#1 2025-09-12 22:45:24
evanescente~ondine
[SOLVED] devuan (fresh install) noticeably slow compared to debian
This is not a ragebait thread I swear. I like your project a lot and overall don't complain much.
And I'm sorry if this doesn't belong to this section since I use Sway, not X.
I see a noticeable loss in speed or liveness since I installed devuan, and it might or might not be specific to wayland, I'm not sure.
What kind of message should I be looking for ?
#2 2025-09-13 01:03:40
RedGreen925
Re: [SOLVED] devuan (fresh install) noticeably slow compared to debian
Well the way I read that is there is a lack of useful information. At the very least we need to know if the software installed is identical in both OSs. For that matter the OSs versions involved. The method of determining this "slowness" that you are using. Without those and many more details no one will be able to help you.
#3 2025-09-13 03:05:14
evanescente~ondine
What you ask is pretty much impossible to provide.
I verified: hardware acceleration is on (Intel Alderlake_n (Gen12).
Here's sway's complete log: https://pastebin.com/i221mjmx
I couldn't find anything strange, but I am no specialist.
Here's dmesg's output: https://pastebin.com/3DcbkzUg
#4 2025-09-13 05:11:08
So you are saying that sway+wayland on devuan (of some version) is or seems to be noticeable slower than something else on something else? ...???
Obviously one must ask: what on what was the baseline? And in what way do you notice that loss in speed?
#5 2025-09-13 08:48:38
Identical computers? Identical software? If not, that is likely your answer.
#6 2025-09-13 16:08:53
Assuming you have 1 computer you can dual boot to debian and devuan (or two identical systems, one running each OS) please post output from the following commands on debian and on devuan:
uname -a
cat /etc/os-release
That will give us at least something to go on.
#7 2025-09-13 22:56:32
Micronaut
This is sort of vague since it doesn't say exactly what is slower. But I can say there is a large difference in disk performance between Devuan and MX Linux, which is apparently much closer to Debian. I've got different disks that I plug in to the same machine, and when I am copying large files -- like the data files for games -- I can see the speed on my Gkrellm and it's literally twice as fast copying the files with MX Linux. Possibly something in the drivers that they had to alter in Devuan to completely remove that fake 'init' wrapper that is taking over everything. But MX Linux may have been able to leave in place since it's just trying to neutralize it without purging the system?
#8 2025-09-14 10:18:29
evanescente~ondine
everything graphical is slower. It boots quickly so it doesn't seem the system is impacted before.
But now you talk about it, file operations are slower too. Again, I can make test and measurements here and you may judge if it's normal given the hardware i have, but I can't or won't install another OS (no assurance programs would be the exact same anyway).
#9 2025-09-14 10:38:39
slower than what?
#10 2025-09-14 14:00:14
evanescente~ondine
Slower than before with debian ! Including uploads.
#11 2025-09-14 15:02:56
igorzwx
If your experiment cannot be reproduced it is a sort of myth.
Can you provide an exact step-by-step instruction how to reproduce your experiment?
#12 2025-09-14 16:17:04
Please give us a bit more info.
At least post output from the commands in my last post on the system as it is now.
Also what CPU is it (look in /proc/cpuinfo for model name, number of cores, etc).
How much RAM does it have? (Run free -ht and post output here.)
What sort of disk drive does it have?  <-- This is probably the most important thing since it's apparently been slowed down.
#13 2025-09-14 16:47:53
evanescente~ondine
total       utilisé      libre     partagé tamp/cache   disponible
Mem:            15Gi       1,6Gi        10Gi       320Mi       3,7Gi        13Gi
Échange:       976Mi          0B       976Mi
Total:          16Gi       1,6Gi        11Gi
#1 SMP PREEMPT_DYNAMIC Debian 6.12.38-1~bpo12+1 (2025-07-27) x86_64 GNU/Linux
PRETTY_NAME="Devuan GNU/Linux 5 (daedalus)"
NAME="Devuan GNU/Linux"
VERSION_ID="5"
VERSION="5 (daedalus)"
VERSION_CODENAME="daedalus"
ID=devuan
ID_LIKE=debian
HOME_URL="https://www.devuan.org/"
SUPPORT_URL="https://devuan.org/os/community"
BUG_REPORT_URL="https://bugs.devuan.org/"
intel (R) N100, one processor four cores
But for some reason it accelerated today. What the hell... I swear I did not upgrade sway.
