#1 2024-12-21 14:05:55
devuanitaviejo
[SOLVED] I can't install hplip on Excalibur
I recently switched to the Excalibur distribution. I have an HP Officejet 9010 printer and I can't get it to work. I see that the hplip package is not in the testing version of debian (trixie) either. How can I fix this?
#2 2024-12-21 14:15:54
Re: [SOLVED] I can't install hplip on Excalibur
Wait until it comes back.
#3 2024-12-21 14:28:42
devuanitaviejo
I think this is not a good idea. It seems that hplip is walking dead according to this post.
https://forums.debian.net/viewtopic.php … 50#p769450
The replacement seems to be libsane-hpaio but I can't get it installed either.
#4 2024-12-21 15:00:03
Dutch_Master
Post the content of the file /etc/apt/sources.list (use the code button to mark it from your normal text)
You may need to enable particular repositories.
#5 2024-12-21 15:00:49
devuanitaviejo
Actually both packages, hplip and libsane-hpaio are in both the stable and experimental versions but not in testing. :-(
#6 2024-12-21 15:03:49
You problem is self-inflicted when you use "testing".
#7 2024-12-21 15:03:53
devuanitaviejo
# deb cdrom:[Devuan GNU/Linux 4.0 chimaera amd64 - netinstall 20211012]/ chimaera non-free main contrib
# deb cdrom:[Devuan GNU/Linux 4.0 chimaera amd64 - netinstall 20211012]/ chimaera contrib main non-free
deb [url]http://deb.devuan.org/merged/[/url] excalibur non-free contrib main
# deb-src [url]http://deb.devuan.org/merged/[/url] daedalus main non-free contrib
# deb [url]http://deb.devuan.org/merged/[/url] daedalus-security non-free contrib main
# deb-src [url]http://pkgmaster.devuan.org/merged/[/url] daedalus-security non-free contrib main
# chimaera-updates, to get updates before a point release is made;
# see [url]https://www.debian.org/doc/manuals/debian-reference/ch02.en.html#_updates_and_backports[/url]
# deb [url]http://deb.devuan.org/merged/[/url] daedalus-updates main
# deb-src [url]http://deb.devuan.org/merged/[/url] daedalus-updates non-free contrib main
# This system was installed using small removable media
# (e.g. netinst, live or single CD). The matching "deb cdrom"
# entries were disabled at the end of the installation process.
# For information about how to configure apt package sources,
# see the sources.list(5) manual.
Did you not see Dutch_Master's post above?
#8 2024-12-21 15:09:53
devuanitaviejo
#9 2024-12-21 15:15:38
devuanitaviejo
If the problem was generated when I switched to the ‘testing’ version, I will try to fix it, not self-punish ;-)
is it possible to install hplip and its dependencies by adding the ceres repository just for that and then unmark it?
#10 2024-12-21 15:50:03
For completeness you should add non-free-firmware to your sources.list.
Using Ceres: it may work, it also can brick your system.
Procedure:
Add this line to your sources.list
deb http://deb.devuan.org/merged/ ceres main contrib non-free non-free-firmware
Run the following commands
# apt update
# apt -t ceres install hplip
Then comment out Ceres in your sources.list and run another apt update.
No warrenty.
#11 2024-12-21 16:18:52
devuanitaviejo
Indeed, I added the repository with the ceres version to the sources.list and was able to install hplip. The printer worked. In the synaptic configuration I chose to prefer the testing version to avoid upgrading to the experimental version. I don't know if this would not require unchecking the ceres repository from the sources.list. If I didn't do something stupid I think I can mark the thread as ‘solved’. What do you guys think?
#12 2024-12-21 22:43:38
The version in ceres will probably be in excalibur in less than a week. You didn't do anything wrong. You would need to install more packages or do an upgrade with the ceres repo enabled to screw up the system.
#13 2024-12-21 23:18:55
devuanitaviejo
Thank you very much for everyone's contributions. Without you I would not have solved the problem.
#14 2024-12-22 07:00:20
I recommend strongly to put a hash # before the ceres line.
#15 2024-12-22 08:21:14
devuanitaviejo
So it wouldn't uninstall the package when I went to update the system, I wouldn't have to force version first or something rolfie?
