#1 2024-02-14 16:11:45
herbie
Repositories
Is the Devuan servers down for maintenance as I cannot update just a bunch of
Could not connect to debian.map.fastlydns.net:80 (146.75.106.132). - connect (111: Connection refused) Cannot initiate the connection to debian.map.fastlydns.net:80 (2a04:4e42:8a::644). - connect (101: Network is unreachable
etc over and over
#2 2024-02-14 16:23:56
The-Amnesiac-Philosopher
Re: Repositories
May I ask...why do you have a "Debian" repo in your sources on Devuan???
A quick search of debian.map.fastlydns was unable to connect to anything.
A quick search of debian.map.fastlydns.net returned a fatal error! yikes
A quick search of debian.map.fastlydns.net:80 returned a fatal error. yikes
Might want to check out this page???
https://www.fastlystatus.com/
I stopped after that. IMHO, this is a Debian/fastly issue...not Devuan...but who am I to say...I'm just some guy... wink
#3 2024-02-14 16:29:19
Re: Repositories
Dude...this is the closest answer I could find...from 3 years ago...
https://lists.debian.org/debian-user/20 … 00229.html
Good luck.
#4 2024-02-14 19:11:18
Re: Repositories
I don't know why this intrigues me tongue ...might try cleaning your cache...
sudo apt clean
...then try running an update again...
sudo apt update
...but it's recommended that you don't mix devuan repos with others. wink
#5 2024-02-14 21:00:45
herbie
Re: Repositories
Thank you all and will try and fix.
#6 2024-02-15 20:57:10
herbie
Re: Repositories
https://imgur.com/a/9oecFhJ is the link to show virgin repositories
#7 2024-02-15 21:04:46
Re: Repositories
Ahhhh...your sources are peppermint and debian. Have you asked on either of their forums?
#8 2024-02-15 21:21:05
herbie
Re: Repositories
No I haven't but remember this is a VIRGIN install.  Those repositories were added by the install process so i assumed they were good to go and I thought Devuan was based on Debian but with Systemd removed.   AMIRITE lol
#9 2024-02-15 21:29:08
Re: Repositories
herbie,
If what I'm seeing is correct, there are no Devuan mirrors included in your sources.list...only Peppermint and Debian.
I'm not sure what happened...
Were you wanting to install the Devuan version of Peppermint? If that's the case, it appears that you actually installed the Debian version of Peppermint?
EDIT: I'm unfamiliar with what the Peppermint sources.list looks like, so I'm only going by the picture that you shared. wink
#10 2024-02-15 22:18:56
herbie
Re: Repositories
Well then I guess I installed Peppermint.   I am befuddled myself.
#11 2024-02-15 22:30:42
herbie
Re: Repositories
Anyone have an idea of how I can change to Devuan repositories or is that not possible.
#12 2024-02-15 23:04:44
Re: Repositories
No, install a genuine Devuan.
Conversion is possible from Debian, see here: https://www.devuan.org/os/documentation … o-daedalus
#13 2024-02-15 23:25:41
Re: Repositories
@herbie . . . Are you aware that there is an official Peppermint Devuan Edition?
#14 2024-02-16 00:55:05
herbie
Re: Repositories
I'll be back sometime later with the correct install for now I'll just try some other os.
Thanks for all your help that this forum is noted for.
