#1 2025-12-15 04:04:58
igorzwx
BlueALSA without systemd
BlueALSA is a Bluetooth audio ALSA backend that allows the use of Bluetooth-connected audio devices without the use of PulseAudio or PipeWire.
_https://wiki.debian.org/Bluetooth/Alsa
It's not entirely beyond the wit of the average person to compile BlueALSA without systemd and manage a basic init script.
Step 1: Compile libfreeaptx codec from git.
Step 2: Compile bluez-alsa from git.
Tested on Devuan 5 Daedalus:
$ inxi -Sxxx
System:
  Host: devuan Kernel: 6.1.0-41-amd64 arch: x86_64 bits: 64 compiler: gcc
    v: 12.2.0 Desktop: MATE v: 1.26.0 info: mate-panel wm: marco v: 1.26.1 vt: 7
    dm: LightDM v: 1.26.0 Distro: Devuan GNU/Linux 5 (daedalus)
Install compilers, packaging tools, and other useful utilities:
sudo apt-get install build-essential fakeroot git sed awk apt-file command-not-found
1. Compile libfreeaptx
Remove the  outdated version of libfreeaptx
apt --simulate remove freeaptx-utils libfreeaptx-dev libfreeaptx0
sudo apt remove freeaptx-utils libfreeaptx-dev libfreeaptx0
This will remove gstreamer1.0-plugins-bad and sayonara, if they are installed. You can reinstall them later if needed.
Create a build directory:
mkdir BUIL1 && cd BUILD1
Clone the repository:
git clone https://github.com/regularhunter/libfreeaptx.git
Compile:
$ cd libfreeaptx && make
Install to ../debdir, that is, BUILD1/debdir
$ make PREFIX=/usr DESTDIR="$(dirname $(pwd))"/debdir install
Go back to the BUILD1folder
$ cd .. && ls -1
debdir
libfreeaptx
Make a template to run dpkg-shlibdeps
mkdir debian && echo -e "Source: libfreeaptx\nPackage: libfreeaptx\nDepends: \${shlibs:Depends}" >> debian/control
Verify:
$ cat debian/control
Source: libfreeaptx
Depends: ${shlibs:Depends}
Run dpkg-shlibdeps to calculate dependencies
dpkg-shlibdeps -v -xlibfreeaptx -ldebdir/usr/lib --ignore-missing-info -e $(find debdir/usr -type f 2>/dev/null)
Check the dependencies calculated by dpkg-shlibdeps
$ cat debian/substvars
shlibs:Depends=libc6 (>= 2.34)
This means the Depends field in the DEBIAN/control file you're about to create should be:
Depends: libc6 (>= 2.34)
Now you can build the Debian package from debdir.
install -vm0755 -d debdir/DEBIAN
$ install -vm0755 -d debdir/DEBIAN
install: creating directory 'debdir/DEBIAN'
Create DEBIAN/control with a text editor
nano debdir/DEBIAN/control
$ cat debdir/DEBIAN/control
Version: 0.2.2
Architecture: amd64
Priority: optional
Section: libdevel
Source: libfreeaptx
Maintainer: Devuan
Installed-Size: 24.6 kB
Conflicts: freeaptx-utils, libfreeaptx-dev, libfreeaptx0
Provides: freeaptx-utils (= 0.2.2), libfreeaptx-dev (= 0.2.2), libfreeaptx0 (= 0.2.2)
Replaces: freeaptx-utils, libfreeaptx-dev, libfreeaptx0
Homepage: https://github.com/regularhunter/libfreeaptx
Tag: devel::library, role::devel-lib
Download-Size: 4,596 B
Description: Free implementation of aptX codec.
 libfreeaptx is based on version 0.2.0 of libopenaptx with the intent of
 continuing under a free license without the additional license restriction
 added to libopenaptx 0.2.1.
 This package contains the binaries, libraries, and header files for libfreeaptx.
Generate DEBIAN/md5sums
cd debdir && find . -type f -not -path "./DEBIAN/*" -exec md5sum {} + | sort -k 2 | sed 's/\.\/\(.*\)/\1/' > DEBIAN/md5sums
cd .. && chmod 0644 -- debdir/DEBIAN/md5sums
Build the Debian package
fakeroot -- dpkg-deb -b debdir libfreeaptx_0.2.2_amd64.deb
$ fakeroot -- dpkg-deb -b debdir libfreeaptx_0.2.2_amd64.deb
dpkg-deb: building package 'libfreeaptx' in 'libfreeaptx_0.2.2_amd64.deb'.
