So I decided to try using a devuan base again for my custom gaming computer
in the past i've had trouble getting custom kernels to work with devuan
which is usually what causes me to jump into other distros
cause custom kernel patches allow for pretty extreme performance enhancements
but after reading some comments from my old post about installing a custom kernel
I decided to jump back into devuan and see if I can turn it into the Ultimate Gaming system
I decided to upload my install notes in case it may be helpful to others later on
I keep notes on an old backup drive to help remember all the nuances at a later date
I'm building a system for high performance general/desktop/gaming usage
and am working towards it with Crowz->Devuan-Daedalus base
to get the best possible performance linux has to offer right now
System specs...
I have a custom built gaming computer with mostly the latest hardware/features
i7 cpu
rtx graphics card
16gb ddr4 ram
water cooling, giant rainbow fans, nvme hard drive
gaming monitor, mouse/keyboard
I use a wifi card, even though ethernet is ideal
usually my install notes are a lot simpler/cleaner but I decided to add details
to help explain the whole process, and my thinking along the way
##### Crowz-Devuan-Daedalus ROOT Only Ultimate-Linux Hyper Drive Gaming Install Notes
## I started with crowz to provide a super lightweight base system
## and to take advantage of it's calamares installer to quickly
## install a base system on an f2fs partition for my ssd drive
## Crowz Live CD location
https://sourceforge.net/projects/crowz/files/
## the proper method for making a USB to install the ISO with...
## I always use gparted to prepare the USB for an iso
sudo apt install gparted
## in gparted make sure to select the correct drive to work on,
## or you'll lose your data
## for me the USB is registered by the operating system as "sdb"
## then inside gparted -> select the usb drive in the dropdown menu
##-> select Device -> create new partition table -> select gpt
## then right click the device or look in partition menu
## and format the drive as fat32
## then after the drive is formatted correctly I use DD, and
## finally sync to write the iso to the usb
## after installing linux perhaps hundreds of times, this
## is the method I have developed out of habit, and failing
## to do these exact steps, will lead to corrupt installs/iso's
## that can be difficult to troubleshoot
sudo dd if=crowz.5.0...iso of=/dev/sdb bs=1M status=progress; sync
## Booting the Crowz-Devuan Live CD
## (I used the open box version of crowz)
## user//pass for crowz to login is crowzlive//live
## (lower case l in the password)
## have to install in bios mode NOT uefi mode
## by choosing usb:usb NOT usb:uefi
## in boot menu to use calamares to install on f2fs
## for hyper speed
## in order to get crowz to boot
## i had to go down to "(failsafe)"
## in the live cd's grub menu and hit tab to edit the command line
## used to boot the live cd... editing everything out except for
## vmlinuz... components vga=normal initrd...
##I had to use the failsafe menu entry to edit because the default
## live menu entry couldn't be edited, and that was the only way
## I could get the system to boot. i.e. allowing the kernel
## to automatically configure things on it's own by deleting
## the default commands on the grub menu options
## after it finally boots
## and you use startx to start the graphical desktop environment
startx
## then inside crowz I had to use some skillfull
## clicking to wrangle the network connections icon
## to connect to the internet
## opened a terminal to install f2fs-tools after updating
## the package database to do so....
sudo apt update && sudo apt install f2fs-tools -y
## then after installing f2fs-tools it's time to install
## crowz-devuan
## right click the desktop or open the file manager
## navigate to -> applications -> system tools
## which are inside the file manager as opposed to an app menu
## and double click the installer (have to double click pretty fast)
## to run calamares
## selecting the target drive for installation
## manual partitionning
## create new partition table -> gpt
## create 8 mb parition -> unformatted -> with bios/grub flag
## create 2048 mb -> linux swap -> swap
## create desired size (i left some space for future dual boots
## cause linux gaming doesnt require the hundreds and hundreds of gigabytes
## that windows gaming does) (made my root around 500 gb...)
## create a 500 gb -> f2fs -> root parition -> mounted on /
## make sure the bootloader is installed onto /dev/nvme0n1
## which is the actual device as a whole and not a partition on it
## which is indicated by a little dropdown menu on the very bottom
## of the screen. (should be the default setting)
## and because I initialized the installer after booting the live cd
## in bios mode , and NOT uefi mode
## the installation works perfectly and I have an f2fs formatted ssd drive
## which is the fastest anyone can possibly get right now : D
## then the restart button in crowz didn't work(like many things in crowz, but that is a good thing)
## because of it's minimal approach it is as fast as a lightning bolt)
## so I had to manually restart with...
sudo shutdown -r now
## Made a root account in crowz
sudo passwd root
## installed xfce (which enables running the entire operating system,
## including the graphical environment as a root user. (open box would crash)
sudo tasksel
## restarted
## logged into xfce as root to start building on the crowz-devuan foundation
## my ideal gaming system
## with an f2fs partition you have to disable the file system check called fsck
## in the file system table called /etc/fstab
## and with the ultimate gaming computer you have to disable all automation anyways
## this is just the first step of many which also turn off automation
nano -w /etc/fstab
## then inside nano I unchecked the option that automatically invokes fsck
## at some future interval when I would bootup which would break my system
## and make it unbootable with an f2fs parition.... to make it look like
UUID=d88643b9-552k-4b21-8409-61caxe156bcf / f2fs defaults,lazytime 0 0
## [cntrl] + o , [enter]
## to save the file
## [cntrl] + x
## to exit nano
## then editing grub adding commands to default command line
mousepad /etc/default/grub
cpufreq.default_governor=performance mitigations=off rootwait
## make sure to save the file... I use rootwait with an nvme drive
## which is helpful to prevent lockups, that can happen depending
## on the configuration which changes over time
## I also use mitigations=off which is absolutely essential
## for getting the maximum performance in FPS gaming, other
## kinds of gaming it's not necessarry, but when every frame counts,
## and you need the best possible performance you need mitigations=off
## and ideally, like in my setup, to use the root account for everything
## update grub
update-grub
## add 32bit library support, and do first basic system upgrade
dpkg --add-architecture i386
apt update && apt upgrade -y
## reboot due to kernel upgrade from first upgrade
shutdown -r now
## always logging in as root manually
## the plan with this system is to install/use everything as root
## and apply unique workarounds to deal with the integrity/security of my system
## to get the highest gaming performance any linux system can offer right now
## installing graphics drivers
## the graphics drivers don't install exactly like they would on debian
## but it's essentially the exact same procedure with a few extra steps
apt install nvidia-driver
apt install nvidia-driver-libs:i386 nvidia-settings
apt install nvidia-vulkan-icd nvidia-vulkan-icd:i386
apt install libvulkan1
sudo reboot
## preparing the make the first backup, which when I stopped
## to make these notes too
sudo apt install ggparted timeshift lynx okular
apt install okular-extra-backends unrar
apt install wine winetricks gamemode lutris steam -y
apt install gufw
apt install vlc
## some simple hacks to run programs as root
## quoted directly from those websites...
## simple hack to allow vlc to run as root
## to play background music while you run circles
## around people in online gaming, and make them look silly
This is what worked for me. No compilation required.
sed -i 's/geteuid/getppid/' /usr/bin/vlc
Using VLC media player 2.0.3 Twoflower on a Raspberry Pi.
Explanation: The initialization script check if the UID is equals to zero. Zero is reserved for the root user. Using sed to replace geteuid for getppid fools the initialization script because it is always > 0.
While running the VLC as root is not recommended, it works. Be aware of the risks and obviously do not do it for production environments.
For Freebsd and other finicky unices and macos use the proper full syntax:
sed -i '' 's/geteuid/getppid/' /usr/local/bin/vlc
## simple hack for steam to run as root
OMG.
Open /usr/bin/steam
Comment or delete such lines:
if [ "$(id -u)" == "0" ]; then
show_message --error $"Cannot run as root user"
exit 1
fi
## I didnt have to apply this hack actually
## I think because I installed steam logged
## into the desktop environment under the root account...
## at this point I have a perfect base for
## my Ultimate-Linux Hyper Drive Gaming system
## and have little left to do other than basic desktop tweaks
## installing a custom kernel, and more system tweaks to
## get even more performance
## Generally the older kernels (i can't remember the versioning schemes,
## but basically the point upgrades stable distributions like devuan/debian use
## are actually faster, so you want to focus on those, and the same is true
## for drivers. Newer isn't actually faster, or better for performance...
## I actually miss the bullseye kernel/nvidia driver combo
## which is like versions 5.10 and 425 because they perform very well
## compared to the newer stuff
## first I will try using the basic liquorix kernel with my Crowz-Devuan Hybrid build
## which has patches for gaming, and later I will attempt to install a custom gaming
## kernel, or the patches for it using some guides online
## installing Devuan using the Crowz live cd actually made for the leanest
## base system anyone can possibly get right now, that is satisfactory for gaming,
## and after installing xfce, logging into it, the system is only using around 686-700 mb
## of ram, which is extremely impressive. This equates to faster system response time
## which is necessary for competitive gaming
## I also decided to stick with alsa for sound instead of getting pulesudio, as per
## advice on the devuan forum, alsa by itself is sufficient/ has very low performance overhead,
## which is ideal for my use case
## Using the root account for everything literally doubles my download speed, and
## system response time across the board. Everything is faster, more efficient,
## and super speedy. As I'm writing these notes im getting 200 MB/s download speed
## on my wifi, downloading the first game I will be testing the system with, which
## is literally double the speed I have ever gotten in a regular user account.
## As a regular user this download might of taken an hour and a half, whereas
## under the root account I've got the game up and running in less than 20 minutes.
## And this is essentially how using the root account is going to benefit all of the
## system operations compared to a regular user account. Everything will be twice
## as fast, including beating people up on online gaming ;D
## with f2fs, devuan, some basic system tweaks for performance,
## on top of my mid-range gaming setup
## my computer is literally as fast as a lightning bolt,
## This setup is literally like hyper-drive, file system operations are instantaneous
## and everything else is close behind instantaneous performance : D
## So like I usually do with debian
## I install a liquorix kernel, which is easy with it.
## On arch linux I would jump right into xanmod installed from aur
## or start compiling a custom tkg-kernel, but this process doesn't
## work as simply with debian, but anyways I will try to get these
## higher performance alternatives working later
## I think liquorix has f-sync patched into it
## which can be a major performance improvement,
## if it does, it is satisfactory as the main kernel
## to use for gaming, and I wont need to attempt to compile
## my own with custom patches
curl -s 'https://liquorix.net/install-liquorix.sh' | sudo bash
## the download -> install script
## for liquorix kernel fails with these error messages
E: The repository 'https://liquorix.net/debian n/a Release' does not have a Release file.
## which is fixed by going into directory...
cd /etc/apt/sources.list.d
## and editing the sources adding in -> bookworm -> instead of "n/a"
## to look like this...
deb [arch=amd64 signed-by=/etc/apt/keyrings/liquorix-keyring.gpg] https://liquorix.net/debian bookworm main
deb-src [arch=amd64 signed-by=/etc/apt/keyrings/liquorix-keyring.gpg] https://liquorix.net/debian bookworm main
## update the package database
apt update
## and ran an apt search to pick out a kernel
## from my newly added liquorix repositories
apt update
## and installed a new custom liquorix kernel
apt install linux-image-liquorix-amd64
## reboot
shutdown -r now
## it seems like liquorix has 6.4 and 6.6 kernels
## and devuan has 6.1 by default, which could be a problem
## if certain programs are designed to only work with older kernels
## and upon first reboot
## it seems liquorix isn't working and it's not clear why
## but it looks like a variety of programs are running into each other
## locking up the system
## so I reboot into devuan's default kernel
## using the advanced options from grub menu to select it
## at this point it's going to take some troubleshooting
## and tinkering around to tweak the system for even more
## performance, but with this basic setup
## I am already in a great position to start gaming
## using cat /proc/cpuinfo and grep
## to see if performance mode in grub is applying to the kernel
root@ity:~# cat /proc/cpuinfo | grep MHz
cpu MHz : 800.000
cpu MHz : 800.000
cpu MHz : 800.000
cpu MHz : 800.000
cpu MHz : 800.000
cpu MHz : 800.000
cpu MHz : 800.000
cpu MHz : 800.000
## and it isn't
## looking for commands to alter the cpu mode
## I noticed some people metioning services altering
## the cpu_freq mode and decided to investigate it
root@ity:~# service --status-all
[ ? ] alsa-utils
[ - ] anacron
[ + ] apparmor
[ - ] bootlogd
[ - ] bootlogs
[ - ] bootmisc.sh
[ - ] brightness
[ - ] checkfs.sh
[ - ] checkroot-bootclean.sh
[ - ] checkroot.sh
[ + ] connman
[ ? ] cpufrequtils
[ + ] cron
[ + ] dbus
[ + ] elogind
[ + ] eudev
[ - ] hostname.sh
[ ? ] hwclock.sh
[ - ] killprocs
[ ? ] kmod
[ - ] live-config
[ - ] lm-sensors
[ ? ] loadcpufreq
[ ? ] mount-configfs
[ - ] mountall-bootclean.sh
[ - ] mountall.sh
[ - ] mountdevsubfs.sh
[ - ] mountkernfs.sh
[ - ] mountnfs-bootclean.sh
[ - ] mountnfs.sh
[ ? ] networking
[ + ] ntpsec
[ - ] procps
[ - ] rc.local
[ - ] rmnologin
[ - ] rsync
[ + ] rsyslog
[ - ] sendsigs
[ + ] slim
[ - ] stop-bootlogd
[ - ] stop-bootlogd-single
[ - ] sudo
[ + ] ufw
[ - ] umountfs
[ - ] umountnfs.sh
[ - ] umountroot
[ - ] urandom
[ + ] uuidd
[ - ] x11-common
## looking in /etc/init.d
## I see the cpufrequtils init config
## and edit the line to default to performance mode and reboot
## to see if it alters the situation
root@ity:~# cat /sys/devices/system/cpu/cpu0/cpufreq/scaling_available_governors
performance powersave
## editing /etc/init.d/cpufrequtils
mousepad /etc/init.d/cpufrequtils
ENABLE="true"
GOVERNOR="performance"
