#1 2024-03-26 15:54:19
dirk.gently
Incus
Is anyone working on a Devuan package for Incus? Incus (https://linuxcontainers.org/incus) is a relatively recent fork of LXD (after Canonical pulled LXD from the linuxcontainers.org project and changed licensing).  Debian has no official Incus packages, but Zabbly maintains Debian/Ubuntu builds (https://github.com/zabbly/incus).  However Zabbly's Debian packages have systemd hooks in the package scripts that break things on Devuan.  I'm such a newbie to Devuan devel that I can't glean any useful information from pkginfo.devuan.org about who, for instance, repackaged LXD* for Devuan and what they did -- apologies.  The Incus fork is recent enough that it should be reasonable to just repeat the same changes from Debian that were needed for LXD.  I'd be willing to take this on but would happily stand aside if someone else is already working on it.  TIA!
#2 2024-03-27 02:18:27
nixer
Re: Incus
I found some debian packages in daedalus-backports.  But warning... by default it does try to pull in systemd-standalone-sysusers, and I would strongly urge you to pin this out so that it will not get installed.  There is a non-systemd package called opensysusers which will install in its place if the systemd* packages are pinned from getting installed.
For example, this is my apt pin in /etc/apt/preferences.d/00nosystemd:
Package: *systemd* systemd-* systemd-standalone-sysusers
Pin: release *
Pin-Priority: -1
Make sure the daedalus-backports repo is active in sources.list.
# apt policy incus
incus:
  Installed: (none)
  Candidate: 0.6-1~bpo12+1
  Version table:
     0.6-1~bpo12+1 100
        100 http://deb.devuan.org/merged daedalus-backports/main amd64 Packages
# apt install -t daedalus-backports incus
  attr incus-client libcowsql0 liblxc-common liblxc1 libraft0 libsubid4 lxcfs
  opensysusers uidmap
Suggested packages:
  btrfs-progs ceph-common lvm2 zfsutils-linux incus-tools cgroupfs-mount
  | systemd
Recommended packages:
  apparmor dnsmasq-base incus-agent
  attr incus incus-client libcowsql0 liblxc-common liblxc1 libraft0 libsubid4
  lxcfs opensysusers uidmap
0 upgraded, 11 newly installed, 0 to remove and 59 not upgraded.
Need to get 22.7 MB/22.8 MB of archives.
After this operation, 76.9 MB of additional disk space will be used.
I have not installed, nor do I know if these packages will work.  I see that systemd is a "suggested" package, but not a dependency.  Let us know how it goes.  Thanks.
Edit:  grammar and spelling.