$ ls *.deb
Install
sudo dpkg -i libfreeaptx_0.2.2_amd64.deb
Re-install gstreamer1.0-plugins-bad and sayonara if needed
sudo apt install gstreamer1.0-plugins-bad sayonara
2. Compile bluez-alsa
Install Buid-Deps:
sudo apt install libfdk-aac-dev libasound2-dev libbluetooth-dev libdbus-1-dev libglib2.0-dev libsbc-dev liblc3-dev libldacbt-enc-dev libldacbt-abr-dev libmp3lame-dev libmpg123-dev libspandsp-dev libopus-dev libbsd-dev libreadline-dev check dbus-daemon python3-docutils pkgconf libudev-dev libell-dev
Clone the source and run autoreconf
mkdir BUILD2 && cd BUILD2
git clone https://github.com/arkq/bluez-alsa.git
cd bluez-alsa && autoreconf --install
mkdir ../build && cd ../build
Run the configure script from within the build directory:
"$(dirname $(pwd))"/bluez-alsa/configure --prefix=/usr --sysconfdir=/etc --with-bluealsaduser=bluealsad --enable-ldac --with-libfreeaptx --enable-aptx  --enable-aptx-hd --enable-faststream --enable-lc3-swb --enable-mp3lame --enable-mpg123 --enable-msbc --enable-ofono --enable-midi --enable-opus --enable-upower --enable-rfcomm --enable-a2dpconf --enable-hcitop --enable-test --enable-aac --enable-manpages --disable-systemd
Compile
make
Install to debdir
make DESTDIR="$(dirname $(pwd))"/debdir install
$ cd .. && ls -1
bluez-alsa
build
debdir
install -vDm0644 "$(pwd)"/bluez-alsa/LICENSE "$(pwd)"/debdir/usr/share/licenses/bluez-alsa/LICENSE
To run bluealsad daemon on Devuan, you need a simple init script
mkdir -vp debdir/etc/init.d
nano debdir/etc/init.d/bluealsad
$ cat debdir/etc/init.d/bluealsad
### BEGIN INIT INFO
# Provides:          bluealsa
# Required-Start:    dbus $syslog $local_fs $remote_fs bluetooth
# Required-Stop:     dbus $syslog $local_fs $remote_fs
# Default-Start:     2 3 4 5
# Default-Stop:      0 1 6
# Short-Description: BlueALSA daemon
# Description:       Bluetooth ALSA audio daemon
### END INIT INFO
. /lib/lsb/init-functions
NAME=bluealsad
DESC="BlueALSA daemon"
DAEMON=/usr/bin/$NAME
PIDFILE="/var/run/$NAME.pid"
STORAGE_DIR="/var/lib/bluealsa"
USER="bluealsad"
COMMON_OPTS="--quiet --oknodo --pidfile $PIDFILE"
# Working configuration without low-quality HSP codecs
BA_OPTS="-S -p a2dp-source -p a2dp-sink -p hfp-ag -p hfp-hf -c sbc -c aac -c mp3 -c aptx -c aptx-hd -c faststream -c opus -c msbc -c lc3-swb -c ldac --aac-afterburner --aac-bitrate=320000 --aac-vbr"
# Ensure bluealsad user exists and has correct group membership
if ! id $USER >/dev/null 2>&1; then
    # Create user if it doesn't exist
    useradd -r -s /bin/false $USER
    usermod -a -G audio $USER
else
    # User exists, check if in audio group
    if ! id -nG $USER | grep -qw audio; then
    fi
fi
# Ensure storage directory exists with correct ownership
if [ ! -d "$STORAGE_DIR" ]; then
    mkdir -p "$STORAGE_DIR"
    chown $USER:$USER "$STORAGE_DIR"
    chmod 0700 "$STORAGE_DIR"
else
    # Directory exists, check ownership
    CURRENT_OWNER=$(stat -c "%U:%G" "$STORAGE_DIR")
    if [ "$CURRENT_OWNER" != "$USER:$USER" ]; then
    fi
fi
case "$1" in
  start)
    log_daemon_msg "Starting $DESC" "$NAME"
    start-stop-daemon $COMMON_OPTS --start --background \
        --make-pidfile --chuid $USER --exec $DAEMON -- $BA_OPTS
    log_end_msg $?
  stop)
    log_daemon_msg "Stopping $DESC" "$NAME"
    start-stop-daemon $COMMON_OPTS --stop --retry 5
    log_end_msg $?
  restart|force-reload)
    $0 stop
    $0 start
  status)
    status_of_proc $DAEMON "$NAME" || exit $?
