#1 2024-10-02 16:39:51
How to replace all mentions in git soure code,
I am basically asking, something in continuation to this:
http://dev1galaxy.org/viewtopic.php?id=6857
How can I replace all mentions instead of a word instead of searching for it.
Through all of a git folders/repo
#2 2024-10-02 17:19:59
Re: How to replace all mentions in git soure code,
From the root of the git repo:
find . -type f -exec sed -i 's/old-word/new-word/g' {} \;
Be careful with your words! (e.g. don't change a word that might be part of a word that's not the intended word.)
#3 2024-10-02 18:08:18
You are giving zapper a loaded gun to play with?! Oh my!!!  big_smile
#4 2024-10-02 19:24:28
@golinux which is why I am replacing python2.7 with tauthon instead of python with tauthon
;P
Btw, I used this command after doing that:
git rev-list --all | xargs git grep -F python2.7
and it still shows python2.7 mentions... weird stuff.
Correcting what I said, I wrote down the wrong one.
#5 2024-10-02 20:10:01
You said, "I used this command after doing that."
I ask, "What did you do before you ran that 'find' command?"  It should have worked.
#6 2024-10-02 20:33:23
In simple terms, I did this:
Then I did my command to check to see if it was fixed,
I seem to have gotten mixed up and written wrong thing down... my bad.
In any case, that might help clear up the confusion.
Does the find command you gave me actually replace all mentions of the word python2.7 if I put it as first word with the second word in all source code?
Or am I really confused.
#7 2024-10-02 21:33:01
Yes you are confused smile.
That find command of @fsmithred, when taken literally, will replace all occurrences of "old-word" (literally) with "new-word" (literally), and it will do nothing to occurrences of "python2.7".
That is a puzzle for ome and not for others.
#8 2024-10-02 23:12:11
Yeah, you have to tell sed exactly what to find and replace.
find . -type f -exec sed -i 's/python2.7/tauthon/g' {} \;
#9 2024-10-03 05:08:24
@fsmithred hmm... weird I tried that and it still left stuff behind unchanged...
#10 2024-10-03 07:07:50
The command you are using,
scans all versions of all files in reverse chronological order, to find "python2.7".
Probably you mean to only check the latest version of the files? Like
grep  -F python2.7 -r *
which would not report any match.
#11 2024-10-03 07:44:27
@ralph.ronnquist fair point hmm....
Yeah, it must keep resetting... then.  I am doing something a bit out of the norm anyhow for here.
So I will leave it at that.