## I'm not really used to dealing with services in non-systemd or openrc systems
## so I'll have to learn more about devuans way of doing things
## I went back and tried editing the file again like this
## after first reboot it wasnt working...
ENABLE="true"
MAX_SPEED="3600000"
MIN_SPEED="3600000"
## I had to find out the min and max cpu frequency values using...
cat /sys/devices/system/cpu/cpufreq/policy0/cpuinfo_max_freq
cat /sys/devices/system/cpu/cpufreq/policy0/cpuinfo_min_freq
reboot
## and upon rebooting again I noticed the system is working
## as fast as a lightning bolt which makes me smile really widely : D D
## and checking the reported cpu frequencies reported by the kernel
## I see now everything is working appropriately, and I'm locked in at 3.6GHz
## for gaming : D
cpu MHz : 3600.000
cpu MHz : 3600.000
cpu MHz : 3600.000
cpu MHz : 3600.000
cpu MHz : 3600.000
cpu MHz : 3600.000
cpu MHz : 3600.000
cpu MHz : 3600.000
## at this point I remembered trying to use the liquorix kernel before
## and it seemed to run startup programs out of sync with each other creating
## a lockup scenario, and failing to get to the desktop envrionment, so I decided
## to reboot into it to see if locking down the cpu frequency altered the situation
## this time the system booted up properly, without programs running into each other
## and overlapping, but I got stuck at a login terminal, instead of booting
## into my desktop environment which is always what happens when I try to
## install custom kernels on devuan... : ' (
## anyways I will figure it out eventually and get it working
## when I tweak things some more and get more time to test different configurations
## I might update the post
## edit... 6 hours later
## okay I think I have it figured out now
## now here's some random notes with no explanation
init─┬─accounts-daemon───3*[{accounts-daemon}]
├─connmand
├─console-kit-dae───5*[{console-kit-dae}]
├─cron
├─2*[dbus-daemon]
├─dbus-launch
├─dunst───3*[{dunst}]
├─elogind-daemon
├─6*[getty]
├─gpg-agent
├─ntpd
├─polkitd───3*[{polkitd}]
├─rsyslogd───3*[{rsyslogd}]
├─slim─┬─Xorg───{Xorg}
│ └─ck-launch-sessi───xfce4-session─┬─Thunar───3*[{Thunar}]
│ ├─xfce4-panel─┬─panel-14-action──+++
│ │ ├─panel-6-systray──+++
│ │ ├─panel-8-pulseau──+++
│ │ ├─xfce4-terminal─┬─+
│ │ └─3*[{xfce4-panel}]
│ ├─xfdesktop───3*[{xfdesktop}]
│ ├─xfsettingsd───2*[{xfsettingsd}]
│ ├─xfwm4───2*[{xfwm4}]
│ └─3*[{xfce4-session}]
├─udevd───udevd
├─upowerd───3*[{upowerd}]
├─uuidd
├─wpa_supplicant
└─xfconfd───3*[{xfconfd}]
root@ity:~#
"/home/xfin/.local/share/xorg/Xorg.0.log"
[ 25.469] (EE) NVIDIA: Failed to initialize the NVIDIA kernel module. Please see the
[ 25.469] (EE) NVIDIA: system's kernel log for additional error messages and
[ 25.469] (EE) NVIDIA: consult the NVIDIA README for details.
[ 25.469] (EE) No devices detected.
[ 25.469] (EE)
Fatal server error:
[ 25.469] (EE) no screens found(EE)
[ 25.469] (EE)
Please consult the The X.Org Foundation support
at http://wiki.x.org
apt-get --reinstall install nvidia-driver
https://github.com/Frogging-Family/linux-tkg
https://github.com/Frogging-Family/nvidia-all
## apt install makepkg
dkms: autoinstall for kernel 6.6.2-1-liquorix-amd64 was skipped since the kernel headers for this kernel do not seem to be installed.
root@ity:~/nvidia-all# apt install linux-headers-liquorix-amd64 linux-image-liquorix-amd64
Building module:
Cleaning build area...
env NV_VERBOSE=1 make -j8 modules KERNEL_UNAME=6.6.2-1-liquorix-amd64........(bad exit status: 2)
Error! Bad return status for module build on kernel: 6.6.2-1-liquorix-amd64 (x86_64)
Consult /var/lib/dkms/nvidia-current/525.125.06/build/make.log for more information.
Error! One or more modules failed to install during autoinstall.
Refer to previous errors for more information.
dkms: autoinstall for kernel: 6.6.2-1-liquorix-amd64 failed!
run-parts: /etc/kernel/header_postinst.d/dkms exited with return code 11
Failed to process /etc/kernel/header_postinst.d at /var/lib/dpkg/info/linux-headers-6.6.2-1-liquorix-amd64.postinst line 11.
dpkg: error processing package linux-headers-6.6.2-1-liquorix-amd64 (--configure):
installed linux-headers-6.6.2-1-liquorix-amd64 package post-installation script subprocess returned error exit status 1
dpkg: dependency problems prevent configuration of linux-headers-liquorix-amd64:
linux-headers-liquorix-amd64 depends on linux-headers-6.6.2-1-liquorix-amd64 (= 6.6-2.1~bookworm); however:
Package linux-headers-6.6.2-1-liquorix-amd64 is not configured yet.
dpkg: error processing package linux-headers-liquorix-amd64 (--configure):
Processing triggers for libc-bin (2.36-9+deb12u3) ...
root@ity:~/nvidia-all# sudo apt install linux-headers-6.6.2-1-liquorix-amd64
https://wiki.debian.org/NvidiaGraphicsDrivers
Before installing the drivers, you must obtain the proper kernel headers for the NVIDIA driver to build with.
https://dev1galaxy.org/viewtopic.php?id=5415
https://dev1galaxy.org/viewtopic.php?id=564
ls
~/linux-tkg/linux-src-git
-> Configuration done.
-> Installing udev rule for winesync
-> Adding winesync to '/etc/modules-load.d' for auto-loading by systemd - Password prompt incoming!
-> Enabled ccache
-> Building kernel DEB packages
UPD include/config/kernel.release
make clean
sh ./scripts/package/mkdebian
Using default distribution of 'unstable' in the changelog
Install lsb-release or set $KDEB_CHANGELOG_DIST explicitly
TAR linux-upstream.tar.gz
origversion=$(dpkg-parsechangelog -SVersion |sed 's/-[^-]*$//');\
mv linux-upstream.tar.gz ../linux-upstream_${origversion}.orig.tar.gz
Can't locate Term/ANSIColor.pm in @INC (you may need to install the Term::ANSIColor module) (@INC contains: /etc/perl /usr/local/lib/x86_64-linux-gnu/perl/5.36.0 /usr/local/share/perl/5.36.0 /usr/lib/x86_64-linux-gnu/perl5/5.36 /usr/share/perl5 /usr/lib/x86_64-linux-gnu/perl-base /usr/lib/x86_64-linux-gnu/perl/5.36 /usr/share/perl/5.36 /usr/local/lib/site_perl) at /usr/share/perl5/Dpkg/ErrorHandling.pm line 71.
dpkg-buildpackage -r"fakeroot -u" -a$(cat debian/arch) -i.git -us -uc
Can't locate File/Copy.pm in @INC (you may need to install the File::Copy module) (@INC contains: /etc/perl /usr/local/lib/x86_64-linux-gnu/perl/5.36.0 /usr/local/share/perl/5.36.0 /usr/lib/x86_64-linux-gnu/perl5/5.36 /usr/share/perl5 /usr/lib/x86_64-linux-gnu/perl-base /usr/lib/x86_64-linux-gnu/perl/5.36 /usr/share/perl/5.36 /usr/local/lib/site_perl) at /usr/bin/dpkg-buildpackage line 28.
BEGIN failed--compilation aborted at /usr/bin/dpkg-buildpackage line 28.
make[1]: *** [scripts/Makefile.package:80: deb-pkg] Error 2
make: *** [Makefile:1656: deb-pkg] Error 2
-> exit cleanup done
Term::ANSIColor was first included with Perl in Perl 5.6.0.
root@ity:/etc# perl -v
This is perl 5, version 36, subversion 0 (v5.36.0)
## I figured out that the NVIDIA kernel module didn't appear to be loading properly
## with the liquorix kernel, so I figured that I didn't install it properly, so I reloaded my timeshift
## backup in order to make a clean slate with devuan in order to try to get it working again
## then I installed first the liquorix-headers file from it's repository
## which failed to build the kernel modules
## then the liquorix kernel, and then some other stuff I can't remember
## all of which failed
## then I tried using the tkg-linux source files and tkg-nvidia source files
## to build a custom kernel, which I think failed because in devuan there is
## only perl version 3.36 and it expects version 3.6
## that all comprised maybe 3-4 hours after 2 hours of reading documentation
## and doing basic configurations all over the place
## so i think I'm on the right track though and am toying with
## the idea of using a how-to on the forum for building a kernel on devuan
## as a point of reference for getting a custom-gaming kernel working on here
## and maybe if I update some packages from debians bookworm repository
## I can get the tkg-linux scripts to work which have all of that built in, but
## expect package versions to be more up-to-date like arch linux
## I think a lot of the problems I have been running into have revolved
## around versioning/dependency errors that are mismatched between
## all the various distros/development cycles/and development projects
## but based on my extensive experience, having tested and worked with
## basically 80% of all the linux distros over the years I think im on the right
## track with using Crowz->Devuan-Daedalus for literally the Ultimate Linux Hyper Drive Gaming System
## right now my system is already so lightning fast I want to skip all the technical work
## and just put it to work running circles around all those snarky windows users in some online games
## Based on my experience I think there is no better alternative to get the highest possible performance
## for linux gaming right now, I just have to work out more technical details, get more experience using devuan
## to fully unlock it's potential
## edit 12 hours after installation
## I finally got a custom gaming kernel working
## I figured out after endless trial and error, and alternate configurations
## You need an equal kernel version to what devuan is using
## and you need to install the kernel headers first(I think?)
## or nvidia's module wont properly build, or it's some other problem,
## I don't know because i keep getting the same error messages now,
## and the same exact error messages apparently represent completely different problems!
## but hey that is linux, it's totally insane...
## to install the xanmod kernel for devuan I had to...
## quoted mostly from the xanmod website...
1. Register the PGP key:
wget -qO - https://dl.xanmod.org/archive.key | sudo gpg --dearmor -o /usr/share/keyrings/xanmod-archive-keyring.gpg
2. Add the repository:
echo 'deb [signed-by=/usr/share/keyrings/xanmod-archive-keyring.gpg] http://deb.xanmod.org releases main' | sudo tee /etc/apt/sources.list.d/xanmod-release.list
##. Then update
apt update
## Then use apt search to find the right kernel for your system
## (turn on unlimited scrolling in your terminal program)
## or like apt search xanmod | grep 6.1
apt search xanmod
### Then install
apt install linux-headers-6.1.35-x64v3-xanmod1 linux-image-6.1.35-x64v3-xanmod1
## my cpu architecture is x86_64 v3 for other people it would be different....but what is also important
## is that I picked out a kernel version next to what devuan is using i.e. 6.1
## so my graphics driver could properly build against it,
## anyways it's a real ugly duckling this devuan system, it's going to take a lot of love to clean it up and
## tweak it out, but this is the absolute leanest and meanest Linux gaming system in the entire linux Universe
## she sits at 487 MB of RAM usage after login, with no apps open, in the xfce desktop environment
## which is literally almost exactly two times
## less than all of the competitors I have tried out.
## This system with Xanmod -> Crowz-Devuan -> on top of an ssd with F2FS
## and some mid range gaming hardware is literally screaming fast,
## and runs like a super car, I can barely control, it's so sensitive, and powerful
These are the error messages I keep getting when installing a custom kernel,
but it appears the nvidia module(the graphics driver for my graphics driver) is installing properly,
and my wifi, so from my end user perspective everything works great!
root@ity:~# apt install linux-headers-6.1.13-x64v3-rt7-xanmod1 linux-image-6.1.13-x64v3-rt7-xanmod1
0 upgraded, 2 newly installed, 0 to remove and 0 not upgraded.
