#1 2023-08-29 22:01:23
torquebar
Chimaera sound/music issues
I'm using chimaera (IV) and update it regularly, have not many problems with it so I don't see why I would upgrade; anyway, isn't Devuan a rolling release?
The current problem I *do* have is with sound or rather music apps; namely, jack_capture and qjackctl. The context is the group of apps I use to create my own backing tracks for guitar, not all each time but usually started in this order: qjackctl, qsynth, Yoshimi, Hydrogen, Rosegarden.
jack_capture is driving me nuts (and not only when using Devuan), here's the error message that no one seems to know how to put out of its freakin' misery:
Cannot lock down 107341338 byte memory area (Cannot allocate memory)
>>> Warning. Could not set higher priority for a SCHED_OTHER process using setpriority().
Cannot use real-time scheduling (RR/5) (1: Operation not permitted)
JackClient::AcquireSelfRealTime error
>>> Recording to "jack_capture_02.wav". Press <Return> or <Ctrl-C> to stop.
>>> Please wait while writing all data to disk. (shouldn't take long)
00:|        |
01:|        |
Buffer: 4.03s./4.03s    Time: 0.07m.   DHP: [ ]  Overruns: 0  Xruns: 0
The other one is qjackctl which doesn't recognize an already started
Yoshimi synthesizer which thus doesn't show in the qjackctl 'connections'
dialog. Yoshimi in this case is the rather outdated v-1.7.4 but I have
no idea if this is a factor.
Any help would be appreciated, particulartly with jack_capture.
Tuesdays are Devuan days: GNU/Linux 4 (chimaera), BIOS-boot, DM=Unknown,
Kernel=5.10.0-25-amd64 on x86_64, DM=Unknown, DE=XFCE, ST=x11,grub2, GPT,
https://imgur.com/x2A9zHw.png      https://i.imgur.com/RsbswMP.png
Who, has loved us more?
#2 2023-08-29 22:15:40
Re: Chimaera sound/music issues
torquebar wrote:
. . . anyway, isn't Devuan a rolling release?
No! At least as to what I understand a rolling release to be. It is a "stable" release. "testing"is a rolling release until it becomes the next "stable" release. See:
https://www.devuan.org/os/releases
#3 2023-08-29 22:28:13
torquebar
That HAS to be the fastest response I have ever received in any forum, group or mailing list!
#4 2023-08-30 07:39:41
Hi, I think jack wants realtime access from the kernel.
uname -a will show your current kernel version, yours should have rt in it's name.
(edit) terrible typos
#5 2023-08-30 11:39:34
torquebar
Thanks, I'm on slackware right now:
# uname -a
Linux darkstar.example.net 5.15.117 #1 SMP PREEMPT Thu Jun 22 15:39:49 CDT 2023 x86_64 AMD FX(tm)-8150 Eight-Core Processor AuthenticAMD GNU/Linux
...similar problems with jack_capture on several distros. Jack itself seems to work OK, but my technical polish is the equivalent of about grit-20 sandpaper. I thought jack was needed TO provide virtual low latency so why use it if one has a real low-latency kernel?
#6 2023-08-30 12:04:52
jack needs a real-time-kernel to be able to schedule the audio-related processes accordingly.
The error message (#1) could also mean "your user is not allowed to do real time scheduling", even if the kernel is capable.
#7 2023-08-30 17:14:47
torquebar
I'm on Suse-Leap right now but you just solved my problem, or at least provided a workaround.
This distro does run a RT kernel (I think)
# uname -a
Linux localhost.localdomain 5.14.21-150500.55.19-default #1 SMP PREEMPT_DYNAMIC Tue Aug 8 22:15:01 UTC 2023 (9908c29) x86_64 x86_64 x86_64 GNU/Linux
When I read 'permissions' I decided to try it as root, it didn't work either
But then I logged back as userr, retried ...and BINGO.
Beats the rcap out me lieutenant, but nice work  :-)
#8 2023-08-30 18:00:10
# uname -a
No, that not a RT kernel, that would look like this:
Linux localhost.localdomain 5.14.21-150500.55.19-default #1 SMP PREEMPT_DYNAMIC RT Tue Aug 8 22:15:01 UTC 2023 (9908c29) x86_64 x86_64 x86_64 GNU/Linux
#9 2023-08-30 19:33:47
torquebar
thanks
#10 2023-08-30 22:33:07
For what it's worth, Pre-empt is not RealTime, but close.
I hope it keeps working for you.
See how you go when playing back 14 tracks while recording overdubs in real time.
Minimal xruns.
