#1 2026-03-07 10:06:31
SS
[SOLVED] Accidental Success: Revived 2008 Toshiba with Devuan 6 & AI (Non-Tech)
Hello
I am a home user with zero technical background. When Windows 10 support ended, I asked an AI for a Linux recommendation to save my 15-year-old laptop. It suggested Devuan 6 Excalibur. At the time, I didn't even know what "Init Freedom" meant—I just wanted a computer that worked.
I chatted to others who said it will be a "difficult". They told me get something "modern" with a slick GUI like Ubuntu with Gnome as will be way easier to set up.
But after a 4-day "crash course" using AI as my private tutor, I’ve built a system that seems to work nicely.
The Hardware:
Model: Toshiba Satellite A300-1BZ (2008)
RAM: 4GB / SSD: Crucial MX300
WiFi: Intel Ultimate N 6300 (Replacement)
OS: Devuan 6 Excalibur (XFCE)
The AI-Guided Journey (4 Days of "Hard Mode"):
Since I didn't know what terminal was and was thinking oh no do I have to use this thing??! I decided to try it anyway and used AI to bridge the gap.
In just a few days, I learned to use chmod for permissions, top for process monitoring, and pstree to understand the system flow.
We implemented:
*WiFI Fixes:  I discovered the intel-microcode was being blacklisted by default. Removing the intel-microcode-blacklist.conf was essential for CPU stability. Used modprobe configs to stop Intel WiFi dropouts, I had to write scripts to keep USB ports "UP" so my Bluetooth stayed connected. Kept getting errors as well solved by custom scripts to rc.local to handle "kernel 110 timeouts". Had to create coexistence scripts and disable "11n" for wifi
*Audio: Replaced Blueman with bluetoothctl commands for crystal-clear audio (With blueman it kept asking for a pin when pairing to google home speakers. Bluetoothctl after some setup resolved that).
*Printing: Set up my Epson ET-2850 via a manual IPP connection and a "ping" script to ensure it wakes up on the 2.4GHz band.
*Modern Sync & Storage: Confirmed the Filen .deb works perfectly for 2-way cloud syncing.
*The "Safety Net" Launchers: I created XFCE launcher buttons for updates: (apt update/upgrade/ full upgrade), Flatpak updates, system cleanups, and SSD health checks (using smartctl). The update and clean up scripts include y/n prompts for review and a warning to run a Timeshift backup before any major changes (I didn't know what timeshift or system backups were but I do now!)
*Safety: Firewall set up (never knew what that was); firefox is firejailed and Vpn.ac gui client works (I tested it for dns leaks and kill switch - vpn.ac guys were very helpful)
*SSD Trim: Configured Anacron to handle SSD TRIM every two weeks (AI noticed Devuan didn't auto-trim the full drive initially).
The Result:
Efficiency: I have ~1.6GB of RAM free while streaming music with extra firefox tabs open and LibreOffice open.
Pstree showed only 1 active process during the stream. I kept asking AI if that was correct... couldn't believe it.
Speed: My Bluetooth connects faster and clearer than it ever did on Windows. My printer connects in 30 seconds from start up. No printing problems at all now. Never was that fast on windows and always had connection issues time to time.
Control: I went from being annoyed by forced Windows updates and unfixable crashes to having a system where every action is a script I can read and control (of course AI helps)
Conclusion:
I might have stumbled into Devuan by accident, but I’m staying on purpose. I didn’t need to be super technical to build a professional-grade, disaster-proof system—I just needed a curious mind and AI help. I finally feel like I actually own my computer instead of just being a passenger in it and learned something.
To the developers: thank you for keeping this "obsolete" hardware out of the landfill. It’s blazing fast.
This report maybe of use or not...sharing just incase
#2 2026-03-07 10:28:22
Duke Nukem
Re: [SOLVED] Accidental Success: Revived 2008 Toshiba with Devuan 6 & AI (Non-Tech)
Well done. That is quite something for someone "with zero technical background".  I've been using Linux for 20 years and Devuan for 10, but I had never even come across pstree - Linux has many, many, different ways of doing things.