Need to get 83.0 MB of archives.
After this operation, 460 MB of additional disk space will be used.
Get:1 [url]http://deb.xanmod.org[/url] releases/main amd64 linux-headers-6.1.13-x64v3-rt7-xanmod1 amd64 6.1.13-x64v3-rt7-xanmod1-0~20230223.8aba792 [8,972 kB]
Get:2 [url]http://deb.xanmod.org[/url] releases/main amd64 linux-image-6.1.13-x64v3-rt7-xanmod1 amd64 6.1.13-x64v3-rt7-xanmod1-0~20230223.8aba792 [74.1 MB]
Fetched 83.0 MB in 8s (9,941 kB/s)
Selecting previously unselected package linux-headers-6.1.13-x64v3-rt7-xanmod1.
(Reading database ... 137844 files and directories currently installed.)
Preparing to unpack .../linux-headers-6.1.13-x64v3-rt7-xanmod1_6.1.13-x64v3-rt7-
xanmod1-0~20230223.8aba792_amd64.deb ...
Unpacking linux-headers-6.1.13-x64v3-rt7-xanmod1 (6.1.13-x64v3-rt7-xanmod1-0~202
30223.8aba792) ...
Selecting previously unselected package linux-image-6.1.13-x64v3-rt7-xanmod1.
Preparing to unpack .../linux-image-6.1.13-x64v3-rt7-xanmod1_6.1.13-x64v3-rt7-xa
Unpacking linux-image-6.1.13-x64v3-rt7-xanmod1 (6.1.13-x64v3-rt7-xanmod1-0~20230
223.8aba792) ...
Setting up linux-headers-6.1.13-x64v3-rt7-xanmod1 (6.1.13-x64v3-rt7-xanmod1-0~20
230223.8aba792) ...
Setting up linux-image-6.1.13-x64v3-rt7-xanmod1 (6.1.13-x64v3-rt7-xanmod1-0~2023
0223.8aba792) ...
dkms: running auto installation service for kernel 6.1.13-x64v3-rt7-xanmod1.
Sign command: /lib/modules/6.1.13-x64v3-rt7-xanmod1/build/scripts/sign-file
Signing key: /var/lib/dkms/mok.key
Public certificate (MOK): /var/lib/dkms/mok.pub
Error! The /var/lib/dkms/nvidia-current/525.125.06/6.1.13-x64v3-rt7-xanmod1/x86_
64/dkms.conf for module nvidia-current includes a BUILD_EXCLUSIVE directive whic
h does not match this kernel/arch/config.
This indicates that it should not be built.
dkms: autoinstall for kernel: 6.1.13-x64v3-rt7-xanmod1 failed!
run-parts: /etc/kernel/postinst.d/dkms exited with return code 11
update-initramfs: Generating /boot/initrd.img-6.1.13-x64v3-rt7-xanmod1
I: The initramfs will attempt to resume from /dev/nvme0n1p2
I: (UUID=a55c7c8d-2d4b-45a7-a449-fe3825c1f0a4)
I: Set the RESUME variable to override this.
Warning: Not updating LILO; /etc/lilo.conf not found!
Generating grub configuration file ...
Found background: /usr/share/images/desktop-base/crowz-grub.png
Found background image: /usr/share/images/desktop-base/crowz-grub.png
Found linux image: /boot/vmlinuz-6.1.35-x64v3-xanmod1
Found initrd image: /boot/initrd.img-6.1.35-x64v3-xanmod1
Found linux image: /boot/vmlinuz-6.1.13-x64v3-rt7-xanmod1
Found initrd image: /boot/initrd.img-6.1.13-x64v3-rt7-xanmod1
Found linux image: /boot/vmlinuz-6.1.0-13-amd64
Found initrd image: /boot/initrd.img-6.1.0-13-amd64
Warning: os-prober will not be executed to detect other bootable partitions.
Systems on them will not be added to the GRUB boot configuration.
Check GRUB_DISABLE_OS_PROBER documentation entry.
done
dpkg: error processing package linux-image-6.1.13-x64v3-rt7-xanmod1 (--configure
installed linux-image-6.1.13-x64v3-rt7-xanmod1 package post-installation script
E: Sub-process /usr/bin/dpkg returned an error code (1)Edit: so this 6.1 RT kernel I just installed does not work, cant get to the graphical envrionment,
while displaying the same error messages as my other attempts to install custom kernels,
with one caveat... the 6.1.35 xanmod kernel is working perfectly, again, despite displaying
the same error messages.
Edit2: so I went ahead and tried installing a different version: the 6.1.33 RT kernel from xanmods repo's
and this time gathering some error logs to see what is happening. After booting into it I saved dmesg
to a file on the desktop to see what is going wrong during the boot process that prevents me from getting to
the graphical desktop envrionment. Keeping in mind that after getting nearly identical error messages,
my install of the 6.1.35 is working just fine.
root@ity:~# apt install linux-headers-6.1.33-rt11-x64v3-xanmod1 linux-image-6.1.33-rt11-x64v3-xanmod1
Need to get 83.1 MB of archives.
Get:1 http://deb.xanmod.org releases/main amd64 linux-headers-6.1.33-rt11-x64v3-xanmod1 amd64 6.1.33-rt11-x64v3-xanmod1-0~20230613.b891f3a [8,977 kB]
Get:2 http://deb.xanmod.org releases/main amd64 linux-image-6.1.33-rt11-x64v3-xanmod1 amd64 6.1.33-rt11-x64v3-xanmod1-0~20230613.b891f3a [74.1 MB]
Fetched 83.1 MB in 9s (8,996 kB/s)
Selecting previously unselected package linux-headers-6.1.33-rt11-x64v3-xanmod1.
Preparing to unpack .../linux-headers-6.1.33-rt11-x64v3-xanmod1_6.1.33-rt11-x64v3-xanmod1-0~20230613.b891f3a_amd64.deb ...
Unpacking linux-headers-6.1.33-rt11-x64v3-xanmod1 (6.1.33-rt11-x64v3-xanmod1-0~20230613.b891f3a) ...
Selecting previously unselected package linux-image-6.1.33-rt11-x64v3-xanmod1.
Preparing to unpack .../linux-image-6.1.33-rt11-x64v3-xanmod1_6.1.33-rt11-x64v3-xanmod1-0~20230613.b891f3a_amd64.deb ...
Unpacking linux-image-6.1.33-rt11-x64v3-xanmod1 (6.1.33-rt11-x64v3-xanmod1-0~20230613.b891f3a) ...
Setting up linux-image-6.1.33-rt11-x64v3-xanmod1 (6.1.33-rt11-x64v3-xanmod1-0~20230613.b891f3a) ...
dkms: running auto installation service for kernel 6.1.33-rt11-x64v3-xanmod1.
Sign command: /lib/modules/6.1.33-rt11-x64v3-xanmod1/build/scripts/sign-file
Error! The /var/lib/dkms/nvidia-current/525.125.06/6.1.33-rt11-x64v3-xanmod1/x86_64/dkms.conf for module nvidia-current includes a BUILD_EXCLUSIVE directive which does no
dkms: autoinstall for kernel: 6.1.33-rt11-x64v3-xanmod1 failed!
update-initramfs: Generating /boot/initrd.img-6.1.33-rt11-x64v3-xanmod1
Found linux image: /boot/vmlinuz-6.1.33-rt11-x64v3-xanmod1
Found initrd image: /boot/initrd.img-6.1.33-rt11-x64v3-xanmod1
done
dpkg: error processing package linux-image-6.1.33-rt11-x64v3-xanmod1 (--configure):
installed linux-image-6.1.33-rt11-x64v3-xanmod1 package post-installation script subprocess returned error exit status 1
Setting up linux-headers-6.1.33-rt11-x64v3-xanmod1 (6.1.33-rt11-x64v3-xanmod1-0~20230613.b891f3a) ...
root@ity:~#
[ 0.000000] microcode: microcode updated early to revision 0xfa, date = 2023-02-27
[ 0.000000] Linux version 6.1.33-rt11-x64v3-xanmod1 (root@mascote) (gcc-12 (Debian 12.2.0-14) 12.2.0, GNU ld (GNU Binutils for Debian) 2.40) #0~20230613.b891f3a SMP PREEMPT_RT Tue Jun 13 10:08:28 UTC 2023
[ 0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-6.1.33-rt11-x64v3-xanmod1 root=UUID=d38623b9-542a-4b21-8409-60ca5e1563cf ro initrd=/install/gtk/initrd.gz resume=UUID=a55c7c8d-2d4b-45a7-a449-fe3825c1f0a4 mitigations=off mds=off tsx_async_abort=off rootwait
[ 0.000000] KERNEL supported cpus:
[ 0.000000] Intel GenuineIntel
[ 0.000000] AMD AuthenticAMD
[ 0.000000] Hygon HygonGenuine
[ 0.000000] Centaur CentaurHauls
[ 0.000000] zhaoxin Shanghai
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x008: 'MPX bounds registers'
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x010: 'MPX CSR'
[ 0.000000] x86/fpu: xstate_offset[2]: 576, xstate_sizes[2]: 256
[ 0.000000] x86/fpu: xstate_offset[3]: 832, xstate_sizes[3]: 64
[ 0.000000] x86/fpu: xstate_offset[4]: 896, xstate_sizes[4]: 64
[ 0.000000] x86/fpu: Enabled xstate features 0x1f, context size is 960 bytes, using 'compacted' format.
[ 0.000000] signal: max sigframe size: 2032
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000009d3ff] usable
[ 0.000000] BIOS-e820: [mem 0x000000000009d400-0x000000000009ffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000000e0000-0x00000000000fffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000000100000-0x000000003ce99fff] usable
[ 0.000000] BIOS-e820: [mem 0x000000003ce9a000-0x000000003e705fff] reserved
[ 0.000000] BIOS-e820: [mem 0x000000003e706000-0x000000003e898fff] usable
[ 0.000000] BIOS-e820: [mem 0x000000003e899000-0x000000003ec5bfff] ACPI NVS
[ 0.000000] BIOS-e820: [mem 0x000000003ec5c000-0x000000003f40efff] reserved
[ 0.000000] BIOS-e820: [mem 0x000000003f40f000-0x000000003f40ffff] usable
[ 0.000000] BIOS-e820: [mem 0x000000003f410000-0x000000003fffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000e0000000-0x00000000efffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fe000000-0x00000000fe010fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fec00000-0x00000000fec00fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fed00000-0x00000000fed03fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fee00000-0x00000000fee00fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000ff000000-0x00000000ffffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000100000000-0x00000006bdffffff] usable
[ 0.000000] NX (Execute Disable) protection: active
[ 0.000000] SMBIOS 3.1.1 present.