    echo "Usage: $0 {start|stop|restart|force-reload|status}" >&2
    exit 1
esac
exit 0
Make it executable
chmod +x debdir/etc/init.d/bluealsad
Make a template
mkdir debian && echo -e "Source: bluez-alsa\nPackage: bluez-alsa\nDepends: \${shlibs:Depends}" >> debian/control
Source: bluez-alsa
Package: bluez-alsa
dpkg-shlibdeps -v -xbluez-alsa -ldebdir/usr/lib --ignore-missing-info -e $(find debdir/usr -type f 2>/dev/null)
shlibs:Depends=libasound2 (>= 1.1.7), libbluetooth3 (>= 4.91), libbsd0 (>= 0.0), libc6 (>= 2.34), libdbus-1-3 (>= 1.9.14), libfdk-aac2 (>= 2.0.1), libglib2.0-0 (>= 2.67.3), liblc3-0 (>= 1.0.1), libldacbt-abr2 (>= 2.0.2), libldacbt-enc2 (>= 2.0.2), libmp3lame0 (>= 3.100), libmpg123-0 (>= 1.28.0), libncurses6 (>= 6), libopus0 (>= 1.1), libreadline8 (>= 6.0), libsbc1 (>= 2.0), libspandsp2 (>= 0.0.6~pre18), libtinfo6 (>= 6)
Package: bluez-alsa
Version: 4.3.1-86
Architecture: amd64
Priority: optional
Section: utils
Source: bluez-alsa
Maintainer: Devuan
Installed-Size: 541 kB
Conflicts: bluez-alsa-utils, libasound2-plugin-bluez
Provides: bluez-alsa-utils (= 4.3.1-86), libasound2-plugin-bluez (= 4.3.1-86)
Replaces: bluez-alsa-utils, libasound2-plugin-bluez
Depends: libasound2 (>= 1.1.7), libbluetooth3 (>= 4.91), libbsd0 (>= 0.0), libc6 (>= 2.34), libdbus-1-3 (>= 1.9.14), libfdk-aac2 (>= 2.0.1), libglib2.0-0 (>= 2.67.3), liblc3-0 (>= 1.0.1), libldacbt-abr2 (>= 2.0.2), libldacbt-enc2 (>= 2.0.2), libmp3lame0 (>= 3.100), libmpg123-0 (>= 1.28.0), libncurses6 (>= 6), libopus0 (>= 1.1), libreadline8 (>= 6.0), libsbc1 (>= 2.0), libspandsp2 (>= 0.0.6~pre18), libtinfo6 (>= 6)
Homepage: https://github.com/Arkq/bluez-alsa
Description: Bluetooth Audio ALSA Backend (utils)
 Bluetooth Audio ALSA Backend allows bluetooth audio without PulseAudio and PipeWire.
 This package provides sysVinit script for bluealsad daemon to run it without systemd.
This project is a rebirth of a direct integration between Bluez and ALSA.
Since Bluez >= 5, the build-in integration has been removed in favor of 3rd
party audio applications. From now on, Bluez acts as a middleware between an
audio application, which implements Bluetooth audio profile, and a Bluetooth
audio device.
Make a Debian package
fakeroot -- dpkg-deb -b debdir bluez-alsa_4.3.1-86_amd64.deb
$ fakeroot -- dpkg-deb -b debdir bluez-alsa_4.3.1-86_amd64.deb
dpkg-deb: building package 'bluez-alsa' in 'bluez-alsa_4.3.1-86_amd64.deb'.
$ ls *.deb
Install
sudo dpkg -i bluez-alsa_4.3.1-86_amd64.deb
Configure the bluealsad service  to start automatically at system boot
sudo update-rc.d bluealsad defaults
Start the bluealsad service and check its status
sudo service bluealsad start
sudo service bluealsad status
If, for some strange reason, bluealsad fails to start, restart services in the correct order:
sudo service dbus restart
sudo service dbus status
sudo service bluetooth restart
sudo service bluetooth status
sudo service bluealsad restart
Or simply reboot the system to ensure all services start in the proper sequence.
3. Pair and connect Bluetooth headphones using the Blueman Manager
$ apt-cache show blueman | grep Recommends:
Recommends: pulseaudio-module-bluetooth
It will install pulseaudio and/or pipewire. if they are not pinned.
The magic command apt-mark hold can fix the problem
sudo apt-mark hold pulseaudio* pipewire*
sudo apt install blueman
  1. Put Headphones in Pairing Mode:
  • Turn on your headphones and press/hold the power or Bluetooth button until an indicator light flashes (usually blue/red), showing they are discoverable.
  1. Launch Blueman Manager:
   blueman-manager
  • Search for Devices:
  • In the Blueman Manager window, click the "Search" button (or magnifying glass icon) to scan for devices.
  • Pair the Headphones:
  • When your headphones appear, right-click the device name.
  • Select Pair. Confirm the pairing request if a prompt appears (often within 20 seconds).
  • Right-click again and select Trust so they connect automatically next time.
