#1 2024-10-06 08:00:47
Paddlaren
[SOLVED] Security updates of Devuan compared to Debian
I am intending to use Devuan for a public server (most likely in a VPS) but I am keen to know the process of security updates.
I am aware of Devuans relation to Debian in general but how does it work with security updates?  Are the Debian changes  mirrored in Devuan and does it imply a lot of manual work involved or will the change enter Devuan quite quickly? How does the release engineering flow look like?
Thanx in advance,
Erik
#2 2024-10-06 09:14:46
Re: [SOLVED] Security updates of Devuan compared to Debian
Devuan uses the Debian repositories for everything except systemd related software.
#3 2024-10-06 14:51:52
Paddlaren
Thanks,
So the Devuan repos are mirrored from Debian and when a security patch is release in Debian it is directly available in Devuan then?
Are the packages mirrored from Debian every what-ever hours or are Debian mirrors included in the Devuan installation but with lesser priority than Devuans own mirrors?
#4 2024-10-06 14:54:33
And here is how Debian sources are merged with Devuan:
amprolla magic
#5 2024-10-06 17:33:04
Paddlaren
Thanks,
I always find it difficult to understand how distros implement their respective dependencies. This is the first time I have gotten some understandable answer smile
BR
Erik
