#1 2017-06-19 18:12:19
keos
[solved] Problems to open synaptic icon.
I'm no able to open the synaptic from the menu, just as root from terminal, any idea?.
Thanks!
devuan_ascii_2.0.0-rc_amd64_desktop-live.iso  [Xfce]
Graphics: AMD Radeon HD 7640G integrated graphics
GPU: AMD/ATI Trinity [Radeon HD 7640G]
#2 2017-06-20 13:52:54
keos
Re: [solved] Problems to open synaptic icon.
gksu gedit /usr/share/applications/synaptic.desktop
and change line Exec=synaptic-pkexec to Exec=gksu synaptic
#3 2017-06-20 14:39:33
That will work until synaptic is upgraded to a newer version. Then your edited .desktop file will be replaced. I solved that problem by making a separate .desktop file called synaptic-gksu.desktop. Make sure to change the Name field, because you will have two entries in your menu for synaptic. You need to be able to tell them apart.
#4 2017-06-20 14:42:27
I have a gksu synaptic launcher stacked in the Xfce panel so never have to open from the menu or desktop.  wink  Ditto other root accessible apps.