  • Connect and Set Audio Output:
  • Right-click the device in Blueman and choose Connect
You can do the same with bluetoothctl
bluetoothctl scan on
bluetoothctl pair XX:XX:XX:XX:XX:XX
bluetoothctl trust XX:XX:XX:XX:XX:XX
bluetoothctl connect XX:XX:XX:XX:XX:XX
TEST:
alsamixer -D bluealsa
aplay -D bluealsa /usr/share/sounds/alsa/Front_Center.wav
$ bluealsad --help | grep "Available BT profiles" -A20
Available BT profiles:
  - a2dp-source	Advanced Audio Source (v1.4)
  - a2dp-sink	Advanced Audio Sink (v1.4)
  - hfp-ofono	Hands-Free AG/HF handled by oFono
  - hfp-ag	Hands-Free Audio Gateway (v1.9)
  - hfp-hf	Hands-Free (v1.9)
  - hsp-ag	Headset Audio Gateway (v1.2)
  - hsp-hs	Headset (v1.2)
  - midi	Bluetooth LE MIDI (v1.0)
Available BT audio codecs:
  a2dp-source:	SBC, MP3, AAC, aptX, aptX-HD, FastStream, LDAC, Opus
  a2dp-sink:	SBC, MP3, AAC, aptX, aptX-HD, FastStream, Opus
  hfp-*:	CVSD, mSBC, LC3-SWB
$ bluealsactl status
Service: org.bluealsa
Version: v4.3.1-86-gf1e53d3
Adapters: hci0
Profiles:
  A2DP-source : SBC MP3 AAC aptX aptX-HD FastStream LDAC Opus
  A2DP-sink   : SBC MP3 AAC aptX aptX-HD FastStream Opus
  HFP-AG      : CVSD mSBC LC3-SWB
  HFP-HF      : CVSD mSBC LC3-SWB
Right, so not all Bluetooth codecs are supported by your headphones — it’s a bit of a mismatch, really. With the Sennheiser HD 450BT on Linux, you’re limited to SBC, AAC, and aptX, even if the device supports more in other ecosystems.
The bluealsactl output confirms this:
$ bluealsactl codec $(bluealsactl list-pcms | grep a2dpsrc | head -1)
Available codecs: SBC AAC aptX
Selected codec: aptX
You can switch to AAC manually:
bluealsactl codec $(bluealsactl list-pcms | grep a2dpsrc | head -1) aac
And verify:
Selected codec: AAC
Both aptX  and aptX-HD codecs support 16kHz, 32kHz, 44.1kHz, and 48kHz sample rates with BlueALSA.
The aptX-HD implementation in src/a2dp-aptx-hd.c includes:
  • Sample rate support for 16kHz, 32kHz, 44.1kHz, and 48kHz
  • 24-bit audio support
  • Encoder and decoder initialization functions
Tested with:
ASUS USB-BT540 Bluetooth 5.4 Dongle Adapter Compatible with Linux
Sennheiser HD 450BT
Specifications:
  • Bluetooth profiles: AVRCP, A2DP, HFP, HSP
  • Bluetooth Audio Codecs: AptX, AptX Low Latency, AAC, SBC
$ bluealsa-aplay -L
bluealsa:DEV=80:C3:BA:8B:B6:CC,PROFILE=sco,SRV=org.bluealsa
    HD 450BT, trusted audio-headphones, playback
    SCO (mSBC): S16_LE 1 channel 16000 Hz
    HD 450BT, trusted audio-headphones, capture
bluealsa:DEV=80:C3:BA:8B:B6:CC,PROFILE=a2dp,SRV=org.bluealsa
    A2DP (aptX): S16_LE 2 channels 48000 Hz
$ bluealsa-aplay -l
**** List of PLAYBACK Bluetooth Devices ****
hci0: 80:C3:BA:8B:B6:CC [HD 450BT], trusted audio-headphones
**** List of CAPTURE Bluetooth Devices ****
ALSA config for BlueALSA virtual PCM device
$ cat ~/.asoundrc
defaults.pcm.rate_converter "fftrate"
pcm.!default "bluealsa"
MPV Player config:
$ cat ~/.config/mpv/mpv.conf
ao=alsa
alsa-resample=yes
alsa-buffer-time=160000
alsa-periods=4
Celluloid:
  • Open the Preferences menu.
  • Go to the Miscellaneous tab.
  • Enter mpv command-line options into the "Extra MPV Options" text box:
ao=alsa alsa-resample=yes alsa-buffer-time=160000 alsa-periods=4
Audacious:
  • go to Preferences → Audio → Buffer size
  • set 2000 ms
Firefox
about:config
media.cubeb.backend                    alsa
media.resampling.enabled            false
media.cubeb_latency_playback_ms        160
TEST:
$ mpv *.dsf
 (+) Audio --aid=1 (dsd_lsbf_planar 2ch 1411200Hz)
Input:  1411200 Hz, 2 ch, 's16_le' (0x2): dummy = 0, period = 56448
Output: 48000 Hz, 2 ch, 's16_le' (0x2): dummy = 0, period = 1920
Rates:  1411200 --> 48000 (J: 0.00%, T: FFT, W: Vorbis)
Ok.
