#1 2023-12-12 01:14:54
The-Amnesiac-Philosopher
A lightweight irc client???
Can anyone suggest a lightweight irc client that uses a GUI???
Thanks!
#2 2023-12-12 02:02:14
Re: A lightweight irc client???
I started using xchat with jessie now it's hexchat in chimaera. That's the default in Xfce . . . It is text based. No html. The on line version can be found at https://libera.chat/ but then you won't have logs locally. parazyd had to nursemaid me through the setup . . . I am not an irc nerd so can't help beyond that. Looking forward to seeing you there! You can share your humor in the #devuan-offtopic channel! Hehehe . . .
PS. Channel logs are here
#3 2023-12-12 05:43:20
Danielsan
Some friends of mine are developing this:
https://lab.abiscuola.com/irctk/dir?ci=tip
Otherwise I use catgirl over the terminal...
#4 2023-12-13 14:38:29
Thanks for the recommendations!
(cough-cough -->  --no-install-recommends) tongue
HAHAHAHA!
I did a search in the terminal for irc clients. Several of them looked interesting. For now, I've installed Hexchat. I'll revisit others later. smile
Thanks again!
#5 2023-12-13 16:10:53
Just use ERC.ERC is an IRC client. It is included in Emacs as of version 22.3
#6 2023-12-19 18:34:05
Hexchat is what i've been using for years, works great!
https://sourceforge.net/projects/vuu-do/ New Vuu-do isos uploaded April 2025!
