#1 2024-11-20 21:31:24
pcalvert
New packages automatically installed?
Today I ran apt upgrade on a Chimaera system that I am still using and this was the output:
# apt upgrade
Calculating upgrade... Done
  libc++1-16 libc++abi1-16 libunwind-16
  libjavascriptcoregtk-4.0-18 libwebkit2gtk-4.0-37
2 upgraded, 3 newly installed, 0 to remove and 0 not upgraded.
Need to get 25.5 MB of archives.
After this operation, 768 kB disk space will be freed.
Notice that apt wants to install new packages. I've seen this before, and it always struck me as being a bit unusual. I thought that automatic installation of new packages is only supposed to occur if one is using testing or unstable. Does anyone have an explanation for why this is happening?
Another one is called Luxxle.
#2 2024-11-20 22:41:16
Re: New packages automatically installed?
Are you trying to update Chimaera or upgrade to Daedalus? Or maybe I'm misunderstanding something . . . wouldn't be the first time.
#3 2024-11-21 00:07:53
pcalvert
Update Chimaera (i.e., normal, regular maintenance).
#4 2024-11-21 00:55:19
Apparently your system has older versions those packages, and your command asks for upgrading anything upgradable. You might try
$ apt-cache policy libjavascriptcoregtk-4.0-18 libwebkit2gtk-4.0-37
to get more information before accepting... or maybe that's too late now?
#5 2024-11-21 17:55:10
pcalvert
An idea just came to me, so I went ahead and tried it:
$ aptitude why libc++1-16
i   atril                Depends libatrilview3 (= 1.24.0-1+deb11u1)
i A libatrilview3        Depends libwebkit2gtk-4.0-37 (>= 2.5.3)
p A libwebkit2gtk-4.0-37 Depends libc++1-16 (>= 1:16.0.6)
$ aptitude why libc++abi1-16
p A libwebkit2gtk-4.0-37 Depends libc++abi1-16 (>= 1:16.0.6)
$ aptitude why libunwind-16
p A libwebkit2gtk-4.0-37 Depends libunwind-16 (>= 1:16.0.6)
So, apparently the new packages are dependencies of libwebkit2gtk-4.0-37. That's a new one for me. I did not know that packages could suddenly acquire new dependencies. Perhaps this is just one of the oddities that can show up when one is running oldstable.