AO: [alsa] 1411200Hz stereo 2ch float
(Paused) AV: 00:00:30 / 00:04:35 (11%)
$ audacious 2>&1 *.dsf
Input:  1411200 Hz, 2 ch, 's32_le' (0xa): dummy = 0, period = 352800
Output: 48000 Hz, 2 ch, 's16_le' (0x2): dummy = 0, period = 12000
Ok.
$ MOZ_LOG="MediaDecoder:4,cubeb:5" stdbuf -oL firefox 2>&1 https://rutube.ru/video/4202a6f411ad55ea7f55e38f860e26bc/ | grep  --line-buffered -E "MetadataLoaded.*rate=|FirstFrameLoaded.*rate=|CubebStreamInit output stream rate|target rate|Output hardware|Input|Output|Rates" | grep -vE "hasVideo=0|hasAudio=0"
[Child 21800: Main Thread]: D/MediaDecoder MediaDecoder[7f5208797000] MetadataLoaded, channels=2 rate=44100 hasAudio=1 hasVideo=1
[Child 21800: Main Thread]: D/MediaDecoder MediaDecoder[7f5208797000] FirstFrameLoaded, channels=2 rate=44100 hasAudio=1 hasVideo=1 mPlayState=PLAY_STATE_LOADING transportSeekable=1
[Child 21800: MediaDecoderStateMachine #1]: I/cubeb CubebStreamInit output stream rate 44100
$ mpv 2>&1 rudra*
 (+) Audio --aid=1 (flac 2ch 44100Hz)
AO: [alsa] 44100Hz stereo 2ch s16
(Paused) A: 00:00:41 / 00:18:33 (4%)
It means that sample rate 44100Hz is indeed supported by aptX codec. That is why you do not see logs of fftrate, which is now the default ALSA resampler.
Buffer settings for aplayand arecord
aplay -F 40000 -B 160000 <.wav>
arecord -F 40000 -B 160000 <.wav>
$ aplay -F 40000 -B 160000 1_08*
Playing WAVE '1_08-Faust - Funeral March Of A Marionette - DSD256.dsf.wav' : Signed 32 bit Little Endian, Rate 1411200 Hz, Stereo
Input:  1411200 Hz, 2 ch, 's32_le' (0xa): dummy = 0, period = 56448
Ok.
Full duplex with mSBC  codec
$ arecord -F 40000 -B 160000 -D bluealsa:PROFILE=sco -V mono -f CD | aplay -F 40000 -B 160000 -D bluealsa:PROFILE=sco
Recording WAVE 'stdin' : Signed 16 bit Little Endian, Rate 44100 Hz, Stereo
Input:  16000 Hz, 1 ch, 's16_le' (0x2): dummy = 0, period = 640
Output: 44100 Hz, 1 ch, 's16_le' (0x2): dummy = 0, period = 1764
Rates:  16000 --> 44100 (J: 0.00%, T: FFT, W: Vorbis)
Ok.
Playing WAVE 'stdin' : Signed 16 bit Little Endian, Rate 44100 Hz, Stereo
Input:  44100 Hz, 1 ch, 's16_le' (0x2): dummy = 0, period = 1764
Output: 16000 Hz, 1 ch, 's16_le' (0x2): dummy = 0, period = 640
Rates:  44100 --> 16000 (J: 0.00%, T: FFT, W: Vorbis)
Ok.
#################################                 +| MAX
mSBC codec Playback/Capture devices:
**** PLAYBACK Bluetooth Device ****
**** CAPTURE Bluetooth Device ****
#2 2025-12-15 04:17:25
Re: BlueALSA without systemd
Note also that In excalibur bluez-alsa-utils provides bluealsa (without systemd dependency).
#3 2025-12-15 04:32:19
igorzwx
Can you post URL of the source package?
#4 2025-12-15 04:38:25
#5 2025-12-15 04:40:59
igorzwx
https://pkginfo.devuan.org/cgi-bin/poli … .68.126.15
An error occurred while reading CGI reply (no response received)
#6 2025-12-15 05:17:45
Yes try https://pkginfo.devuan.org/bluez-alsa-utils rather
(golinux' URL includes the AI bot distraction so it's not sharable)
#7 2025-12-15 05:29:53
igorzwx
It does not seem to contain any init script.
I have already enabled the stable repository:
$ apt source bluez-alsa-utils
Picking 'bluez-alsa' as source package instead of 'bluez-alsa-utils'
NOTICE: 'bluez-alsa' packaging is maintained in the 'Git' version control system at:
https://salsa.debian.org/bluetooth-team/bluez-alsa.git
Please use:
git clone https://salsa.debian.org/bluetooth-team/bluez-alsa.git
to retrieve the latest (possibly unreleased) updates to the package.
Need to get 257 kB of source archives.