[ 0.000000] DMI: To Be Filled By O.E.M. To Be Filled By O.E.M./Z390 Phantom Gaming 4S/ac, BIOS L1.21A 06/18/2020
[ 0.000000] tsc: Detected 3600.000 MHz processor
[ 0.000439] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[ 0.000441] e820: remove [mem 0x000a0000-0x000fffff] usable
[ 0.000447] last_pfn = 0x6be000 max_arch_pfn = 0x400000000
[ 0.000522] x86/PAT: Configuration [0-7]: WB WC UC- UC WB WP UC- WT
[ 0.000889] last_pfn = 0x3f410 max_arch_pfn = 0x400000000
[ 0.006770] found SMP MP-table at [mem 0x000fce50-0x000fce5f]
[ 0.006782] Using GB pages for direct mapping
[ 0.006979] RAMDISK: [mem 0x3351b000-0x35a84fff]
[ 0.006983] ACPI: Early table checksum verification disabled
[ 0.006985] ACPI: RSDP 0x00000000000F05B0 000024 (v02 ALASKA)
[ 0.006987] ACPI: XSDT 0x000000003EBAC0A0 0000C4 (v01 ALASKA A M I 01072009 AMI 00010013)
[ 0.006991] ACPI: FACP 0x000000003EBEDB48 000114 (v06 ALASKA A M I 01072009 AMI 00010013)
[ 0.006995] ACPI: DSDT 0x000000003EBAC200 041948 (v02 ALASKA A M I 01072009 INTL 20160527)
[ 0.006997] ACPI: FACS 0x000000003EC5B080 000040
[ 0.006998] ACPI: APIC 0x000000003EBEDC60 0000BC (v04 ALASKA A M I 01072009 AMI 00010013)
[ 0.007000] ACPI: FPDT 0x000000003EBEDD20 000044 (v01 ALASKA A M I 01072009 AMI 00010013)
[ 0.007002] ACPI: FIDT 0x000000003EBEDD68 00009C (v01 ALASKA A M I 01072009 AMI 00010013)
[ 0.007004] ACPI: MCFG 0x000000003EBEDE08 00003C (v01 ALASKA A M I 01072009 MSFT 00000097)
[ 0.007005] ACPI: SSDT 0x000000003EBEDE48 000378 (v01 SataRe SataTabl 00001000 INTL 20160527)
[ 0.007007] ACPI: SSDT 0x000000003EBEE1C0 001B1C (v02 CpuRef CpuSsdt 00003000 INTL 20160527)
[ 0.007010] ACPI: AAFT 0x000000003EBEFCE0 000264 (v01 ALASKA OEMAAFT 01072009 MSFT 00000097)
[ 0.007011] ACPI: SSDT 0x000000003EBEFF48 0031C6 (v02 SaSsdt SaSsdt 00003000 INTL 20160527)
[ 0.007013] ACPI: SSDT 0x000000003EBF3110 00231B (v02 PegSsd PegSsdt 00001000 INTL 20160527)
[ 0.007015] ACPI: HPET 0x000000003EBF5430 000038 (v01 ALASKA A M I 00000002 01000013)
[ 0.007017] ACPI: SSDT 0x000000003EBF5468 002950 (v02 INTEL xh_cfsd4 00000000 INTL 20160527)
[ 0.007019] ACPI: UEFI 0x000000003EBF7DB8 000042 (v01 ALASKA A M I 00000002 01000013)
[ 0.007020] ACPI: LPIT 0x000000003EBF7E00 00005C (v01 ALASKA A M I 00000002 01000013)
[ 0.007022] ACPI: SSDT 0x000000003EBF7E60 0014E2 (v02 ALASKA TbtTypeC 00000000 INTL 20160527)
[ 0.007024] ACPI: DBGP 0x000000003EBF9348 000034 (v01 ALASKA A M I 00000002 01000013)
[ 0.007026] ACPI: DBG2 0x000000003EBF9380 000054 (v00 ALASKA A M I 00000002 01000013)
[ 0.007027] ACPI: SSDT 0x000000003EBF93D8 001B67 (v02 ALASKA UsbCTabl 00001000 INTL 20160527)
[ 0.007029] ACPI: SSDT 0x000000003EBFAF40 000144 (v02 Intel ADebTabl 00001000 INTL 20160527)
[ 0.007031] ACPI: WSMT 0x000000003EBFB088 000028 (v01 ALASKA A M I 01072009 AMI 00010013)
[ 0.007032] ACPI: Reserving FACP table memory at [mem 0x3ebedb48-0x3ebedc5b]
[ 0.007033] ACPI: Reserving DSDT table memory at [mem 0x3ebac200-0x3ebedb47]
[ 0.007034] ACPI: Reserving FACS table memory at [mem 0x3ec5b080-0x3ec5b0bf]
[ 0.007035] ACPI: Reserving APIC table memory at [mem 0x3ebedc60-0x3ebedd1b]
[ 0.007035] ACPI: Reserving FPDT table memory at [mem 0x3ebedd20-0x3ebedd63]
[ 0.007036] ACPI: Reserving FIDT table memory at [mem 0x3ebedd68-0x3ebede03]
[ 0.007036] ACPI: Reserving MCFG table memory at [mem 0x3ebede08-0x3ebede43]
[ 0.007037] ACPI: Reserving SSDT table memory at [mem 0x3ebede48-0x3ebee1bf]
[ 0.007037] ACPI: Reserving SSDT table memory at [mem 0x3ebee1c0-0x3ebefcdb]
[ 0.007038] ACPI: Reserving AAFT table memory at [mem 0x3ebefce0-0x3ebeff43]
[ 0.007039] ACPI: Reserving SSDT table memory at [mem 0x3ebeff48-0x3ebf310d]
[ 0.007039] ACPI: Reserving SSDT table memory at [mem 0x3ebf3110-0x3ebf542a]
[ 0.007040] ACPI: Reserving HPET table memory at [mem 0x3ebf5430-0x3ebf5467]
[ 0.007040] ACPI: Reserving SSDT table memory at [mem 0x3ebf5468-0x3ebf7db7]
[ 0.007041] ACPI: Reserving UEFI table memory at [mem 0x3ebf7db8-0x3ebf7df9]
[ 0.007041] ACPI: Reserving LPIT table memory at [mem 0x3ebf7e00-0x3ebf7e5b]
[ 0.007042] ACPI: Reserving SSDT table memory at [mem 0x3ebf7e60-0x3ebf9341]
[ 0.007042] ACPI: Reserving DBGP table memory at [mem 0x3ebf9348-0x3ebf937b]
[ 0.007043] ACPI: Reserving DBG2 table memory at [mem 0x3ebf9380-0x3ebf93d3]
[ 0.007044] ACPI: Reserving SSDT table memory at [mem 0x3ebf93d8-0x3ebfaf3e]
[ 0.007044] ACPI: Reserving SSDT table memory at [mem 0x3ebfaf40-0x3ebfb083]
[ 0.007045] ACPI: Reserving WSMT table memory at [mem 0x3ebfb088-0x3ebfb0af]
[ 0.007311] No NUMA configuration found
[ 0.007311] Faking a node at [mem 0x0000000000000000-0x00000006bdffffff]
[ 0.007319] NODE_DATA(0) allocated [mem 0x6bdfd5000-0x6bdffffff]
[ 0.007364] Zone ranges:
[ 0.007365] DMA [mem 0x0000000000001000-0x0000000000ffffff]
[ 0.007366] DMA32 [mem 0x0000000001000000-0x00000000ffffffff]
[ 0.007367] Normal [mem 0x0000000100000000-0x00000006bdffffff]
[ 0.007368] Device empty
[ 0.007368] Movable zone start for each node
[ 0.007370] Early memory node ranges
[ 0.007370] node 0: [mem 0x0000000000001000-0x000000000009cfff]
[ 0.007372] node 0: [mem 0x0000000000100000-0x000000003ce99fff]
[ 0.007373] node 0: [mem 0x000000003e706000-0x000000003e898fff]
[ 0.007373] node 0: [mem 0x000000003f40f000-0x000000003f40ffff]
[ 0.007374] node 0: [mem 0x0000000100000000-0x00000006bdffffff]
[ 0.007376] Initmem setup node 0 [mem 0x0000000000001000-0x00000006bdffffff]
[ 0.007379] On node 0, zone DMA: 1 pages in unavailable ranges
[ 0.007398] On node 0, zone DMA: 99 pages in unavailable ranges
[ 0.008557] On node 0, zone DMA32: 6252 pages in unavailable ranges
[ 0.008586] On node 0, zone DMA32: 2934 pages in unavailable ranges
[ 0.036292] On node 0, zone Normal: 3056 pages in unavailable ranges
[ 0.036373] On node 0, zone Normal: 8192 pages in unavailable ranges
[ 0.036914] ACPI: PM-Timer IO Port: 0x1808
[ 0.036919] ACPI: LAPIC_NMI (acpi_id[0x01] high edge lint[0x1])
[ 0.036920] ACPI: LAPIC_NMI (acpi_id[0x02] high edge lint[0x1])
[ 0.036920] ACPI: LAPIC_NMI (acpi_id[0x03] high edge lint[0x1])
[ 0.036921] ACPI: LAPIC_NMI (acpi_id[0x04] high edge lint[0x1])
[ 0.036921] ACPI: LAPIC_NMI (acpi_id[0x05] high edge lint[0x1])
[ 0.036922] ACPI: LAPIC_NMI (acpi_id[0x06] high edge lint[0x1])
[ 0.036922] ACPI: LAPIC_NMI (acpi_id[0x07] high edge lint[0x1])
[ 0.036923] ACPI: LAPIC_NMI (acpi_id[0x08] high edge lint[0x1])
[ 0.036988] IOAPIC[0]: apic_id 2, version 32, address 0xfec00000, GSI 0-119
[ 0.036990] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.036991] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[ 0.036994] ACPI: Using ACPI (MADT) for SMP configuration information
[ 0.036995] ACPI: HPET id: 0x8086a201 base: 0xfed00000
[ 0.036997] TSC deadline timer available
[ 0.036998] smpboot: Allowing 8 CPUs, 0 hotplug CPUs
[ 0.037010] PM: hibernation: Registered nosave memory: [mem 0x00000000-0x00000fff]
[ 0.037011] PM: hibernation: Registered nosave memory: [mem 0x0009d000-0x0009dfff]
[ 0.037012] PM: hibernation: Registered nosave memory: [mem 0x0009e000-0x0009ffff]
[ 0.037012] PM: hibernation: Registered nosave memory: [mem 0x000a0000-0x000dffff]
[ 0.037013] PM: hibernation: Registered nosave memory: [mem 0x000e0000-0x000fffff]
[ 0.037014] PM: hibernation: Registered nosave memory: [mem 0x3ce9a000-0x3e705fff]
[ 0.037015] PM: hibernation: Registered nosave memory: [mem 0x3e899000-0x3ec5bfff]
[ 0.037015] PM: hibernation: Registered nosave memory: [mem 0x3ec5c000-0x3f40efff]
[ 0.037016] PM: hibernation: Registered nosave memory: [mem 0x3f410000-0x3fffffff]
[ 0.037017] PM: hibernation: Registered nosave memory: [mem 0x40000000-0xdfffffff]
[ 0.037017] PM: hibernation: Registered nosave memory: [mem 0xe0000000-0xefffffff]
[ 0.037018] PM: hibernation: Registered nosave memory: [mem 0xf0000000-0xfdffffff]
[ 0.037018] PM: hibernation: Registered nosave memory: [mem 0xfe000000-0xfe010fff]
[ 0.037019] PM: hibernation: Registered nosave memory: [mem 0xfe011000-0xfebfffff]
[ 0.037019] PM: hibernation: Registered nosave memory: [mem 0xfec00000-0xfec00fff]
[ 0.037020] PM: hibernation: Registered nosave memory: [mem 0xfec01000-0xfecfffff]
[ 0.037020] PM: hibernation: Registered nosave memory: [mem 0xfed00000-0xfed03fff]
[ 0.037021] PM: hibernation: Registered nosave memory: [mem 0xfed04000-0xfedfffff]
[ 0.037021] PM: hibernation: Registered nosave memory: [mem 0xfee00000-0xfee00fff]
[ 0.037022] PM: hibernation: Registered nosave memory: [mem 0xfee01000-0xfeffffff]
[ 0.037022] PM: hibernation: Registered nosave memory: [mem 0xff000000-0xffffffff]
[ 0.037024] [mem 0x40000000-0xdfffffff] available for PCI devices
[ 0.037025] Booting paravirtualized kernel on bare hardware
[ 0.037026] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 3821924579961850 ns
[ 0.041175] setup_percpu: NR_CPUS:512 nr_cpumask_bits:8 nr_cpu_ids:8 nr_node_ids:1
[ 0.041302] percpu: Embedded 54 pages/cpu s184320 r8192 d28672 u262144
[ 0.041307] pcpu-alloc: s184320 r8192 d28672 u262144 alloc=1*2097152
[ 0.041308] pcpu-alloc: [0] 0 1 2 3 4 5 6 7
[ 0.041322] Fallback order for Node 0: 0
[ 0.041324] Built 1 zonelists, mobility grouping on. Total pages: 6172781
[ 0.041325] Policy zone: Normal
[ 0.041325] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-6.1.33-rt11-x64v3-xanmod1 root=UUID=d38623b9-542a-4b21-8409-60ca5e1563cf ro initrd=/install/gtk/initrd.gz resume=UUID=a55c7c8d-2d4b-45a7-a449-fe3825c1f0a4 mitigations=off mds=off tsx_async_abort=off rootwait
[ 0.041408] Unknown kernel command line parameters "BOOT_IMAGE=/boot/vmlinuz-6.1.33-rt11-x64v3-xanmod1", will be passed to user space.
[ 0.041436] random: crng init done
[ 0.042620] Dentry cache hash table entries: 4194304 (order: 13, 33554432 bytes, linear)
[ 0.043217] Inode-cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear)
[ 0.043275] mem auto-init: stack:off, heap alloc:on, heap free:off
[ 0.043279] software IO TLB: area num 8.
[ 0.090252] Memory: 24484644K/25083688K available (14337K kernel code, 2014K rwdata, 4516K rodata, 2188K init, 17952K bss, 598784K reserved, 0K cma-reserved)
[ 0.090357] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1
[ 0.090418] rcu: Preemptible hierarchical RCU implementation.
[ 0.090419] rcu: RCU restricting CPUs from NR_CPUS=512 to nr_cpu_ids=8.
[ 0.090419] rcu: RCU_SOFTIRQ processing moved to rcuc kthreads.
