good. I was unsurprised, (yet still disappointed) that 3rd party repos like ProtonVPN are DOA, since it's built with a hard systemd dependency. It could probably be fixed but that's likely a low priority for them. I went ahead with a manual wireguard setup which they have a decent setup guide for and it worked exactly as on Debian. Hopefully Mozilla's repo works but I haven't tried it yet. (I want a current Firefox, but I refuse to use a Flatpak browser.)
I went with Cinnamon, one of my favorite desktops from the amazing Mint team and it mostly seemed ok but the time was broken in the GUI. I couldn't set it, nor enable network time, probably due to using a systemd component. I don't know if the cinnamon package slipped through the cracks or if systemd is so deeply ingrained that patching it is infeasible for the Devuan team. At any rate, I did more or less fix it by manually installing chrony and configuring NTP that way. GUI remains broken but at least displays the right time as long as I have internet. It does fall back to a bad time without a network but that might be a VM issue.
In any case, I'm really enjoying Devuan so far and look forward to finding out all the little ways I was secretly reliant on systemd's bloated mess. As a Debian user, I deeply value privacy and security and I love that Devuan prioritizes user control and transparency on top of that security-first philosophy. smile
#2 2026-05-11 22:07:14
Re: New to Devuan
Welcome aboard, soulstenance!
#3 2026-05-12 09:34:27
Robin
Re: New to Devuan
Welcome!
The good folks here have been very helpful for this newbie (to Devuan) so far.
#4 2026-05-12 10:06:45
Re: New to Devuan
soulstenance wrote:
... but the time was broken in the GUI. I couldn't set it, nor enable network time, probably due to using a systemd component.
Its not the fault of Cinnamon nor a systemd influence. The package gnome-system-tools* is broken, and this for at least 4 years already. Don't try to use the gui, you can easily make it work on the console.
To be installed: ntpsec, ntpsec-ntpdate and ntpsec-ntpdig. Configuration in /etc/ntpsec/ntp.conf.
* gnome-system-tools is a Debian package w/o systemd dependency. The maintainer got lost somewhere in the Ukrainian planes, and there seems to be no replacement.
#5 2026-05-12 21:03:13
soulstenance
Re: New to Devuan
rolfie wrote:
Its not the fault of Cinnamon nor a systemd influence...
Thanks for the info, I will give that a try! In my VM I went with chrony which seemed to mostly do the trick. I thought cinnamon might be using timesyncd or something, but glad it's not a systemd issue, that makes it (hopefully) easier to fix.
Appreciate the welcome and the help I got from a certain wizard wink when I made some mistakes during registration. I hope to find some ways to contribute soon, however I can.
#6 2026-05-12 21:27:32
Re: New to Devuan
Well, chrony is an alternative. I am used to ntp(sec) ...
#7 2026-05-14 14:29:10
NakedRider
Re: New to Devuan
Welcome!
Try this link to add Firefox. Scroll down to where there is a black background and follow the steps in order using cut and paste.
https://idroot.us/install-firefox-browser-debian-13/
Instant current Firefox plus it is upgraded with your normal upgrade process.
#8 2026-05-14 23:42:40
soulstenance
Re: New to Devuan
Thanks!
Yep, method one is what used on Debian 12 and I imagine it should work the same on Devuan. Worst case, I have to do a manual install, or stick with ESR, which is fine. I used to hate ESR since streaming DRM content was broken/unsupported, but I don't stream anymore so that's irrelevant.