Get:1 http://deb.devuan.org/merged stable/main bluez-alsa 4.3.1-3 (dsc) [2,528 B]
Get:2 http://deb.devuan.org/merged stable/main bluez-alsa 4.3.1-3 (tar) [249 kB]
Get:3 http://deb.devuan.org/merged stable/main bluez-alsa 4.3.1-3 (diff) [6,076 B]
Fetched 257 kB in 0s (764 kB/s)
dpkg-source: info: extracting bluez-alsa in bluez-alsa-4.3.1
dpkg-source: info: unpacking bluez-alsa_4.3.1.orig.tar.xz
dpkg-source: info: unpacking bluez-alsa_4.3.1-3.debian.tar.xz
The source package is from Debian repository, configured for systemd.
bluez-alsa-utils_4.3.1-3_amd64.deb
was compiled for systemd, it does not have any init script inside.
_https://pkginfo.devuan.org/cgi-bin/package-query.html?c=package&q=bluez-alsa-utils=4.3.1-3.1
Package: bluez-alsa-utils
Version: 4.3.1-3.1
Installed-Size: 521
Maintainer: Debian Bluetooth Maintainers <team+pkg-bluetooth@tracker.debian.org>
Content
/etc/alsa/conf.d/20-bluealsa.conf
/etc/default/bluez-alsa
/usr/bin/a2dpconf
/usr/bin/bluealsa-aplay
/usr/bin/bluealsa-cli
/usr/bin/bluealsa-rfcomm
/usr/bin/bluealsa
/usr/bin/hcitop
/usr/lib/systemd/system/bluealsa-aplay.service
/usr/lib/systemd/system/bluealsa.service
/usr/share/dbus-1/system.d/bluealsa.conf
/usr/share/doc/bluez-alsa-utils/changelog.Debian.gz
/usr/share/doc/bluez-alsa-utils/copyright
/usr/share/man/man1/bluealsa-aplay.1.gz
/usr/share/man/man1/bluealsa-cli.1.gz
/usr/share/man/man1/bluealsa-rfcomm.1.gz
/usr/share/man/man1/hcitop.1.gz
/usr/share/man/man8/bluealsa.8.gz
It should look like this:
In the git version, it is already renamed to "bluealsad"
#8 2025-12-15 05:48:41
I think bluealsa gets started via dbus, But I haven't explored it.
#9 2025-12-15 05:55:23
igorzwx
It was compiled with --enable-systemd   (see: debian/rules )
I have already recompiled the Debian source package.
It is outdated, and the codecs are outdated.
The git version is much better.
#10 2025-12-15 06:04:57
Thanks. Good advice. I'll probably look at doing that eventually.
(I'm not using my bluetooth headset much at the moment)
It could possibly be helpful to the debian maintainer of bluez-alsa-util to lodge a bug regarding outdated codecs. Especially if there is a patch included. I guess the packaging project is on salsa.debian.org.
#11 2025-12-15 06:11:14
igorzwx
What is the spec of your headset, is there something like this:
- Bluetooth codecs
- aptX™ Adaptive
  aptX™ HD
  aptX™
  AAC
  SBC
- Bluetooth profiles
- A2DP
  AVRCP
  HFP
Debian default is low quality SBC codec.
With aptX codec, sound quality is much better.
libfreeaptx is outdated in the oldstable
_https://tracker.debian.org/pkg/libfreeaptx
git version;
$ freeaptxdec --help
aptX decoder utility 0.2.2 (using libfreeaptx 0.2.2)
This utility decodes aptX or aptX HD audio stream
from stdin to a raw 24 bit signed stereo on stdout
the Debian source of bluez-alsa is outdated
_https://tracker.debian.org/pkg/bluez-alsa
The git version is now v4.3.1-86-gf1e53d3. It means that 86 bugs were fixed. In any case, everything was compiled.
All codecs available for Linux were compiled and enabled.
Adapters: hci0
Profiles:
hsp codecs are not loaded with init script. They are of low quality: 8kHz sample rate.
The question is: which codecs are supported by your BT headphones?
What is your spec?
Sennheiser HD 450BT does have aptX-HD, but it has aptX
Specifications:
$ bluealsa-aplay -L
Sennheiser HDB 630
_https://www.sennheiser-hearing.com/en-DE/p/hdb-630/
Specifications
Codec support
aptX™ Adaptive™, aptX™ HD, aptX™, AAC, SBC
Enjoy high resolution with support for aptX™ HD and aptX™ Adaptive, especially when paired with the included BTD 700 Bluetooth® USB C Dongle
For the purest signal, connect via USB C or analog input for lossless listening at up to 24 bit/96 kHz.
Bowers & Wilkins Px7 S2e Bluetooth Wireless Headphones
_https://www.bowerswilkins.com/en-gb/product/over-ear-headphones/px7-s2e/FP44520P.html#specifications
Specifications
Bluetooth codecs
aptX™ Adaptive
aptX™ HD
aptX™
AAC
SBC
SBC is a basic low quality codec.
aptX Adaptive is not available for Linux.
