#1 2026-04-20 17:13:27
Daemonratte
GTK2 Revival thread
Alright, I decided to pause the Seamless Devuan Project for a moment and fix gtk2.
Here is the repo:
https://git.devuan.org/Daemonratte/gtk2-ng
I added the two patches that the AUR maintainers apply to gtk2, implemented stefan11111's g_qsort_with_data to g_sort_array modernisation and fixed all the compiler warnings so you can compile it on a modern system.
Tested both gcc 14 and clang 21 (and leafpad)
Future plans:
Backport further improvements by stefan11111's (a famous Xlibre contributer)
Backport new features from Ardour's gtk2 fork ytk (without breaking ABI
Getting rid of errors and bugs
Test compiling with gcc 15
Find another name?
Change the license to gpl3 if possible (probably not)
Please test it and report any errors to me
Edit:
Here are build instructions (for installing it on the system:
touch README
autoreconf -fvi
./configure --prefix=/usr --sysconfdir=/etc --localstatedir=/var --with-xinput=yes
make -j"$(nproc)"
sudo make install
if you only want to test it, only use
./configure --prefix=/TESTDIR --with-xinput=yes
make -j"$(nproc)"
make install
and change TESTDIR to another location
#2 2026-04-21 19:06:24
Re: GTK2 Revival thread
If I run into any when using it.
But I tend not to use gtk2 as much on my devuan install, except maybe for palemoon.
#3 2026-04-29 23:51:18
brocashelm
Figured I'd bump this, what with lots of media outlets reporting on this new fork. Most of the discussions are taking place at the Devuan Users Forum (an unofficial community for Devuan and other non-Systemd GNU/Linux and *BSD users) here.
Phoronix and even DistroWatch.com have already reported on this. Bryan Lunduke has also posted his video on this.
#4 2026-04-30 07:32:39
blackhole
Devuan Users Forum
So, history often repeats itself...
#5 2026-04-30 14:59:54
blackhole: Yes. And in this case, that is not a bad thing. wink
#6 2026-05-16 07:40:58
brocashelm
Thanks to SteveM, there are now unofficial packages for Daedalus and Excalibur users in this repository. Keep in mind that the naming decision is still in progress (i.e. we are not calling it the "Devuan ToolKit"), where you can vote in a poll for which one you like the most. It could still work out with DTK (if it comes down to that), with the D standing for something else other than Devuan out of careful consideration.
#7 2026-05-16 16:20:20
Also a test iso available with it pre-installed and compiled, it's not installed system-wide as a replacement but as an alternate set of libraries you can run gtk2 apps against and be able to compare both side-by-side.
https://sourceforge.net/projects/vuu-do … g-testing/
#8 2026-05-21 04:05:23
brocashelm
There are now efforts to improve the filepicker with things like thumbnailing without a file manager pointed to the directory already, tooltips, image previews, and basic UI context menu goodness.
As well on SteveM's git repository, the dependency conflict with gir1.2-gtk-2.0 to also keep stuff like Dia around has been fixed, and can be installed alongside gir1.2-dtk.
Get the Daedalus DEBs below:
amd64 | i386
Get the Excalibur DEBs below:
amd64
