#1 2017-06-16 16:39:06
Somewhat Reticent
Rough edges to polish?
On startup,
GDBus.Error:org.desktop.PolicyKit1.Error.Failed:
Cannot determine user of subject
synaptic does not work from Preferences (why there?) for (mere) user (does waste time) ¿why is it even listed!?
but using Debian/Applications/System/Package_Management brings up LXTerminal (did a message about gksu flash by?):
==== AUTHENTICATING FOR com.ubuntu.pkexec.synaptic ====
Authentication is required to run the Synaptic Package Manager.
Authenticating as:  root
Password:
==== AUTHENTICATION COMPLETE ====
messages repeated several times:
Gtk-message: Gtk-Dialog mapped without a transient parent. This is discouraged.
(also some messages about theme engine not found for (from-menu) app)
(on (possibly-buggered(never trust an "update/upgrade")) LXDE installed from Jessie DVD (only DVD I've seen))
(edit for format, specifics 2017JUN16)
#2 2017-06-16 16:49:30
Re: Rough edges to polish?
Jessie, ASCII, Ceres???  And please use BBCode to enclose the messages.
