#1 2017-07-01 20:13:13
yeu
How to get involved
Hi All,
I just switched to devuan, I'd like to help, but I don't find docs, or information on how to get involved.
Is there a policy or something?
Do you really need help? :-P
#2 2017-07-01 20:29:43
Re: How to get involved
Welcome yeu . . . There are lots of informative stickies posted on this forum: https://dev1galaxy.org/viewtopic.php?id=589
#3 2017-07-01 22:29:59
yeu
Thanks a lot!
#4 2017-07-01 23:01:04
yeu
For example, I tried to use apt-file. It doesn't work. I checked and the bug is registered but not solved.
I checked why it doesn't work. The problem is that the file:
merged/dists/jessie/main/Contents-amd64.gz
doesn't exist.
It should be created on the server. Where can I ask to create this file?
#5 2017-07-01 23:21:24
This is a long-standing issue from the way amprolla works.  Workaround is here:
https://dev1galaxy.org/viewtopic.php?id=519
(The search function on this forum works pretty well.  smile  )
