#1 2024-04-15 20:21:23
[SOLVED] Beowulf updates - no release file
Still running on Beowulf with a backported kernel ... (yes, I know ... )
~$ uname -a
Linux devuan 5.10.0-0.deb10.16-amd64 #1 SMP Debian 5.10.127-2~bpo10+1 (2022-07-28) x86_64 GNU/Linux
... and still pondering what to do/how to do it.
No issues up to today, when I tried to update and got this:
~$ sudo apt update
Err:5 http://deb.devuan.org/merged beowulf-updates Release
  404  Not Found [IP: 185.38.15.84 80]
E: The repository 'http://deb.devuan.org/merged beowulf-updates Release' does not have a Release file.
Same with beowulf-backports main contrib non-free.
Editing the /etc/apt/sources.list to avoid the problem (ie:#deb http://deb.devuan.org/merged/ beowulf- ...) allowed me to update to the lastest xserver security release.
Evidently, deb http://deb.devuan.org/merged/ beowulf-updates main contrib non-free is no longer current.
To stay on Beowulf (and test how it goes, maybe till next year), what changes should I make to /etc/apt/sources.list besides having remmed the line/s above?
#2 2024-04-15 20:31:09
Re: [SOLVED] Beowulf updates - no release file
@Altoid . . . beowulf has been archived so you'll need to change your sources.list though I understand there are still some unfinished bits.
#3 2024-04-15 20:51:41
Don't change yet. Beowulf was accidentally archived too early (and incompletely). Keep using deb.devuan.org - the problem with that got fixed.
Beowulf will be archived for real when debian archives buster.
#4 2024-04-15 21:03:12
Hello gl:
Thanks for the fast reply.
golinux wrote:
... beowulf has been archived so ...
Thought as much, but could not find where 'archived' was.
No problem as long as the rest works, I can wait for it all to pan out.
BTW:
Saw the LeePen interview?
Turns out that besides being active in many (!) different fields, the chap also uses 'extremely old hardware'.
Got me thinkling that my ca. 2007 box has much more life left in it than I originally thought.
Maybe my backported Beowulf installation too?
#5 2024-04-15 21:06:16
Hello fsr:
fsmithred wrote:
Don't ...
Beowulf was accidentally archived ...
... will be archived for real when ...
I see.
Thanks for the heads-up.
#6 2024-04-16 10:14:07
fsmithred wrote:
... the problem with that got fixed.
From today @07:00 (-03:00 GMT):
~$ sudo apt update
Fetched 119 kB in 2s (63.1 kB/s)
Building dependency tree
All packages are up to date.
Thank you.
Q:
Has deb.devuan.org/merged beowulf-backports been archived or maybe the fix has not propagated yet?
~$ sudo apt update
E: The repository 'http://deb.devuan.org/merged beowulf-backports Release' does not have a Release file.
#7 2024-04-16 18:01:37
I was going to say...
I know its listed as being oldoldstable.
Seems we all make our share of errors. wink
#8 2024-04-16 19:35:43
It looks like beowulf-backports got archived.
Get:6 http://archive.devuan.org/merged beowulf-backports/main amd64 Packages [491 kB]
#9 2024-04-16 20:25:22
fsmithred wrote:
... looks like beowulf-backports got archived.
I see ...
Right, I will edit my /etc/apt/sources.list file to reflect this change.
#10 2024-04-16 23:54:16
@fsmithred
How strange... I thought backports lasted as long as the stable  version including oldstable, etc... was supported