[ 0.090420] No expedited grace period (rcu_normal_after_boot).
[ 0.090420] Trampoline variant of Tasks RCU enabled.
[ 0.090421] Tracing variant of Tasks RCU enabled.
[ 0.090421] rcu: RCU calculated value of scheduler-enlistment delay is 50 jiffies.
[ 0.090422] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=8
[ 0.090464] NR_IRQS: 33024, nr_irqs: 2048, preallocated irqs: 16
[ 0.090734] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[ 0.096288] Console: colour VGA+ 80x25
[ 0.131743] printk: console [tty0] enabled
[ 0.131758] ACPI: Core revision 20220331
[ 0.132182] clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635855245 ns
[ 0.132319] APIC: Switch to symmetric I/O mode setup
[ 0.135244] x2apic: IRQ remapping doesn't support X2APIC mode
[ 0.144806] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[ 0.154272] clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x33e452fbb2f, max_idle_ns: 440795236593 ns
[ 0.154275] Calibrating delay loop (skipped), value calculated using timer frequency.. 7200.00 BogoMIPS (lpj=7200000)
[ 0.154278] pid_max: default: 32768 minimum: 301
[ 0.154298] LSM: Security Framework initializing
[ 0.154306] landlock: Up and running.
[ 0.154306] Yama: becoming mindful.
[ 0.154325] AppArmor: AppArmor initialized
[ 0.154389] Mount-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.154429] Mountpoint-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.154613] x86/cpu: VMX (outside TXT) disabled by BIOS
[ 0.154614] x86/cpu: SGX disabled by BIOS.
[ 0.154617] CPU0: Thermal monitoring enabled (TM1)
[ 0.154657] process: using mwait in idle threads
[ 0.154659] Last level iTLB entries: 4KB 128, 2MB 8, 4MB 8
[ 0.154660] Last level dTLB entries: 4KB 64, 2MB 0, 4MB 0, 1GB 4
[ 0.154664] Spectre V2 : User space: Vulnerable
[ 0.154665] Speculative Store Bypass: Vulnerable
[ 0.154666] SRBDS: Vulnerable
[ 0.167767] Freeing SMP alternatives memory: 40K
[ 0.168087] smpboot: CPU0: Intel(R) Core(TM) i7-9700K CPU @ 3.60GHz (family: 0x6, model: 0x9e, stepping: 0xd)
[ 0.176451] cblist_init_generic: Setting adjustable number of callback queues.
[ 0.176452] cblist_init_generic: Setting shift to 3 and lim to 1.
[ 0.176851] cblist_init_generic: Setting shift to 3 and lim to 1.
[ 0.177053] Performance Events: PEBS fmt3+, Skylake events, 32-deep LBR, full-width counters, Intel PMU driver.
[ 0.178275] ... version: 4
[ 0.178474] ... bit width: 48
[ 0.178663] ... generic registers: 8
[ 0.178851] ... value mask: 0000ffffffffffff
[ 0.179041] ... max period: 00007fffffffffff
[ 0.180276] ... fixed-purpose events: 3
[ 0.180474] ... event mask: 00000007000000ff
[ 0.180743] Estimated ratio of average max frequency by base frequency (times 1024): 1024
[ 0.180979] rcu: Hierarchical SRCU implementation.
[ 0.180980] rcu: Max phase no-delay instances is 800.
[ 0.180988] printk: console [tty0] printing thread started
[ 0.183102] NMI watchdog: Enabled. Permanently consumes one hw-PMU counter.
[ 0.183158] smp: Bringing up secondary CPUs ...
[ 0.184665] x86: Booting SMP configuration:
[ 0.184665] .... node #0, CPUs: #1 #2 #3 #4 #5 #6 #7
[ 0.212700] smp: Brought up 1 node, 8 CPUs
[ 0.212700] smpboot: Max logical packages: 1
[ 0.212700] smpboot: Total of 8 processors activated (57600.00 BogoMIPS)
[ 0.216680] devtmpfs: initialized
[ 0.216680] x86/mm: Memory block size: 128MB
[ 0.221080] ACPI: PM: Registering ACPI NVS region [mem 0x3e899000-0x3ec5bfff] (3944448 bytes)
[ 0.221080] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 3822520892550000 ns
[ 0.221080] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
[ 0.222898] pinctrl core: initialized pinctrl subsystem
[ 0.224512] PM: RTC time: 01:49:12, date: 2023-11-29
[ 0.224826] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.225100] DMA: preallocated 4096 KiB GFP_KERNEL pool for atomic allocations
[ 0.226909] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.227107] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.227118] audit: initializing netlink subsys (disabled)
[ 0.227137] audit: type=2000 audit(1701222552.086:1): state=initialized audit_enabled=0 res=1
[ 0.229074] thermal_sys: Registered thermal governor 'fair_share'
[ 0.229074] thermal_sys: Registered thermal governor 'bang_bang'
[ 0.229075] thermal_sys: Registered thermal governor 'step_wise'
[ 0.229075] thermal_sys: Registered thermal governor 'user_space'
[ 0.229075] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.229083] cpuidle: using governor ladder
[ 0.229085] cpuidle: using governor menu
[ 0.229125] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 0.230299] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xefffffff] (base 0xe0000000)
[ 0.230302] PCI: MMCONFIG at [mem 0xe0000000-0xefffffff] reserved in E820
[ 0.230315] PCI: Using configuration type 1 for base access
[ 0.230508] ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
[ 0.238718] kprobes: kprobe jump-optimization is enabled. All kprobes are optimized if possible.
[ 0.238722] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.238722] HugeTLB: 16380 KiB vmemmap can be freed for a 1.00 GiB page
[ 0.238722] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.238722] HugeTLB: 28 KiB vmemmap can be freed for a 2.00 MiB page
[ 0.238722] ACPI: Added _OSI(Module Device)
[ 0.238722] ACPI: Added _OSI(Processor Device)
[ 0.238722] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.238722] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.376744] ACPI: 9 ACPI AML tables successfully acquired and loaded
[ 0.390547] ACPI: \_SB_.PR00: _OSC native thermal LVT Acked
[ 0.402584] ACPI: Interpreter enabled
[ 0.402617] ACPI: PM: (supports S0 S4 S5)
[ 0.402618] ACPI: Using IOAPIC for interrupt routing
[ 0.402726] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[ 0.402727] PCI: Using E820 reservations for host bridge windows
[ 0.404977] ACPI: Enabled 10 GPEs in block 00 to 7F
[ 0.432959] ACPI: PM: Power Resource [USBC]
[ 0.440280] ACPI: PM: Power Resource [V0PR]
[ 0.440655] ACPI: PM: Power Resource [V1PR]
[ 0.441019] ACPI: PM: Power Resource [V2PR]
[ 0.452802] ACPI: PM: Power Resource [WRST]
[ 0.459033] ACPI: PM: Power Resource [PIN]
[ 0.460584] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-fe])
[ 0.460590] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI EDR HPX-Type3]
[ 0.468348] acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug SHPCHotplug PME AER PCIeCapability LTR DPC]
[ 0.470787] PCI host bridge to bus 0000:00
[ 0.470788] pci_bus 0000:00: root bus resource [io 0x0000-0x0cf7 window]
[ 0.470790] pci_bus 0000:00: root bus resource [io 0x0d00-0xffff window]
[ 0.470791] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
[ 0.470792] pci_bus 0000:00: root bus resource [mem 0x40000000-0xdfffffff window]
[ 0.470793] pci_bus 0000:00: root bus resource [mem 0x4000000000-0x7fffffffff window]
[ 0.470794] pci_bus 0000:00: root bus resource [mem 0xfc800000-0xfe7fffff window]
[ 0.470794] pci_bus 0000:00: root bus resource [bus 00-fe]
[ 0.470880] pci 0000:00:00.0: [8086:3e30] type 00 class 0x060000
[ 0.470942] pci 0000:00:01.0: [8086:1901] type 01 class 0x060400
[ 0.470975] pci 0000:00:01.0: PME# supported from D0 D3hot D3cold
[ 0.472964] pci 0000:00:12.0: [8086:a379] type 00 class 0x118000
[ 0.473034] pci 0000:00:12.0: reg 0x10: [mem 0x4000b1d000-0x4000b1dfff 64bit]
[ 0.474662] pci 0000:00:14.0: [8086:a36d] type 00 class 0x0c0330
[ 0.474742] pci 0000:00:14.0: reg 0x10: [mem 0x4000b00000-0x4000b0ffff 64bit]
[ 0.475082] pci 0000:00:14.0: PME# supported from D3hot D3cold
[ 0.478830] pci 0000:00:14.2: [8086:a36f] type 00 class 0x050000
[ 0.478913] pci 0000:00:14.2: reg 0x10: [mem 0x4000b18000-0x4000b19fff 64bit]
[ 0.478970] pci 0000:00:14.2: reg 0x18: [mem 0x4000b1c000-0x4000b1cfff 64bit]
[ 0.482461] pci 0000:00:14.3: [8086:a370] type 00 class 0x028000
[ 0.484524] pci 0000:00:14.3: reg 0x10: [mem 0x4000b14000-0x4000b17fff 64bit]
[ 0.496274] pci 0000:00:14.3: PME# supported from D0 D3hot D3cold
[ 0.503077] pci 0000:00:16.0: [8086:a360] type 00 class 0x078000
[ 0.503140] pci 0000:00:16.0: reg 0x10: [mem 0x4000b1b000-0x4000b1bfff 64bit]
[ 0.504454] pci 0000:00:16.0: PME# supported from D3hot
[ 0.505045] pci 0000:00:17.0: [8086:a352] type 00 class 0x010601
[ 0.505095] pci 0000:00:17.0: reg 0x10: [mem 0x53c00000-0x53c01fff]
[ 0.505122] pci 0000:00:17.0: reg 0x14: [mem 0x53c03000-0x53c030ff]
[ 0.505148] pci 0000:00:17.0: reg 0x18: [io 0x5050-0x5057]
[ 0.505173] pci 0000:00:17.0: reg 0x1c: [io 0x5040-0x5043]
[ 0.505200] pci 0000:00:17.0: reg 0x20: [io 0x5020-0x503f]
[ 0.505227] pci 0000:00:17.0: reg 0x24: [mem 0x53c02000-0x53c027ff]
[ 0.506422] pci 0000:00:17.0: PME# supported from D3hot
[ 0.507069] pci 0000:00:1b.0: [8086:a32c] type 01 class 0x060400
[ 0.508546] pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold
[ 0.508712] pci 0000:00:1b.0: PTM enabled (root), 4ns granularity
[ 0.510760] pci 0000:00:1d.0: [8086:a330] type 01 class 0x060400
[ 0.511184] pci 0000:00:1d.0: PME# supported from D0 D3hot D3cold
[ 0.512390] pci 0000:00:1d.0: PTM enabled (root), 4ns granularity
[ 0.514385] pci 0000:00:1f.0: [8086:a305] type 00 class 0x060100
[ 0.515060] pci 0000:00:1f.3: [8086:a348] type 00 class 0x040300
[ 0.515147] pci 0000:00:1f.3: reg 0x10: [mem 0x4000b10000-0x4000b13fff 64bit]
[ 0.516320] pci 0000:00:1f.3: reg 0x20: [mem 0x4000a00000-0x4000afffff 64bit]
[ 0.516538] pci 0000:00:1f.3: PME# supported from D3hot D3cold
[ 0.522799] pci 0000:00:1f.4: [8086:a323] type 00 class 0x0c0500
[ 0.523001] pci 0000:00:1f.4: reg 0x10: [mem 0x4000b1a000-0x4000b1a0ff 64bit]
[ 0.524286] pci 0000:00:1f.4: reg 0x20: [io 0xefa0-0xefbf]
[ 0.524804] pci 0000:00:1f.5: [8086:a324] type 00 class 0x0c8000
[ 0.524871] pci 0000:00:1f.5: reg 0x10: [mem 0xfe010000-0xfe010fff]
[ 0.526339] pci 0000:01:00.0: [10de:2486] type 00 class 0x030000
[ 0.526413] pci 0000:01:00.0: reg 0x10: [mem 0x52000000-0x52ffffff]
[ 0.526427] pci 0000:01:00.0: reg 0x14: [mem 0x40000000-0x4fffffff 64bit pref]
[ 0.526434] pci 0000:01:00.0: reg 0x1c: [mem 0x50000000-0x51ffffff 64bit pref]
[ 0.526480] pci 0000:01:00.0: reg 0x24: [io 0x4000-0x407f]
[ 0.526523] pci 0000:01:00.0: reg 0x30: [mem 0x53000000-0x5307ffff pref]
[ 0.526611] pci 0000:01:00.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
[ 0.526805] pci 0000:01:00.0: PME# supported from D0 D3hot
[ 0.527119] pci 0000:01:00.0: 126.016 Gb/s available PCIe bandwidth, limited by 8.0 GT/s PCIe x16 link at 0000:00:01.0 (capable of 252.048 Gb/s with 16.0 GT/s PCIe x16 link)
[ 0.528519] pci 0000:01:00.1: [10de:228b] type 00 class 0x040300
[ 0.528594] pci 0000:01:00.1: reg 0x10: [mem 0x53080000-0x53083fff]
[ 0.529151] pci 0000:00:01.0: PCI bridge to [bus 01]
[ 0.529158] pci 0000:00:01.0: bridge window [io 0x4000-0x4fff]
[ 0.529168] pci 0000:00:01.0: bridge window [mem 0x52000000-0x530fffff]
[ 0.529179] pci 0000:00:01.0: bridge window [mem 0x40000000-0x51ffffff 64bit pref]
[ 0.530429] pci 0000:00:1b.0: PCI bridge to [bus 02]
[ 0.530434] pci 0000:00:1b.0: bridge window [io 0x3000-0x3fff]
[ 0.530441] pci 0000:00:1b.0: bridge window [mem 0x53100000-0x53afffff]
[ 0.530455] pci 0000:00:1b.0: bridge window [mem 0x4000000000-0x40009fffff 64bit pref]
[ 0.530762] pci 0000:03:00.0: [15b7:5009] type 00 class 0x010802
[ 0.530863] pci 0000:03:00.0: reg 0x10: [mem 0x53b00000-0x53b03fff 64bit]
[ 0.530987] pci 0000:03:00.0: reg 0x20: [mem 0x53b04000-0x53b040ff 64bit]
[ 0.533106] pci 0000:00:1d.0: PCI bridge to [bus 03]
[ 0.533125] pci 0000:00:1d.0: bridge window [mem 0x53b00000-0x53bfffff]
[ 0.536436] ACPI: PCI: Interrupt link LNKA configured for IRQ 0
[ 0.536509] ACPI: PCI: Interrupt link LNKB configured for IRQ 1
[ 0.536579] ACPI: PCI: Interrupt link LNKC configured for IRQ 0
[ 0.536649] ACPI: PCI: Interrupt link LNKD configured for IRQ 0
[ 0.536719] ACPI: PCI: Interrupt link LNKE configured for IRQ 0
[ 0.536789] ACPI: PCI: Interrupt link LNKF configured for IRQ 0
[ 0.536858] ACPI: PCI: Interrupt link LNKG configured for IRQ 0
[ 0.536928] ACPI: PCI: Interrupt link LNKH configured for IRQ 0
[ 0.548804] iommu: Default domain type: Translated
[ 0.548804] iommu: DMA domain TLB invalidation policy: lazy mode
[ 0.548804] SCSI subsystem initialized
[ 0.548804] libata version 3.00 loaded.