AAC in BlueALSA uses the fdk-aac library from Fraunhofer IIS, which is not completely free software.
The fdk-aac library is under Fraunhofer license which:
    Is free for non-commercial use
    Requires licensing for commercial applications
    Has patent encumbrances in some countries
You may try high quality options: --aac-afterburner --aac-bitrate=320000 --aac-true-bps
# without -c aptx -c aptx-hd
BA_OPTS="-S -p a2dp-source -p a2dp-sink -p hfp-ag -p hfp-hf -c sbc -c aac -c mp3 -c faststream -c opus -c msbc -c lc3-swb -c ldac --aac-afterburner --aac-bitrate=320000 --aac-true-bps"
AAC codec supports 8 kHz to 96 kHz including 44.1kHz and  48kHz.
While BlueALSA's automatic selection is limited to 48kHz, the codecs themselves support higher rates. For example, AAC supports up to 96kHz.
You can manually select higher sample rates using:
bluealsactl codec -r96000 PCM_PATH aac
Sennheiser HD 450BT does not support 96kHz sample rate with AAC codec, but it has analog audio cable with 3.5mm jack plug. It is much better than any Bluetooth codec.
#12 2025-12-15 12:03:41
igorzwx
There is, one might say, a slight oversight in the Debian bluez-alsa package: it runs as root, which is a bit like giving the keys to the house to someone just to borrow the kettle. Should a flaw exist — and history suggests they often do — it could be exploited with elevated consequences.
The good news? This doesn’t affect Devuan at all. The package simply doesn’t work without systemd, so it sits there, harmless and inert — like a very quiet paperweight.
So while Debian’s setup is perhaps more trusting than strictly necessary, Devuan users are, by design, not involved in the drama.
#13 2025-12-15 22:40:26
I guess you won't be interested but as you may know, the action path for Devuan would be for a maintainer to set up a fork project (at git.devuan.org) to sort out its utility in Devuan. I anyhow invite you to take on that role for this package (as well as fftrate packages if you like).
#14 2025-12-16 15:14:25
igorzwx
1. The package is not needed.
2. It is easy to compile.
The Devuan consumer community want to consume knowledge rather than packages. You should not keep them in ignorance.
Knowledge and only knowledge liberates, and absolute knowledge liberates absolutely.
Isaiah Berlin, Four Essays on Liberty (1969).
How to Create a Debian Package Release Bundle
Download sourcedir:
mkdir BUILD3 && cd BUILD3
cd bluez-alsa && export DEBFULLNAME="John Frum"
Install a template:
dh_make --createorig -p bluez-alsa_4.3.1-86 -c apache -e my@mail.org -s
1. debian/control
If you have libfreeaptx-dev installed, replace "libfreeaptx" with "libfreeaptx-dev" in Build-Depends. If you compiled libfreeaptx from git, leave it as is.
Source: bluez-alsa
Section: libs
Priority: optional
Maintainer: John Frum <my@mail.org>
Rules-Requires-Root: no
Build-Depends:
 debhelper-compat (= 13),
	dh-exec,
	libasound2-dev,
	libbluetooth-dev (>= 5.0),
	libdbus-1-dev (>= 1.6),
        libfdk-aac-dev,
	libfreeaptx,
	libglib2.0-dev (>= 2.30),
	libsbc-dev (>= 1.2),
	liblc3-dev,
	libldacbt-enc-dev (>= 2.0.0) [!hppa !m68k !powerpc !ppc64 !s390x !sparc64],
	libldacbt-abr-dev (>= 2.0.0) [!hppa !m68k !powerpc !ppc64 !s390x !sparc64],
	libmp3lame-dev,
	libmpg123-dev,
	libspandsp-dev,
	libopus-dev,
	libbsd-dev,
	libreadline-dev,
	check,
	dbus-daemon <!nocheck>,
	python3-docutils,
	pkgconf
Standards-Version: 4.6.2
#Vcs-Browser: https://salsa.debian.org/debian/bluez-alsa
#Vcs-Git: https://salsa.debian.org/debian/bluez-alsa.git
Package: bluez-alsa
Architecture: linux-any
Multi-Arch: same
Section: libs
Depends:
 ${shlibs:Depends},
 ${misc:Depends},
Provides: bluez-alsa-utils (= 4.3.1-86-1), libasound2-plugin-bluez (= 4.3.1-86-1)
 audio device.
