#1 2024-05-23 16:05:09
zeitlos
AppImage "Todoist" doesn't work
Hi all! The finished package of this application does not want to launch in any way. What could be the reason and how to fix it.
Downloaded from here:
https://todoist.com/downloads/linux
#2 2024-05-25 05:25:44
ab
Re: AppImage "Todoist" doesn't work
This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
Error: dialog module can only be used after app is ready
    at checkAppInitialized (node:electron/js2c/browser_init:2:15666)
    at messageBox (node:electron/js2c/browser_init:2:17556)
    at Object.showMessageBoxSync (node:electron/js2c/browser_init:2:19933)
    at pe (/tmp/.mount_TodoisdwI0mG/resources/app.asar/webpack/electron/electron.js:1:28167)
    at c.registerDefaultProtocol (/tmp/.mount_TodoisdwI0mG/resources/app.asar/webpack/electron/electron.js:1:45776)
    at c.init (/tmp/.mount_TodoisdwI0mG/resources/app.asar/webpack/electron/electron.js:1:45621)
    at /tmp/.mount_TodoisdwI0mG/resources/app.asar/webpack/electron/electron.js:1:35263
    at r.a (/tmp/.mount_TodoisdwI0mG/resources/app.asar/webpack/electron/electron.js:1:52298)
    at 769 (/tmp/.mount_TodoisdwI0mG/resources/app.asar/webpack/electron/electron.js:1:34977)
    at r (/tmp/.mount_TodoisdwI0mG/resources/app.asar/webpack/electron/electron.js:1:51801)
Looks like a build problem.  If you have an account with them, file a support case.  They might want what I pasted above.
#3 2024-05-26 16:52:59
zeitlos
Thank you for your reply
#4 2024-06-28 18:20:51
zeitlos
In general, I wrote to todoist - no one wants to deal with this problem. They said that they only support Ubuntu (and therefore systemd) distributions. It's a pity that this is so, but I tried to do everything I could.
#5 2024-06-28 20:42:34
If not you, perhaps someone else will eventually provide a more universally compatible fork.
