#1 2025-08-20 16:36:55
nixer
[SOLVED] Excalibur and fail2ban
I like to be made aware of any pending problems before they bite me, so, I recently tested a daedalus dist-upgrade to excalibur of a snapshot of my production server within virtualbox.
The dist-upgrade went fine, or so I thought, then upon rebooting I saw that fail2ban was broken.  This is the output in the terminal:
root@fc-vm:/home/user# service fail2ban start
Starting Authentication failure monitor: fail2ban2025-08-20 12:24:03,728 fail2ban                [4719]: ERROR   NOK: (38, 'Function not implemented')
failed!
I checked the fail2ban.log and it contained the same error.  I then did an "apt info fail2ban" command on both the daedalus and excalibur versions of fail2ban to see what could have changed.  The only thing that I noticed was that the package "python3-systemd" is listed as a suggested package in daedalus whereas it is now listed as a dependency in excalibur.  The dist-upgrade did pull in this package python3-systemd so it is installed.  But the program will not start.  The fail2ban homepage specifically says that systemd is not a dependency.
I then tested this on an excalibur preview release from here: https://dev1galaxy.org/viewtopic.php?pid=57204#p57204 and I got the same result, so I know that it is not something on my system or its configuration that is causing a problem.
Has anyone else had this issue?  I consider this the most important program on any system that is open to the internet, so this is important to me.  Any help and/or suggestions are welcome.
#2 2025-08-20 16:53:56
g4sra
Re: [SOLVED] Excalibur and fail2ban
Re dist-upgrade to excalibur
Suggestion:  DONT, Trixie is broken, wait for it to be fixed!
The broken 'fail2ban' thing is well known and all over the internet.
#3 2025-08-20 18:45:37
nixer
Thank you for this bit of info.  I did do a web search and a search on the debian forums a couple days ago and found nothing that looked familiar.  I will try again later.
Thank you again.
#4 2025-08-20 18:51:55
g4sra
Trixie has forced dependency on newer versions of python modules which have dropped depreciated API's.
Of greater concern is the list of faults in trixie, prohibiting it's use in any mission critical role.
https://www.debian.org/releases/trixie/ … ssues.html
Credit to golinux for first posting of the link
#5 2025-08-20 20:53:48
g4sra wrote:
Credit to golinux for first posting of the link ...
Indeed ...
And then, there's also this bit:
uncredited wrote:
    ## Old Business
    - Debian Trixie has been released
    - And what a cluster-f*** it is!
Right on the dot.  8^)
#6 2025-08-20 21:06:36
Hmmmm . . . I wonder who that might be . . . LOL!!  roll
#7 2025-08-21 00:59:35
@g4sra which package has that awful license change? LXD?
#8 2025-08-21 08:27:07
g4sra
@zapper, API = Application Program Interface, the resources that a python module (in this case) provides to your program to call on.
What is coming down the line....
https://docs.python.org/3/deprecations/index.html
Someone needs to port fail2ban to the newer python version forced on it by trixie.
#9 2025-08-21 09:49:34
Upstream fail2ban already has compatibility with python 3.13 (inc. bundling the async modules removed with python 3.12), said upstream version (1.1.0) is in trixie, and there appear to be no relevant reports on the Debian BTS...
If you're going to claim "well known and all over the internet", perhaps provide some examples?
Given that the only hits I can get for that exact error are 1: this thread, and 2: an artix user from 5 years ago, and there's no noise about this at all over on FDN, I'm far more inclined to think this has to do with python-systemd and Devuan packaging / shipped configs than anything else.
Ed. Yup, sure enough, again:
$ diff fail2ban_1.0.2-2_all/data/etc/fail2ban/paths-debian.conf fail2ban_1.1.0-8_all/data/etc/fail2ban/paths-debian.conf
30a31,41
> # In Debian, these services will log to the journal via syslog, so use the
> # journal by default.
