Hello,
at the boot the 6.5.0-5-amd64 Kernel (I Use Devuan Testing) I become follow Problem with udevadm: livacl.so.1 not Found. After this, my RAID is not found and the Boot is Failure. When I use the 6.5.0-4-amd64 have not this Problem. The Library ist found in libacl.so.1 => /lib/x86_64-linux-gnu/libacl.so.1
How can I solve the problem?
how can I add the library to initramfs?
Thanks.
I have found a Workaround:
in the Directory /usr/share/initramfs-tools/hooks add a Script with follow Content:
PREREQ=""
prereqs()
echo "$PREREQ"
case $1 in
# get pre-requisites
prereqs)
prereqs
exit 0
esac
. /usr/share/initramfs-tools/hook-functions
cp -pnL /lib/x86_64-linux-gnu/libacl.so.1 ${DESTDIR}/lib/x86_64-linux-gnu/
and this Solve the Problem. But, Why the Default Hooks and Scripts of initramfs Programs not copy the libacl.so.1 to the initramfs?
I guess it has something to do with usrmerge, I would guess you will need to activate/install usrmerge. There are a few threads in this forum ...
I have installed usrmerge. The Problem started after a few days where I installed usrmerge.
IIUC usrmerge needs to be installed BEFORE moving to Excalibur or Ceres to avoid breakage. Will likely take some doing to unravel . . .
OK. The Problem was:
I must purge the usrmerge Packet (remove or reinstall is not enough!) and than install usrmerge. And I had to manually set the Link from /sbin/udevadm to /bin/udevadm.
Thanks for you Help.