[ 0.548804] ACPI: bus type USB registered
[ 0.548804] usbcore: registered new interface driver usbfs
[ 0.548804] usbcore: registered new interface driver hub
[ 0.548804] usbcore: registered new device driver usb
[ 0.548804] pps_core: LinuxPPS API ver. 1 registered
[ 0.548804] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.548804] PTP clock support registered
[ 0.548804] EDAC MC: Ver: 3.0.0
[ 0.550395] NetLabel: Initializing
[ 0.550396] NetLabel: domain hash size = 128
[ 0.550396] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO
[ 0.550410] NetLabel: unlabeled traffic allowed by default
[ 0.550421] mctp: management component transport protocol core
[ 0.550421] NET: Registered PF_MCTP protocol family
[ 0.550421] PCI: Using ACPI for IRQ routing
[ 0.734796] PCI: pci_cache_line_size set to 64 bytes
[ 0.735018] e820: reserve RAM buffer [mem 0x0009d400-0x0009ffff]
[ 0.735019] e820: reserve RAM buffer [mem 0x3ce9a000-0x3fffffff]
[ 0.735020] e820: reserve RAM buffer [mem 0x3e899000-0x3fffffff]
[ 0.735021] e820: reserve RAM buffer [mem 0x3f410000-0x3fffffff]
[ 0.735022] e820: reserve RAM buffer [mem 0x6be000000-0x6bfffffff]
[ 0.735033] pci 0000:01:00.0: vgaarb: setting as boot VGA device
[ 0.735033] pci 0000:01:00.0: vgaarb: bridge control possible
[ 0.735033] pci 0000:01:00.0: vgaarb: VGA device added: decodes=io+mem,owns=io+mem,locks=none
[ 0.735033] vgaarb: loaded
[ 0.737153] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0, 0, 0, 0, 0, 0
[ 0.737157] hpet0: 8 comparators, 64-bit 24.000000 MHz counter
[ 0.740341] clocksource: Switched to clocksource tsc-early
[ 0.740407] VFS: Disk quotas dquot_6.6.0
[ 0.740416] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.740503] AppArmor: AppArmor Filesystem Enabled
[ 0.740524] pnp: PnP ACPI init
[ 0.740791] system 00:00: [io 0x0280-0x028f] has been reserved
[ 0.740793] system 00:00: [io 0x0290-0x029f] has been reserved
[ 0.740794] system 00:00: [io 0x02a0-0x02af] has been reserved
[ 0.740795] system 00:00: [io 0x02b0-0x02bf] has been reserved
[ 0.741164] pnp 00:01: [dma 0 disabled]
[ 0.741334] system 00:02: [io 0x0680-0x069f] has been reserved
[ 0.741336] system 00:02: [io 0x164e-0x164f] has been reserved
[ 0.741439] system 00:03: [io 0x1854-0x1857] has been reserved
[ 0.741597] system 00:04: [mem 0xfed10000-0xfed17fff] has been reserved
[ 0.741599] system 00:04: [mem 0xfed18000-0xfed18fff] has been reserved
[ 0.741600] system 00:04: [mem 0xfed19000-0xfed19fff] has been reserved
[ 0.741601] system 00:04: [mem 0xe0000000-0xefffffff] has been reserved
[ 0.741602] system 00:04: [mem 0xfed20000-0xfed3ffff] has been reserved
[ 0.741603] system 00:04: [mem 0xfed90000-0xfed93fff] has been reserved
[ 0.741604] system 00:04: [mem 0xfed45000-0xfed8ffff] has been reserved
[ 0.741605] system 00:04: [mem 0xfee00000-0xfeefffff] could not be reserved
[ 0.741803] system 00:05: [io 0x1800-0x18fe] could not be reserved
[ 0.741804] system 00:05: [mem 0xfd000000-0xfd69ffff] has been reserved
[ 0.741805] system 00:05: [mem 0xfd6c0000-0xfd6cffff] has been reserved
[ 0.741806] system 00:05: [mem 0xfd6f0000-0xfdffffff] has been reserved
[ 0.741807] system 00:05: [mem 0xfe000000-0xfe01ffff] could not be reserved
[ 0.741808] system 00:05: [mem 0xfe200000-0xfe7fffff] has been reserved
[ 0.741809] system 00:05: [mem 0xff000000-0xffffffff] has been reserved
[ 0.742077] system 00:06: [io 0x2000-0x20fe] has been reserved
[ 0.742309] system 00:07: [mem 0xfd6e0000-0xfd6effff] has been reserved
[ 0.742311] system 00:07: [mem 0xfd6d0000-0xfd6dffff] has been reserved
[ 0.742312] system 00:07: [mem 0xfd6b0000-0xfd6bffff] has been reserved
[ 0.742313] system 00:07: [mem 0xfd6a0000-0xfd6affff] has been reserved
[ 0.744056] pnp: PnP ACPI: found 9 devices
[ 0.749524] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[ 0.749572] NET: Registered PF_INET protocol family
[ 0.749682] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.751958] tcp_listen_portaddr_hash hash table entries: 16384 (order: 7, 655360 bytes, linear)
[ 0.752013] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.752105] TCP established hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.752543] TCP bind hash table entries: 65536 (order: 10, 5242880 bytes, vmalloc hugepage)
[ 0.753024] TCP: Hash tables configured (established 262144 bind 65536)
[ 0.753155] MPTCP token hash table entries: 32768 (order: 8, 1835008 bytes, linear)
[ 0.753385] UDP hash table entries: 16384 (order: 8, 1572864 bytes, linear)
[ 0.753597] UDP-Lite hash table entries: 16384 (order: 8, 1572864 bytes, linear)
[ 0.753744] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.753752] NET: Registered PF_XDP protocol family
[ 0.753763] pci 0000:00:01.0: PCI bridge to [bus 01]
[ 0.753769] pci 0000:00:01.0: bridge window [io 0x4000-0x4fff]
[ 0.753790] pci 0000:00:01.0: bridge window [mem 0x52000000-0x530fffff]
[ 0.753801] pci 0000:00:01.0: bridge window [mem 0x40000000-0x51ffffff 64bit pref]
[ 0.753822] pci 0000:00:1b.0: PCI bridge to [bus 02]
[ 0.753826] pci 0000:00:1b.0: bridge window [io 0x3000-0x3fff]
[ 0.753844] pci 0000:00:1b.0: bridge window [mem 0x53100000-0x53afffff]
[ 0.753851] pci 0000:00:1b.0: bridge window [mem 0x4000000000-0x40009fffff 64bit pref]
[ 0.753871] pci 0000:00:1d.0: PCI bridge to [bus 03]
[ 0.753886] pci 0000:00:1d.0: bridge window [mem 0x53b00000-0x53bfffff]
[ 0.753919] pci_bus 0000:00: resource 4 [io 0x0000-0x0cf7 window]
[ 0.753920] pci_bus 0000:00: resource 5 [io 0x0d00-0xffff window]
[ 0.753921] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
[ 0.753922] pci_bus 0000:00: resource 7 [mem 0x40000000-0xdfffffff window]
[ 0.753923] pci_bus 0000:00: resource 8 [mem 0x4000000000-0x7fffffffff window]
[ 0.753924] pci_bus 0000:00: resource 9 [mem 0xfc800000-0xfe7fffff window]
[ 0.753924] pci_bus 0000:01: resource 0 [io 0x4000-0x4fff]
[ 0.753925] pci_bus 0000:01: resource 1 [mem 0x52000000-0x530fffff]
[ 0.753926] pci_bus 0000:01: resource 2 [mem 0x40000000-0x51ffffff 64bit pref]
[ 0.753927] pci_bus 0000:02: resource 0 [io 0x3000-0x3fff]
[ 0.753928] pci_bus 0000:02: resource 1 [mem 0x53100000-0x53afffff]
[ 0.753928] pci_bus 0000:02: resource 2 [mem 0x4000000000-0x40009fffff 64bit pref]
[ 0.753929] pci_bus 0000:03: resource 1 [mem 0x53b00000-0x53bfffff]
[ 0.755215] pci 0000:01:00.1: extending delay after power-on from D3hot to 20 msec
[ 0.755264] pci 0000:01:00.1: D0 power state depends on 0000:01:00.0
[ 0.755306] PCI: CLS 64 bytes, default 64
[ 0.755311] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[ 0.755311] software IO TLB: mapped [mem 0x0000000038e9a000-0x000000003ce9a000] (64MB)
[ 0.755354] Trying to unpack rootfs image as initramfs...
[ 0.759259] platform rtc_cmos: registered platform RTC device (no PNP device found)
[ 0.759768] Initialise system trusted keyrings
[ 0.759775] Key type blacklist registered
[ 0.759802] workingset: timestamp_bits=36 max_order=23 bucket_order=0
[ 0.761505] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.761606] fuse: init (API version 7.37)
[ 0.761720] integrity: Platform Keyring initialized
[ 0.761721] integrity: Machine keyring initialized
[ 0.768156] Key type asymmetric registered
[ 0.768157] Asymmetric key parser 'x509' registered
[ 0.940159] Freeing initrd memory: 38312K
[ 0.942729] alg: self-tests for CTR-KDF (hmac(sha256)) passed
[ 0.942748] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
[ 0.942769] io scheduler mq-deadline registered
[ 0.943144] pcieport 0000:00:01.0: PME: Signaling with IRQ 120
[ 0.943489] pcieport 0000:00:1b.0: PME: Signaling with IRQ 121
[ 0.943530] pcieport 0000:00:1b.0: pciehp: Slot #24 AttnBtn- PwrCtrl- MRL- AttnInd- PwrInd- HotPlug+ Surprise+ Interlock- NoCompl+ IbPresDis- LLActRep+
[ 0.944148] pcieport 0000:00:1d.0: PME: Signaling with IRQ 122
[ 0.944384] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 0.945286] input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input0
[ 0.945303] ACPI: button: Sleep Button [SLPB]
[ 0.945327] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1
[ 0.945340] ACPI: button: Power Button [PWRB]
[ 0.945361] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input2
[ 0.945528] ACPI: button: Power Button [PWRF]
[ 0.946006] Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
[ 0.968168] 00:01: ttyS0 at I/O 0x3f8 (irq = 4, base_baud = 115200) is a 16550A
[ 0.970913] Linux agpgart interface v0.103
[ 0.972586] loop: module loaded
[ 0.972765] tun: Universal TUN/TAP device driver, 1.6
[ 0.972820] PPP generic driver version 2.4.2
[ 0.972864] VFIO - User Level meta-driver version: 0.3
[ 0.972948] i8042: PNP: No PS/2 controller found.
