#1 2017-06-13 15:23:34
maurorappa
AWS AMI Devuan available
I created a public AMI for Devuan 1 !
it' on London region,  details are:
AMI ID
ami-9bafb8ff
AMI Name
Devuan-1.0-TLS
user is devuan:devuan
I also published the instructions I used:
https://gist.github.com/maurorappa/b21b … 6e8f29a46c
Feel free to use, copy, write any feedback, insult!
UPDATE: it's also available in Virgina and Frankfurt region
#2 2017-06-19 02:49:28
Re: AWS AMI Devuan available
This just posted on #devuan:
<batmore> golinux,fsmithred,rrq: I checked out Amazon Web Services, Devuan-1.0-TLS by maurorappa... Amazon image for people to use within AWS env.  Very nice installation and setup.  Far and away better than my AWS instance.  The docs for the image are straight forward and correct. You end up with a usable simple install of Devuan Jessie 1.0 with TLS effective (security).  I recommend it as the base, goto AWS AMI image to use within Amazon clo
<batmore> golinux,fsmithred,rrq: for reference... the aws ami image I produced was an adaption of an earlier Debian Wheezy, that was upgraded to Devuan Jessie v1.0. Mine ends up using xilinux for boot rather than grub(2).  Mine is simpler, but maurorappa's image is more true to current Devuan Jessie setup/config.  cheers
Well done maurorappa!!  This is a great addition to our image library.
#3 2017-06-19 12:28:32
maurorappa
thank you! big_smile