> syslog_backend = systemd
> sshd_backend = systemd
> dropbear_backend = systemd
> proftpd_backend = systemd
> pureftpd_backend = systemd
> wuftpd_backend = systemd
> postfix_backend = systemd
> dovecot_backend = systemd
$ diff fail2ban_1.0.2-2_all/data/etc/fail2ban/jail.d/defaults-debian.conf fail2ban_1.1.0-8_all/data/etc/fail2ban/jail.d/defaults-debian.conf
0a1,4
> [DEFAULT]
> banaction = nftables
> banaction_allports = nftables[type=allports]
1a6,7
> backend = systemd
> journalmatch = _SYSTEMD_UNIT=ssh.service + _COMM=sshd
That's not going to work, now is it? Nice job Devuan packaging team merging stuff from debian without testing it bot, great catch. Definitely fixing all the systemd things for this premiere systemd-free distro. roll
@OP, make sure all your jails are using the 'polling', 'pyinotify' (if you have that installed) or 'auto' backends. This might not be your problem, but I suspect it is based on where that error appears to be coming from...
Either way though: Blindingly obvious excalibur packaging fail. If it doesn't cause problems here, it will later.
#10 2025-08-21 11:42:37
It looks like there you have a task to volunteer for.
#11 2025-08-21 18:00:26
nixer
I had my backends set to "auto", and I even tried "polling".  I have not tried "pyinotify" yet, but if it works, I will report back here.
EDIT:  I installed
apt install python3-pyinotify
and it worked!
In my jail.local file I have the backend set at:
backend = auto
Maybe the package does not need to be rebuilt, yet, but when this issue comes up again with someone else, pass the word about a missing dependency in devuan "python3-pyinotify"
root@fc-vm:/home/niXer# service fail2ban status
Status of Authentication failure monitor: fail2ban is running.
root@fc-vm:/home/niXer# lsb_release -a
No LSB modules are available.
Distributor ID:    Devuan
Description:    Devuan GNU/Linux 6 (excalibur/ceres)
Release:    6
Codename:    excalibur ceres
root@fc-vm:/home/niXer# apt policy fail2ban
fail2ban:
  Installed: 1.1.0-8
  Candidate: 1.1.0-8
  Version table:
*** 1.1.0-8 500
        500 http://gnlug.org/pub/devuan/merged excalibur/main amd64 Packages
        100 /var/lib/dpkg/status
root@fc-vm:/home/niXer# apt policy python3-pyinotify
python3-pyinotify:
  Installed: 0.9.6-5
  Candidate: 0.9.6-5
  Version table:
*** 0.9.6-5 500
#12 2025-08-21 20:12:10
@g4sra
But which package has the licensing problem? And if its python itself, say so.
If so, does this mean python has a problematic license like rust or java?
Asking...
#13 2025-08-21 23:55:23
You mean giving the forum autoresponder gramophone a whack, because it's stuck again?
zapper wrote:
licensing problem?
There is no "licencing problem". Some APIs were deprecated or moved to external packages, that is all.
zapper wrote:
Asking...
But apparently not reading, because g4sra already explained that.
As usual, a bunch of whinging and finger pointing about "them", "forced" changes, "clusterfuck" upstreams, and a bit of misdirection regarding "awful licence changes"...
While the real problem is right in our back yard, and has nothing to do with any of the favourite punching-bags. Nothing ever changes around here, does it?
#14 2025-08-22 00:24:59
You certainly don't! We seem to be your favorite punching bag. Or maybe you are getting paid for your efforts. Or maybe you are just a pathological SOB. Please just go somewhere else. You have worn out you welcome and good will here, IMO.
#15 2025-08-22 03:27:17
I have posted the information required to solve the OPs problem, because nobody else was doing that. As a result, this thread is now [SOLVED].
What did you contribute here?
#16 2025-08-22 04:30:44
Congratulations! And the winner of the best problem solver but most disgusting human being award goes to . . .
(see above post)
#17 2025-08-22 04:39:16
Ahh, personal attacks. The last refuge of the incompetent. Bye go, I'm done arguing with you.
Nice one nuking the image BTW, did that land a little close to home?