[ 0.972978] mousedev: PS/2 mouse device common for all mice
[ 0.973050] rtc_cmos rtc_cmos: RTC can wake from S4
[ 0.975098] rtc_cmos rtc_cmos: registered as rtc0
[ 0.975499] rtc_cmos rtc_cmos: setting system clock to 2023-11-29T01:49:13 UTC (1701222553)
[ 0.975560] rtc_cmos rtc_cmos: alarms up to one month, y3k, 114 bytes nvram
[ 0.975564] i2c_dev: i2c /dev entries driver
[ 0.977008] device-mapper: core: CONFIG_IMA_DISABLE_HTABLE is disabled. Duplicate IMA measurements will not be recorded in the IMA log.
[ 0.977025] device-mapper: uevent: version 1.0.3
[ 0.977086] device-mapper: ioctl: 4.47.0-ioctl (2022-07-28) initialised: dm-devel@redhat.com
[ 0.977089] intel_pstate: Intel P-state driver initializing
[ 0.977445] intel_pstate: Disabling energy efficiency optimization
[ 0.977446] intel_pstate: HWP enabled
[ 0.977501] intel_pmc_core INT33A1:00: initialized
[ 0.977670] NET: Registered PF_INET6 protocol family
[ 0.980562] Segment Routing with IPv6
[ 0.980567] In-situ OAM (IOAM) with IPv6
[ 0.980581] NET: Registered PF_PACKET protocol family
[ 0.980654] Key type dns_resolver registered
[ 0.981195] microcode: sig=0x906ed, pf=0x2, revision=0xfa
[ 0.981287] microcode: Microcode Update Driver: v2.2.
[ 0.981290] IPI shorthand broadcast: enabled
[ 0.981307] sched_clock: Marking stable (932002120, 49227095)->(686025523, 295203692)
[ 0.981580] registered taskstats version 1
[ 0.981583] Loading compiled-in X.509 certificates
[ 0.982340] Loaded X.509 cert 'Build time autogenerated kernel key: 29d073b748864afdfd9cb0b43e2c7b641df784d9'
[ 0.982695] zswap: loaded using pool lz4/z3fold
[ 0.982911] Key type .fscrypt registered
[ 0.982912] Key type fscrypt-provisioning registered
[ 0.986462] Key type encrypted registered
[ 0.986465] AppArmor: AppArmor sha1 policy hashing enabled
[ 0.986471] ima: No TPM chip found, activating TPM-bypass!
[ 0.986473] Loading compiled-in module X.509 certificates
[ 0.986875] Loaded X.509 cert 'Build time autogenerated kernel key: 29d073b748864afdfd9cb0b43e2c7b641df784d9'
[ 0.986877] ima: Allocated hash algorithm: sha1
[ 0.986881] ima: No architecture policies found
[ 0.986888] evm: Initialising EVM extended attributes:
[ 0.986888] evm: security.selinux
[ 0.986889] evm: security.SMACK64
[ 0.986890] evm: security.SMACK64EXEC
[ 0.986890] evm: security.SMACK64TRANSMUTE
[ 0.986890] evm: security.SMACK64MMAP
[ 0.986891] evm: security.apparmor
[ 0.986891] evm: security.ima
[ 0.986891] evm: security.capability
[ 0.986891] evm: HMAC attrs: 0x1
[ 0.987943] PM: Magic number: 15:102:813
[ 0.988097] RAS: Correctable Errors collector initialized.
[ 0.988695] Freeing unused decrypted memory: 2036K
[ 0.988979] Freeing unused kernel image (initmem) memory: 2188K
[ 1.007323] Write protecting the kernel read-only data: 22528k
[ 1.007929] Freeing unused kernel image (text/rodata gap) memory: 2044K
[ 1.008129] Freeing unused kernel image (rodata/data gap) memory: 1628K
[ 1.016669] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[ 1.016673] Run /init as init process
[ 1.016673] with arguments:
[ 1.016674] /init
[ 1.016675] with environment:
[ 1.016675] HOME=/
[ 1.016675] TERM=linux
[ 1.016676] BOOT_IMAGE=/boot/vmlinuz-6.1.33-rt11-x64v3-xanmod1
[ 1.023653] udevd[222]: starting version 3.2.12
[ 1.024299] udevd[224]: starting eudev-3.2.12
[ 1.042148] udevd[254]: Error running install command 'modprobe -i nvidia-current ' for module nvidia: retcode 1
[ 1.042498] xhci_hcd 0000:00:14.0: xHCI Host Controller
[ 1.042502] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 1
[ 1.042752] ahci 0000:00:17.0: version 3.0
[ 1.043779] xhci_hcd 0000:00:14.0: hcc params 0x200077c1 hci version 0x110 quirks 0x0000000000009810
[ 1.044344] xhci_hcd 0000:00:14.0: xHCI Host Controller
[ 1.044347] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 2
[ 1.044349] xhci_hcd 0000:00:14.0: Host supports USB 3.1 Enhanced SuperSpeed
[ 1.044697] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.01
[ 1.044699] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.044700] usb usb1: Product: xHCI Host Controller
[ 1.044702] usb usb1: Manufacturer: Linux 6.1.33-rt11-x64v3-xanmod1 xhci-hcd
[ 1.044702] usb usb1: SerialNumber: 0000:00:14.0
[ 1.044953] hub 1-0:1.0: USB hub found
[ 1.045180] i801_smbus 0000:00:1f.4: SMBus using PCI interrupt
[ 1.045184] hub 1-0:1.0: 16 ports detected
[ 1.053075] ahci 0000:00:17.0: AHCI 0001.0301 32 slots 6 ports 6 Gbps 0x3f impl SATA mode
[ 1.053079] ahci 0000:00:17.0: flags: 64bit ncq sntf clo only pio slum part ems deso sadm sds apst
[ 1.059303] i2c i2c-0: 3/4 memory slots populated (from DMI)
[ 1.059556] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.01
[ 1.059558] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.059559] usb usb2: Product: xHCI Host Controller
[ 1.059560] usb usb2: Manufacturer: Linux 6.1.33-rt11-x64v3-xanmod1 xhci-hcd
[ 1.059561] usb usb2: SerialNumber: 0000:00:14.0
[ 1.059663] hub 2-0:1.0: USB hub found
[ 1.059761] hub 2-0:1.0: 10 ports detected
[ 1.060165] i2c i2c-0: Successfully instantiated SPD at 0x51
[ 1.060644] i2c i2c-0: Successfully instantiated SPD at 0x52
[ 1.061095] i2c i2c-0: Successfully instantiated SPD at 0x53
[ 1.061287] usb: port power management may be unreliable
[ 1.063225] nvme nvme0: pci function 0000:03:00.0
[ 1.078580] nvme nvme0: allocated 32 MiB host memory buffer.
[ 1.080815] nvme nvme0: 8/0/0 default/read/poll queues
[ 1.084104] nvme0n1: p1 p2 p3
[ 1.087833] scsi host0: ahci
[ 1.088024] scsi host1: ahci
[ 1.088165] scsi host2: ahci
[ 1.088315] scsi host3: ahci
[ 1.088387] scsi host4: ahci
[ 1.088463] scsi host5: ahci
[ 1.088509] ata1: SATA max UDMA/133 abar m2048@0x53c02000 port 0x53c02100 irq 123
[ 1.088512] ata2: SATA max UDMA/133 abar m2048@0x53c02000 port 0x53c02180 irq 123
[ 1.088515] ata3: SATA max UDMA/133 abar m2048@0x53c02000 port 0x53c02200 irq 123
[ 1.088518] ata4: SATA max UDMA/133 abar m2048@0x53c02000 port 0x53c02280 irq 123
[ 1.088520] ata5: SATA max UDMA/133 abar m2048@0x53c02000 port 0x53c02300 irq 123
[ 1.088523] ata6: SATA max UDMA/133 abar m2048@0x53c02000 port 0x53c02380 irq 123
[ 1.301294] usb 1-3: new low-speed USB device number 2 using xhci_hcd
[ 1.395590] ata6: SATA link down (SStatus 4 SControl 300)
[ 1.395613] ata5: SATA link down (SStatus 4 SControl 300)
[ 1.395672] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 1.395728] ata4: SATA link down (SStatus 4 SControl 300)
[ 1.395780] ata2: SATA link down (SStatus 4 SControl 300)
[ 1.395833] ata3: SATA link down (SStatus 4 SControl 300)
[ 1.406709] ata1.00: ACPI cmd f5/00:00:00:00:00:00(SECURITY FREEZE LOCK) filtered out
[ 1.406711] ata1.00: ACPI cmd b1/c1:00:00:00:00:00(DEVICE CONFIGURATION OVERLAY) filtered out
[ 1.434614] ata1.00: ATA-10: ST2000DM008-2FR102, 0001, max UDMA/133
[ 1.438884] usb 1-3: New USB device found, idVendor=4e53, idProduct=5407, bcdDevice= 1.00
[ 1.438886] usb 1-3: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 1.438887] usb 1-3: Product: USB OPTICAL MOUSE
[ 1.442885] hid: raw HID events driver (C) Jiri Kosina
[ 1.443695] ata1.00: 3907029168 sectors, multi 16: LBA48 NCQ (depth 32), AA
[ 1.478710] ata1.00: ACPI cmd f5/00:00:00:00:00:00(SECURITY FREEZE LOCK) filtered out
[ 1.478713] ata1.00: ACPI cmd b1/c1:00:00:00:00:00(DEVICE CONFIGURATION OVERLAY) filtered out
[ 1.515673] ata1.00: configured for UDMA/133
[ 1.515808] scsi 0:0:0:0: Direct-Access ATA ST2000DM008-2FR1 0001 PQ: 0 ANSI: 5
[ 1.516315] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 1.516413] sd 0:0:0:0: [sda] 3907029168 512-byte logical blocks: (2.00 TB/1.82 TiB)
[ 1.516414] sd 0:0:0:0: [sda] 4096-byte physical blocks
[ 1.516457] sd 0:0:0:0: [sda] Write Protect is off
[ 1.516459] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 1.516531] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 1.516638] sd 0:0:0:0: [sda] Preferred minimum I/O size 4096 bytes
[ 1.557237] usb 1-4: new low-speed USB device number 3 using xhci_hcd
[ 1.560846] sda: sda1
[ 1.560920] sd 0:0:0:0: [sda] Attached SCSI disk
[ 1.566932] usbcore: registered new interface driver usbhid
[ 1.566933] usbhid: USB HID core driver
[ 1.567787] usbcore: registered new interface driver usbmouse
[ 1.567845] usbcore: registered new interface driver usbkbd
[ 1.568818] input: USB OPTICAL MOUSE as /devices/pci0000:00/0000:00:14.0/usb1/1-3/1-3:1.0/0003:4E53:5407.0001/input/input3
[ 1.568880] hid-generic 0003:4E53:5407.0001: input,hidraw0: USB HID v1.11 Mouse [USB OPTICAL MOUSE ] on usb-0000:00:14.0-3/input0
[ 1.569035] input: USB OPTICAL MOUSE Keyboard as /devices/pci0000:00/0000:00:14.0/usb1/1-3/1-3:1.1/0003:4E53:5407.0002/input/input4
[ 1.621543] hid-generic 0003:4E53:5407.0002: input,hiddev0,hidraw1: USB HID v1.10 Keyboard [USB OPTICAL MOUSE ] on usb-0000:00:14.0-3/input1
[ 1.682716] PM: Image not found (code -22)
[ 1.695971] usb 1-4: New USB device found, idVendor=0c45, idProduct=7603, bcdDevice= 1.17
[ 1.695973] usb 1-4: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[ 1.695975] usb 1-4: Product: USB Keyboard
[ 1.699932] input: USB Keyboard as /devices/pci0000:00/0000:00:14.0/usb1/1-4/1-4:1.0/0003:0C45:7603.0003/input/input6
[ 1.753447] hid-generic 0003:0C45:7603.0003: input,hidraw2: USB HID v1.11 Keyboard [USB Keyboard] on usb-0000:00:14.0-4/input0
[ 1.765368] input: USB Keyboard Consumer Control as /devices/pci0000:00/0000:00:14.0/usb1/1-4/1-4:1.1/0003:0C45:7603.0004/input/input7
[ 1.773288] tsc: Refined TSC clocksource calibration: 3600.009 MHz
[ 1.773291] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x33e45c2fe0b, max_idle_ns: 440795366804 ns
[ 1.773333] clocksource: Switched to clocksource tsc
[ 1.780755] F2FS-fs (nvme0n1p3): recover fsync data on readonly fs
[ 1.780915] F2FS-fs (nvme0n1p3): Mounted with checkpoint version = 3d75f0e4
[ 1.821380] input: USB Keyboard System Control as /devices/pci0000:00/0000:00:14.0/usb1/1-4/1-4:1.1/0003:0C45:7603.0004/input/input8
[ 1.821482] input: USB Keyboard as /devices/pci0000:00/0000:00:14.0/usb1/1-4/1-4:1.1/0003:0C45:7603.0004/input/input10
[ 1.821722] hid-generic 0003:0C45:7603.0004: input,hiddev1,hidraw3: USB HID v1.11 Keyboard [USB Keyboard] on usb-0000:00:14.0-4/input1
[ 1.976154] udevd[503]: starting version 3.2.12
[ 1.985835] udevd[504]: starting eudev-3.2.12
[ 2.016882] udevd[533]: failed to execute '/lib/udev/mtp-probe' 'mtp-probe /sys/devices/pci0000:00/0000:00:14.0/usb1/1-3 1 2': No such file or directory
[ 2.018177] udevd[536]: failed to execute '/lib/udev/mtp-probe' 'mtp-probe /sys/devices/pci0000:00/0000:00:14.0/usb1/1-4 1 3': No such file or directory
[ 2.020103] udevd[522]: Error running install command 'modprobe -i nvidia-current ' for module nvidia: retcode 1
[ 2.026081] iTCO_vendor_support: vendor-support=0
[ 2.026089] EDAC ie31200: No ECC support
