#1 2023-09-07 07:10:44
Charon795
[SOLVED] Keyboard issue, theme installation
Hi all! I am a new devuan and linux user. i have some questions and also i am facing some problems
I need your help
1. Keyboard issue
I have a dell inspirion 7537 keyboard model. In the settings, I set the dell inspirion 6000/8000, but the keys are still confused for some reason. what to do?
2. I want to put a theme from the following site: https://www.xfce-look.org/p/1661959
Chose the Colloroid theme. The question is how to install it instead of the standard one?
#2 2023-09-07 08:14:02
Re: [SOLVED] Keyboard issue, theme installation
Welcome to Devuan!
You can either put it into /home/[youuser].themes/ or in /usr/share/themes. You will need to put it into /usr to have the theme work on synaptic etc.
#3 2023-09-07 08:26:23
Charon795
golinux wrote:
Welcome to Devuan!
I tried to extract the folder with Colloroid to the path usr/shame/theme/ but I get an error saying that I do not have enough rights to extract to this directory
#4 2023-09-07 09:05:28
PedroReina
You have to do it as the user named "root".
#5 2023-09-07 09:13:53
Charon795
Logically. How to do it?
#6 2023-09-07 11:25:31
Charon795
The issue with the installation of the theme has been resolved. The keyboard issue still stands.
#7 2023-09-07 11:29:40
Hello.
You shouldn't play with the root directory. Especially with files downloaded from unknown sources. Considering you have no experience with Unix systems, I would advise you to install the theme you downloaded into your user home directory.
I would advise to make everything much simpler
Create dir
$mkdir .themes
And put extracted files to that folder.
P.S.
I also suggest you to search for themes in the official Devuan package repository. It really has a lot of good themes, which, by the way, are properly tested and compatible with the current version of Devuan.
#8 2023-09-07 11:46:15
Charon795
stopAI wrote:
Hello.
Create dir
$mkdir .themes
P.S.
Thank you for your reply.
And sorry for the dumb question. Do I just need to type this in the terminal? Nothing else needs to be added to create a directory?
I will only be glad if you send a link where you can download themes
#9 2023-09-07 11:56:34
Next time one problem per post please, makes answering and follow up much easier.
To the keyboard issue: I never cared for any keyboard model. Locale and keyboard layout are usually defined during setup, im my case Germany/German. Maybe you take a read into the Ubuntu wiki, or search the web a bit for the keywords "linux configure locale" and "linux configure keyboard".
What I haven't seen is a exact description of your problem, so a specific answer isn't possible.
My locale shows:
$ locale
LANG=de_DE.UTF-8
LANGUAGE=
LC_CTYPE="de_DE.UTF-8"
LC_NUMERIC="de_DE.UTF-8"
LC_TIME="de_DE.UTF-8"
LC_COLLATE="de_DE.UTF-8"
LC_MONETARY="de_DE.UTF-8"
LC_MESSAGES="de_DE.UTF-8"
LC_PAPER="de_DE.UTF-8"
LC_NAME="de_DE.UTF-8"
LC_ADDRESS="de_DE.UTF-8"
LC_TELEPHONE="de_DE.UTF-8"
LC_MEASUREMENT="de_DE.UTF-8"
LC_IDENTIFICATION="de_DE.UTF-8"
LC_ALL=
In /etc/default/keyboard I find:
$ cat /etc/default/keyboard
# KEYBOARD CONFIGURATION FILE
# Consult the keyboard(5) manual page.
XKBMODEL="pc105"
XKBLAYOUT="de"
XKBVARIANT=""
XKBOPTIONS=""
BACKSPACE="guess"
That works for me.
Maybe you tell as a bit more about the problem? What is your locale? Which keyboard settings are used? What does not work?
#10 2023-09-07 12:04:19
Charon795
Sorry. I'll keep it in mind next time.
When installing the system, I specified the usual 105-key model and now I have mixed up characters on numbers like a question or an exclamation mark
As I said, I changed the keyboard model to my own, but still, for some reason, nothing changes. As instead of an exclamation mark, she wrote the letter n with a round, and continues to write it. and I literally don't know what to do with it
#11 2023-09-07 12:14:15
Show the printout of:
$ locale
and tell us which keyboard layout do you have? Norwegian, Swedisch, Spanish .... ?
#12 2023-09-07 12:28:22
Charon795
$ locale
I can't copy information from the terminal. I press ctrl+c but nothing
I use Russian and English layout
#13 2023-09-07 12:42:01
alexkemp
Please stop full-post quoting almost *every* reply, that is just childish nonsense. If you wish to indicate what you are replying to, then edit the text down to the minimum. These forums are noisy enough as they are without scores & scores of full-text quotes.
If you are using the "xfce4-terminal" (see menu:Help | About) then the command to copy highlighted-text is shown at menu:Edit | Copy (key-command is Shift+Ctrl+C).
#14 2023-09-07 16:08:34
Please check this:
https://dev1galaxy.org/viewtopic.php?id=5969
I really don't recommend you do that, ie. download themes from unknown sources. For starters, before you gain experience, install themes from the official Devuan  repository.
#15 2023-09-11 08:44:55
Charon795
Please check this:
So can you tell me HOW can I install themes from the official repository??
#16 2023-09-11 11:47:17
Did you understand what I wrote to you? Did you click the link and read what it says? I don't really understand what you don't understand...
P.S.
Here is the link again that describes how to install gtk themes.
