#1 2023-09-07 13:14:23
Charon795
installing a theme from the official devuan package repository
Hi all! I am a new Linux Devuan user.
I would like to install a new theme for myself, but I do not know where to get them from. 1 person advised to look for themes in the official devuan package repository, but I don't know how to do it.
This person also advised to install downloaded themes in your home directory
And to create a directory, you need to register the $mkdir .themes command in the terminal.
I write this command but it gives me an error:
bash: .themes: command not found
what should I do?
#2 2023-09-07 16:01:59
Re: installing a theme from the official devuan package repository
what should I do?
Hello.
Please, check, maybe this dir (.themes) already exist.
Open a terminal and type
ls -a
If this dir does not exist, create this dir with command:
$ mkdir .themes
You can search for the gtk3 themes with simple command:
$ apt search gtk3 | less
You can scroll up or down with arrow keys.
Using this method, you will easily find the gtk 3 theme you need.
Here example of terminal command and output:
Sorting...
Full Text Search...
appmenu-gtk3-module/stable 0.7.6-2.1 amd64
  GtkMenuShell D-Bus exporter (GTK+3.0)
connman-gtk/stable 1.1.1+git20180626.b72c6ab-3 amd64
  fully-featured GUI for ConnMan with systray support
cyclograph-gtk3/stable 1.9.1-1.2 all
  route altimetry plotting application - GTK3 interface
darkblood-gtk-theme/stable 0-4 all
  dark GTK2/GTK3/Metacity theme
darkcold-gtk-theme/stable 5.0.0-3 all
darkfire-gtk-theme/stable 0-4 all
darkmint-gtk-theme/stable 2.0.0-3 all
fcitx-frontend-gtk3/stable 1:4.2.9.9-1 amd64
  Flexible Input Method Framework - GTK+ 3 IM Module frontend
fcitx5-frontend-gtk3/stable 5.0.21-1 amd64
  GTK3 IM Module for fcitx5
freeciv-client-extras/stable 3.0.6-1 amd64
  Civilization turn based strategy game (miscellaneous extras)
freeciv-client-gtk3/stable 3.0.6-1 amd64
  Civilization turn based strategy game (GTK 3 client)
freeciv-client-sdl/stable 3.0.6-1 amd64
  Civilization turn based strategy game (SDL client)
gambas3-gb-gtk3/stable 3.18.0-4 amd64
  Gambas GTK+3 component
gambas3-gb-gtk3-opengl/stable 3.18.0-4 amd64
  Gambas OpenGL component with GTK+3 toolkit
gambas3-gb-gtk3-wayland/stable 3.18.0-4 amd64
  Gambas GTK+3 Wayland component
gambas3-gb-gtk3-webview/stable 3.18.0-4 amd64
  Gambas GTK+3 Webview component
gambas3-gb-gtk3-x11/stable 3.18.0-4 amd64
  Gambas GTK+3 X11 component
gambas3-gb-gui/stable 3.18.0-4 amd64
  Gambas graphical toolkit selector
gcin/stable 2.9.0+dfsg1-2+b4 amd64
  GTK+ based input method for Chinese users
gcin-gtk3-immodule/stable 2.9.0+dfsg1-2+b4 amd64
  GTK3 input method module with gcin as backend
gcolor3/stable 2.4.0-2 amd64
  Simple GTK3 color selector and picker
geany/stable 1.38-1+b1 amd64
  fast and lightweight IDE
geany-common/stable 1.38-1 all
  fast and lightweight IDE -- common files
gir1.2-dbusmenu-gtk3-0.4/stable 18.10.20180917~bzr492+repack1-3 amd64
  typelib file for libdbusmenu-gtk3-4
For example, if I want to install
darkfire-gtk-theme
the following commands must be used:
sudo apt update
sudo apt install darkfire-gtk-theme
#3 2023-09-07 16:23:43
When you see an example command starting with a $ don't enter the $, just the rest of the command. It's usually the terminal prompt.
In the unlikely event you did need to enter the $ the poster would tell you explicitly.
#4 2023-09-07 16:26:48
boughtonp
what should I do?
Hello.
Nope, it's because they exactly copied what was written in the other thread $mkdir .themes
Since there is no variable "mkdir" it evaluated to empty string, and thus was removed, leaving ".themes" which Bash tried to execute as a command, and since there isn't such a command, it displayed "command not found".
ls -a
$ mkdir .themes
The command is mkdir .themes - no dollar - just like you didn't put a dollar for the ls -a command.
Yes, the dollar is the prompt - experienced users know that, but new users don't - so it should be explicitly pointed out, or not used - personally, I'll only include a prompt when displaying both input and output. When offering advice for a specific command to run, it's less confusing to not use it. (Especially when one forgets the space and doesn't spot it whilst proofreading. Or writes one command with it and one without.)
Charon795:
It's a good practice to always verify what a command does before you enter it. Putting "man $mkdir" into a search engine would have clarified that the correct command is "mkdir" and explained what it does. The best source for Devuan is Debian man pages //manpages.debian.org
A dollar at the start of a command is usually the shell prompt (and thus not intended to be typed), but elsewhere in a command it can be a shell variable, and those can significantly change what a command does.
Something else worth pointing out - when a file or directory name starts with a "." it is considered "hidden" and not always displayed. This is why the need for ls -a instead of just ls. If you use a graphical file manager, it will have an option to toggle hidden resources on/off, which you would want to do if managing this folder with such a tool.
Also, if you prefer to reduce the number of files/directories directly in your home, you might prefer to use .local/share/themes instead of .themes
3.1415P265E589T932E846R64338
#5 2023-09-12 15:45:34
Charon795
So, it turns out that there are only 4 topics in the official repository?
#6 2023-09-12 15:57:01
Be creative ! Try search
apt search theme | less
#7 2023-09-12 16:02:47
Charon795
That's a different conversation) thank you
Now I see a huge pile of unknown topics and.. All that remains is to understand how you can view each topic without installing it and without entering each one separately into Google?
ps: is it worth downloading themes from xfce-look.org?
I really liked the whitesur theme, but I didn’t see it in the official repository
#8 2023-09-12 16:11:47
Charon795 . . . Certain themes are available by default and you can switch them in Xfce from the "Settings - Appearance" options.
You can see the Devuan specific artwork in our git store:
https://git.devuan.org/devuan/documenta … t/graphics
There are also previews on the forum for the first 5 Devuan releases.
#9 2023-09-12 16:27:10
Charon795
In the settings-appearance I see only one theme and those that I installed. I don’t see any other topics that could be put on..
The link you sent me gives me a 404 error.
#10 2023-09-12 17:05:33
What DE or WM are you using? The default XFCE has all the past custom Devuan themes available
The link works just fine but the visible link is truncated so you cannot copy/paste it directly. Use the complete URL.