[ 2.026722] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 2.026996] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 2.027102] ee1004 0-0051: 512 byte EE1004-compliant SPD EEPROM, read-only
[ 2.027113] ee1004 0-0052: 512 byte EE1004-compliant SPD EEPROM, read-only
[ 2.027119] ee1004 0-0053: 512 byte EE1004-compliant SPD EEPROM, read-only
[ 2.027554] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[ 2.027556] cfg80211: failed to load regulatory.db
[ 2.062494] input: PC Speaker as /devices/platform/pcspkr/input/input11
[ 2.067152] iTCO_wdt iTCO_wdt: Found a Intel PCH TCO device (Version=6, TCOBASE=0x0400)
[ 2.067601] iTCO_wdt iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0)
[ 2.067757] spi-nor spi0.0: w25q128 (16384 Kbytes)
[ 2.071556] RAPL PMU: API unit is 2^-32 Joules, 3 fixed counters, 655360 ms ovfl timer
[ 2.071557] RAPL PMU: hw unit of domain pp0-core 2^-14 Joules
[ 2.071558] RAPL PMU: hw unit of domain package 2^-14 Joules
[ 2.071558] RAPL PMU: hw unit of domain dram 2^-14 Joules
[ 2.074196] Creating 1 MTD partitions on "0000:00:1f.5":
[ 2.074199] 0x000000000000-0x000001000000 : "BIOS"
[ 2.075725] Intel(R) Wireless WiFi driver for Linux
[ 2.075737] cryptd: max_cpu_qlen set to 1000
[ 2.082565] iwlwifi 0000:00:14.3: WRT: Overriding region id 0
[ 2.082567] iwlwifi 0000:00:14.3: WRT: Overriding region id 1
[ 2.082568] iwlwifi 0000:00:14.3: WRT: Overriding region id 2
[ 2.082569] iwlwifi 0000:00:14.3: WRT: Overriding region id 3
[ 2.082570] iwlwifi 0000:00:14.3: WRT: Overriding region id 4
[ 2.082570] iwlwifi 0000:00:14.3: WRT: Overriding region id 6
[ 2.082571] iwlwifi 0000:00:14.3: WRT: Overriding region id 8
[ 2.082572] iwlwifi 0000:00:14.3: WRT: Overriding region id 9
[ 2.082572] iwlwifi 0000:00:14.3: WRT: Overriding region id 10
[ 2.082573] iwlwifi 0000:00:14.3: WRT: Overriding region id 11
[ 2.082574] iwlwifi 0000:00:14.3: WRT: Overriding region id 15
[ 2.082575] iwlwifi 0000:00:14.3: WRT: Overriding region id 16
[ 2.082575] iwlwifi 0000:00:14.3: WRT: Overriding region id 18
[ 2.082576] iwlwifi 0000:00:14.3: WRT: Overriding region id 19
[ 2.082577] iwlwifi 0000:00:14.3: WRT: Overriding region id 20
[ 2.082577] iwlwifi 0000:00:14.3: WRT: Overriding region id 21
[ 2.082578] iwlwifi 0000:00:14.3: WRT: Overriding region id 28
[ 2.082803] iwlwifi 0000:00:14.3: loaded firmware version 46.ea3728ee.0 9000-pu-b0-jf-b0-46.ucode op_mode iwlmvm
[ 2.083154] AVX2 version of gcm_enc/dec engaged.
[ 2.083181] AES CTR mode by8 optimization enabled
[ 2.085047] Error: Driver 'pcspkr' is already registered, aborting...
[ 2.115683] snd_hda_intel 0000:01:00.1: Disabling MSI
[ 2.115687] snd_hda_intel 0000:01:00.1: Handle vga_switcheroo audio client
[ 2.119624] intel_tcc_cooling: Programmable TCC Offset detected
[ 2.122921] iwlwifi 0000:00:14.3: Detected Intel(R) Wireless-AC 9462, REV=0x312
[ 2.122965] thermal thermal_zone2: failed to read out thermal zone (-61)
[ 2.123002] intel_rapl_common: Found RAPL domain package
[ 2.123003] intel_rapl_common: Found RAPL domain core
[ 2.123004] intel_rapl_common: Found RAPL domain dram
[ 2.135134] snd_hda_codec_realtek hdaudioC0D0: ALCS1200A: SKU not ready 0x00000000
[ 2.135704] snd_hda_codec_realtek hdaudioC0D0: autoconfig for ALCS1200A: line_outs=1 (0x14/0x0/0x0/0x0/0x0) type:line
[ 2.135707] snd_hda_codec_realtek hdaudioC0D0: speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[ 2.135708] snd_hda_codec_realtek hdaudioC0D0: hp_outs=1 (0x1b/0x0/0x0/0x0/0x0)
[ 2.135709] snd_hda_codec_realtek hdaudioC0D0: mono: mono_out=0x0
[ 2.135710] snd_hda_codec_realtek hdaudioC0D0: inputs:
[ 2.135710] snd_hda_codec_realtek hdaudioC0D0: Front Mic=0x19
[ 2.135711] snd_hda_codec_realtek hdaudioC0D0: Rear Mic=0x18
[ 2.135712] snd_hda_codec_realtek hdaudioC0D0: Line=0x1a
[ 2.144649] input: HDA NVidia HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input12
[ 2.144698] input: HDA NVidia HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input13
[ 2.145270] input: HDA NVidia HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input14
[ 2.147335] input: HDA NVidia HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input15
[ 2.154841] input: HDA Intel PCH Front Mic as /devices/pci0000:00/0000:00:1f.3/sound/card0/input16
[ 2.154877] input: HDA Intel PCH Rear Mic as /devices/pci0000:00/0000:00:1f.3/sound/card0/input17
[ 2.154938] input: HDA Intel PCH Line as /devices/pci0000:00/0000:00:1f.3/sound/card0/input18
[ 2.155290] input: HDA Intel PCH Line Out as /devices/pci0000:00/0000:00:1f.3/sound/card0/input19
[ 2.155429] input: HDA Intel PCH Front Headphone as /devices/pci0000:00/0000:00:1f.3/sound/card0/input20
[ 2.178623] iwlwifi 0000:00:14.3: base HW address: 34:cf:f6:2f:6c:d7, OTP minor version: 0x4
[ 2.223644] ieee80211 phy0: Selected rate control algorithm 'iwl-mvm-rs'
[ 2.978461] Adding 2097148k swap on /dev/nvme0n1p2. Priority:-2 extents:1 across:2097148k SSDscFS
[ 3.385439] bpfilter: Loaded bpfilter_umh pid 1675
[ 3.385577] Started bpfilter
[ 3.588189] iwlwifi 0000:00:14.3: Conflict between TLV & NVM regarding enabling LAR (TLV = enabled NVM =disabled)
[ 3.702573] wlan0: authenticate with 94:6a:77:af:65:00
[ 3.704171] wlan0: send auth to 94:6a:77:af:65:00 (try 1/3)
[ 3.727175] wlan0: authenticated
[ 3.729293] wlan0: associate with 94:6a:77:af:65:00 (try 1/3)
[ 3.732697] wlan0: RX AssocResp from 94:6a:77:af:65:00 (capab=0x1511 status=0 aid=9)
[ 3.733799] wlan0: associated
[ 3.810143] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 3.815119] wlan0: Limiting TX power to 30 (30 - 0) dBm as advertised by 94:6a:77:af:65:00Edit#4: so it looks like with dmesg, the only error message I can see, and the only thing relevant simultaneously
is...: [ 1.946434] udevd[212]: Error running install command 'modprobe -i nvidia-current ' for module nvidia: retcode 1
which i get in dmesg after booting a good kernel that does get into my desktop environment, and the bad kernel/s that do not,
it looks like there is certainly some kind of weird bug going on here I wish I had more experience troubleshooting software on linux,
usually everything magically works so there's no need to probe all the subsystems, but also now that I am stripping linux down
for a root only gaming system it has caused me to discover perhaps endless little systems and subprocesses' that get in the way
of performance, so much so that I have started going through literally every single line in dmesg, in order to reverse/undo
every single default setting the kernel implements, stripping it down to literally nothing, just to get it completely out of the way
of my own operating system, and my own hardware.
There is no 'you' that can own anything. 'You' is a mental fiction and 'ownership' a delusion . . .
Esleep wrote: I'm building a system for high performance general/desktop/gaming usage
and am working towards it with Crowz->Devuan-Daedalus base
to get the best possible performance linux has to offer right now
Thank you for choosing and using Crowz! That is an impressive tutorial, let me know how it goes! Not a gamer at all, but try to have everything for my two grandsons! Thank you for utilizing your time to share the tutorial for others! ![]()
cheers
zephyr
CROWZ
simple hack to allow vlc to run as root to play background music while you run circles around people in online gaming, and make them look silly
Benchmarks or it didn't happen.
Generally the older kernels (i can't remember the versioning schemes, but basically the point upgrades stable distributions like devuan/debian use are actually faster
Okay then, why (technical explanation, not pseudo-jargon and hand-waving)... Also, benchmarks or it didn't happen.
after installing xfce, logging into it, the system is only using around 686-700 mb of ram, which is extremely impressive.
That's an extremely normal memory consumption for a fresh-boot minimal XFCE desktop.
This equates to faster system response timewhich is necessary for competitive gaming
Unless your system has some weird caching limitation (which AFAIK hasn't been a thing since L2 moved on-die in ~1999), you have severe memory fragmentation, or you are running into memory pressure, how much RAM the desktop uses is of no relevance to system latency.
Again, benchmarks please.
Using the root account for everything literally doubles my download speed, and system response time across the board. Everything is faster, more efficient, and super speedy.
this is essentially how using the root account is going to benefit all of the system operations compared to a regular user account. Everything will be twice as fast, including beating people up on online gaming
Sigh. Benchmarks or it didn't happen.
"Everything will be twice as fast" is an extraordinary claim, and extraordinary claims require extraordinary evidence.
This setup is literally like hyper-drive, file system operations are instantaneous and everything else is close behind instantaneous performance
Subjective performance. Where benchmarks?
it seemed to run startup programs out of sync with each other creating a lockup scenario, and failing to get to the desktop envrionment
Either you have found a bug (in which case you should report it, with all relevant technical information and logs), or this is just more hand-wavy pseudo-technical "explanations" for "I broke it because I don't know what I'm doing", like the last post... Guess which one I'm betting on. ![]()
Or perhaps it's asking to much for someone with "extensive experience, having tested and worked with basically 80% of all the linux distros" to exercise any scientific rigour whatsoever when doing performance tuning and writing "guides"?
Cogito ergo sum
I own my thoughts, and when I die i'm taking 'em with me!
Hold this beer a moment, just need to land my pig, then I can totally I can prove that one. ![]()
Well anything's possible I reckon.
"instantaneous performance" = Me, 18 years old. Poh-leese-man hollers "Hey you, long-hair, hold it right there"
Instantaneous world-class sprinter.
This is better than the "Joke Thread"... Hahahaha!
I'm pretty sure I get better looking when I drink tequila, I have no benchmarks but i'm fairly certain.
Wife however disagrees, but she says I do get better looking when she drinks tequila.
One thing however is FACT, my computers all run better without systemd.
This requires a creative approach.
I would try the "my wife looks better when I drink tequila" option ![]()
And Linux without a system actually works faster.
Two of my machines have two OSes, one with systemd, the other without. Both work without any problems, with the same DU they load approximately the same amount of memory, but the number of processes is different.