#18 2025-11-19 21:35:16
nixer
It seems that a few others have stumbled upon this bug recently, so I thought I would post a working and stable fix.  It can be found at https://lists.dyne.org/lurker/message/2 … b4.it.html
#19 2025-11-20 06:04:50
stultumanto
Huh, that's strange. I installed fail2ban on both a Trixie and an Excalibur system recently and both worked perfectly (once I set the proper logging method.) Maybe it's because I used nftables and pynotify from the start? Those seem to be part of some people's "fixes."
#20 2026-03-28 05:49:45
Hi, I have had the same problem with fail2ban with excalibur... (I've now decided to persist with this version of Devuan) Thank you for your efforts!
I didn't get any joy with the above examples or nixers script.
I eventuall tried to roll-back to fail2ban_1.0.2-2_all.deb.
python3-pyinotify was already installed.
When rollingback I got an error saying asynchat was not installed, so I installed python3-standard-asynchat_3.13.0-5_all.deb
and the fail2ban script started with out error.
I've only done one reboot since, so YMMV, but I hope it helps some of you here.
I'll see what happends when I eventually upgrade fail2ban later.
Cheers!
#21 2026-03-29 06:09:40
I unpacked fail2ban_1.1.0-8_all and rsync'd the files into the install, but didn't run the scripts and it seems like it's working. No error messages.
Cheers!
#22 2026-03-29 11:05:28
trinidad
Thanks @steve_v and @GlennW. It's OK Greta don't fret so much.
TC
Often unawares.
#23 2026-06-17 11:33:26
Marjorie
I've just upgraded my server to Excalibur, having successfully updated a couple of other desktop systems without issue.
The server box (local not in the cloud) does however use fal2ban to block spammers on its postfix/dovecot mailserver.
Fail2ban was working fine on Daedulus but failed when upgraded to Excalibur, with the same unhelpful ERROR message mentioned elsewhere.
I don't think I needed to change my logging target - I'm logging to /var/log/fail2ban.log - but for others perhaps worth checking the default which is set by
logtarget = /var/log/fail2ban.log
in /etc/fail2ban/fail2ban.conf .
There are two issues I found.
1) pyinotify. The package python3-pyinotify was not installed.
apt-get install python3-pyinotify
2) The folder /etc/fai2ban/jail.d contains the file defaults.debian.conf with the code:
[DEFAULT]
[sshd]
backend = systemd
enabled = true
I ban using nftables so those lines worked for me. If you use iptables or another firewall then you would need to change this.
However the only jail enabled [sshd] has backend = systemd, this is what breaks fail2ban on a Devuan install.
Ironically I don't strictly need this jail as my mail server in on my local network and I've closed port 22 to the internet at the router.
Rather than amend this package file, which, of course could be overwritten at an update, I found the solution that worked for me was to add backend=pyinotify to each jail I enabled in /etc/fai2ban/jail.local/ .
So:
[DEFAULT]
# use nftables
# Whitelist specific IPs or ranges
ignoreip = 127.0.0.1/8 192.168.1.0/24
[sshd]
backend = pyinotify
enabled = true
[apache-auth]
backend = pyinotify
enabled = true
[dovecot]
backend = pyinotify
enabled = true
port    = pop3,pop3s,imap2,imaps,submission,465,sieve
maxretry = 3
findtime = 12h
bantime = 3d
[postfix]
backend = pyinotify
enabled = true
mode = auth
logpath = /var/log/mail.log
maxretry = 3
findtime = 12h
bantime = 3d
and so on for a couple more, non standard jails/filters I enable.
I see that python3-systemd is still marked as a dependency and python3-inotify simply as a recommend.
On my upgrade python3-systemd wasn't installed either, maybe it would have been on a systemd box.
This is exactly the problem Steve_V identified last year, not up to me whether it's worth making Devuan specific changes to make upgrading or installing fail2ban work out of the box.
#24 2026-06-19 02:42:41
Marjorie, Thank you for your contribution, I'm using your tips as well.