#3 2026-03-07 10:35:43
Welcome to freedom for you & your computer.... big_smile
#4 2026-03-07 11:14:22
SS
Thank you.
Re pstree,....the AI agent suggested to run that and share it so it could analyse the flow. Then would suggest a fix for an issue, i would try it, (after I would ask for pros/cons to ensure safe), then re share the pstree output for verification. After doing that cycling got into the flow. I'll confess I nearly gave up as ended up in rabbit holes. Got there in the end
#5 2026-03-07 17:44:02
Pretty sure that's not how that works, I believe it's there to stop the microcode from trying to update itself on every boot. But I could be wrong.
https://www.reddit.com/r/debian/comment … acklisted/
https://salsa.debian.org/kernel-team/li … config#L42
This is with the blacklist.conf file still in place:
root@devuan:/home/jack# dmesg | grep "microcode updated early to"
[    3.943872] microcode: microcode updated early to new patch_level=0x05000119
You can see it's been applied in early stage boot despite the blacklist file.
Don't believe everything AI tells you. wink
Can anyone confirm?
Essentially it's baked into initramfs alongside the other firmware, when you install new firmware the system runs update-initramfs and gens a new initrd.img, so the code is there and gets applied early in boot. The blacklist just stops subsequent attempts to update.
At least that's my understanding of it.
#6 2026-03-07 23:54:38
Indeed, that is what I understood.
Blacklisting probably has the added effect of keeping rogue agents from doing it.
#7 2026-03-08 12:41:50
SS
Thank you for the words of wisdom. I  ran dmesg | grep microcode and it shows: microcode: Updated early from: 0x0000060c. Interestingly, dmesg still reports: MDS: Vulnerable: Clear CPU buffers attempted, no microcode. I suspect the AI saw that 'Vulnerable' warning and we went down a bit of a rabbit hole trying to 'fix' an unfixable hardware limitation of this 2008 chip?
Still learning, but I'm glad I checked the logs. I'll revert the blacklist file now."
#8 2026-03-08 20:18:08
You are most welcome sir! But I must beg your pardon, I had completely forgotten my manners so let me rectify:
A very warm welcome to you, to the worldwide community that is Linux! And most especially to Devuan which for 10 years running has been the best of Linux'es in my humble opinion. wink And kudos for a very innovative way to use AI to ease the transition too, nice work all around!
#9 2026-03-11 08:28:05
SS
Thank you for the warm welcome and encouragement. Kind regards
#10 2026-03-17 12:24:44
tyder
Welcome, and congratulations!!!!
I think using AI is essential, but I have already seen several examples of such rabbit holes. We maybe could think of the current language models as generating advice not out of understanding but as good guesses of what knowledgeable persons could say. Therefore, we have to test at every step, only keeping modifications that make a difference - preferably understandable to us ;-)
#11 2026-03-17 13:31:07
tyder wrote:
I think using AI is essential, ...
I don't trust any AI, I try to use my Brain 1.0.
#12 2026-03-17 14:38:27
Andre4freedom
Totally agree wink
#13 2026-03-17 15:52:41
tyder wrote:
I think using AI is essential . . .
I beg to disagree. The "essentials" are food, water, air and hopefully shelter. All the toys we play with are just the products of churning, deluded minds. And what a mess we make of it!
#14 2026-03-17 15:54:28
tyder
Who talked about trusting AI?
I don't really trust any of the equipment I use. It's essential for me nonetheless.
#15 2026-03-17 15:57:01
tyder
I beg to disagree. The "essentials" are food, water and hopefully shelter. All the toys we play with are just the products of churning, deluded minds. And what a mess we make of it!
OK. I promise not to talk about AI use at all.
In return, please don't ask how I got the results that fast.... ;-)
#16 2026-03-17 16:01:02
And we stupidly and willingly followed the breadcrumbs because we were so entranced by all the toys . . .