2. debian/rules
$ cat debian/rules
#!/usr/bin/make -f
# See debhelper(7) (uncomment to enable).
# Output every command that modifies files on the build system.
#export DH_VERBOSE = 1
# See FEATURE AREAS in dpkg-buildflags(1).
#export DEB_BUILD_MAINT_OPTIONS = hardening=+all
# See ENVIRONMENT in dpkg-buildflags(1).
# Package maintainers to append CFLAGS.
#export DEB_CFLAGS_MAINT_APPEND  = -Wall -pedantic
# Package maintainers to append LDFLAGS.
#export DEB_LDFLAGS_MAINT_APPEND = -Wl,--as-needed
	dh $@ --with autoreconf
# dh_make generated override targets.
# This is an example for Cmake (see <https://bugs.debian.org/641051>).
#override_dh_auto_configure:
#	dh_auto_configure -- \
#	-DCMAKE_LIBRARY_PATH=$(DEB_HOST_MULTIARCH)
	dh_auto_configure --  --prefix=/usr --sysconfdir=/etc --with-bluealsaduser=bluealsad --enable-ldac --with-libfreeaptx --enable-aptx  --enable-aptx-hd --enable-faststream --enable-lc3-swb --enable-mp3lame --enable-mpg123 --enable-msbc --enable-ofono --enable-midi --enable-opus --enable-upower --enable-rfcomm --enable-a2dpconf --enable-hcitop --enable-test --enable-aac --enable-manpages --disable-systemd
override_dh_installinit:
	dh_installinit --name=bluealsad
override_dh_shlibdeps:
	dh_shlibdeps --dpkg-shlibdeps-params=--ignore-missing-info
3. debian/bluez-alsa.bluealsad.init
$ cat cat debian/bluez-alsa.bluealsad.init
cat: cat: No such file or directory
### BEGIN INIT INFO
### END INIT INFO
NAME=bluealsad
USER="bluealsad"
else
    fi
fi
else
    fi
fi
case "$1" in
  start)
    log_end_msg $?
  stop)
    log_end_msg $?
    $0 stop
    $0 start
  status)
    exit 1
esac
exit 0
chmod +x debian/bluez-alsa.bluealsad.init
Create Debian source package
dpkg-source -b .
Build Debian package
dpkg-buildpackage -us -uc
$ cd .. && ls -1 *.deb
bluez-alsa_4.3.1-86-1_amd64.deb
bluez-alsa-dbgsym_4.3.1-86-1_amd64.deb
Install
sudo dpkg -i bluez-alsa_4.3.1-86-1_amd64.deb
In bureaucratic terms, you have a complete Debian package upload set or package release bundle:
$ ls -1
bluez-alsa
bluez-alsa_4.3.1-86-1_amd64.buildinfo
bluez-alsa_4.3.1-86-1_amd64.changes
bluez-alsa_4.3.1-86-1.debian.tar.xz
bluez-alsa_4.3.1-86-1.dsc
bluez-alsa_4.3.1-86.orig.tar.xz
This includes:
Source files (.dsc, .orig.tar.xz, .debian.tar.xz)
Binary packages (.deb)
Debug symbols (.dbgsym.deb)
Build metadata (.buildinfo)
Changes file (.changes) — the key control file listing all others
The .changes file defines the full set, used by Debian archive tools (like dak) to process uploads into a repository.
$ sudo service bluealsad restart
Stopping BlueALSA daemon: bluealsad.
Starting BlueALSA daemon: bluealsad.
$ sudo service bluealsad status
bluealsad is running.
See also:
_https://dev1galaxy.org/viewtopic.php?id=7671
Ah, the --with-bluealsaduser=bluealsad option — very sensible. Lets you run the daemon as a dedicated user, which is ever so slightly less daft than letting it run as root. Keeps things tidy, limits the carnage if something goes wrong. Think of it as giving your Bluetooth audio a sensible hat and a laminated badge — still can’t stop it from misbehaving entirely, but at least it’s not running the whole show.
If you don’t specify a user, it defaults to root, which works — until it doesn’t. And when used with older BlueZ versions (≤ 5.50), just make sure your chosen user’s in the "bluetooth" group, or it’ll sulk and refuse to connect. Nothing dramatic — just typical Linux passive aggression.
#15 2025-12-16 16:12:30
I agree 100%, I think Igor would be the perfect candidate to maintain packages like fftrate.  He's certainly knowledgeable about all things ALSA, and you've already done the hard part for fftrate.
C'mon Igor, step up to the plate bro! Ralph's rolling out the red carpet for ya and Devuan is clearly onboard with all this amazing work being done in ALSA these days, we can all make a real difference in how sound is dealt with in Linux. big_smile
#16 2025-12-16 17:24:42
igorzwx
If nobody wants to maintain it, it's not needed.
If nobody can maintain it, it doesn't make sense.
Right, so the bluez-alsa packages in the official Devuan repository were built with --enable-systemd, which means they’ve picked up a systemd dependency — a bit of an oversight, really, given Devuan’s init-agnostic stance.
To address this, the packages were unpacked, the dependency manually adjusted, and then repackaged. They’ll install without complaint, though they might not function perfectly in the absence of systemd. It’s not ideal, but it’s a pragmatic fix.
The method used is a known workaround, documented here:
_https://dev1galaxy.org/viewtopic.php?id=7157