#14 2025-09-14 17:02:46
Perhaps because Ondine is whimsical and unpredictable?
Seong-Jin Cho - Ravel: Gaspard de la Nuit: I. Ondine (Live from Carnegie Hall)
Sorry . . . couldn't resist . . . big_smile
#15 2025-09-14 17:15:12
That N100 is a quite weak CPU. Everything requiring CPU performance will delay the response.
#16 2025-09-15 01:01:40
@rolfie it still is a 13th gen processor. I bet it is faster than some medium grade gen 10 processors and definitely most older stuff.
#17 2025-09-15 05:30:53
whenever i see designations like that(n100) i recollect the old atom n270 stuff:
https://www.cpubenchmark.net/compare/614vs5157/cpu_test_info.html
#18 2025-09-15 16:11:43
@ondine, you still haven't said what sort of disk it has (mechanical or SSD) or the model.
But to work out why it sped up all I can suggest is looking in the logs and dmesg output for interesting messages.
#19 2025-09-15 16:30:19
kapqa
debian13 is quite responsive, especially when downloading packages;
but proof is in the pudding, and feeling is that devuan overall is more responsive, even when run on gen3x4 ssd over an debian on gen4x4 ssd;
the n100 is 12thn gen, and should be very good for easy task requiring single execution; certainly another league than most atom ever were, probably.
that said, i like apu more, because overall round package, although it is difficult with driver sometimes.
#20 2025-09-15 17:22:22
evanescente~ondine
Patriot P220 1024GB (SN12288). An SSD. I did the smart self-test. It's fine.
#21 2025-09-15 18:23:28
kapqa
think the netselect-apt is not yet fully compatible with devuan; it would be nice to have a easy tool via terminal to select the fastest server based on ones location.
EDIT: if you can afford, you would be better of using a pcie ssd over a sata based one; you can then still use the sata ssd for data storage or for your windows installation if you so like; basically you can find pcie ssd a cheaper prices than sata ssd sometimes nowadays. this does not explain why for you debian could be  better chose.
#22 2025-09-15 19:09:03
evanescente~ondine
So I understood well, I use now a Sata disk with a U.2 form factor, and have a spare M.2 NVME disk over, I assume, PCIE lanes. Ok, M.2 or 2.5'', I can't tell the difference... Pfff, standards change wayy too quickly, and few people need or notice the difference anyway. Yeah I should partition the spare windows disk, but isn't it risky ?
#23 2025-09-16 16:13:27
Looking at your free -ht output you seem to have plenty of free memory, and swap space has not been used at all. So that wasn't the problem.
But that doesn't explain why the system suddenly started responding faster. Have you looked for log messages? Did any relevant-looking messages come out when it changed speed. Or start or stop coming out then?
#24 2025-09-17 23:54:49
kapqa
no , partitioning the windows is not that risky, you can do that inside windows, no problem at all; only issue i found with ddual-triple booting or the like is that grub tends to install  itself at times, even when told otherwise,  onto the windows partition in EFI, but that can be easily fixed if it so happens; (booting into windows and deleting the entry manually via diskpart et al) maybe this happens beause my BIOS could have trouble differentiating the three NVME i have installed, have not found a reason why it happens on my PC. (it seems they are getting mixed up or "tossed around" sometime)
you can check that by going into BIOS after you finished your install of Linux, and look if you find on Windows SSD side two entries, one for Windows Manager, and one for Ubuntu or Debian or whatever; of course if you want to use a SSD for both systems, then it should be that way , provided you install install Grub onto location that is being proposed to you.
#25 2025-09-18 03:45:58
RedGreen925
The Debian based installer will install to the first drive seen by the installer in the machine same as windows does no matter what is selected. Only when you go out of your way to deselect all efi system partitions for use except the one you want used will it do what you want and install onto a non first system seen drive. This garbage behaviour bothered me for many years until I figure out what it was doing and the way to avoid it doing so. Not much of a  clue on other distributions installers as I tend to only use Debian systems. If you backup the /boot/efi/EFI/BOOT/BOOTX64.EFI file before installing any Linux then you can restore it to get the windows boot listing back as this is the main file any 64bit OS uses to boot on an EFI machine. Though I have found it is put there by both except for something like Arch/Void systems as my testing on them showed they do direct entry in the EFI firmware for them to boot and ship a broken EFI implementation without that normal usage others do.
