#1 2023-08-25 10:29:36
vendefoulwolf
New Vendefoul Wolf Re-spin | Devuan 5
Hello friends,
I want to let you know about my Re-spin. It's just a customization of Devuan 5, with custom xfce desktop. Neofetch also customised and with a tool to remove win partition passwords, using it in live mode.
The purpose is to create a rescue usb-live to be able to repair access to win. Besides being able to be used and installed on the pc.
Also the main intention is that everything is in Spanish when booting the usb, there are two options English (default) and Spanish (in other languages). In this way, the idea is to expand the use of Devuan in the Hispanic world.
I also have the calamares installer, but at the moment I can't get it to start and run. I'm still working on it. But having calamares, this expansion is possible.
The ISO is currently available with the refracta installer, which is also very solid and will always be available, but also calamares will be available in the near future.
Thanks for your support, and help to spread this re-spin, which is nothing more than a simple customisation of Devuan that I hope to like if it expands in thousands of downloads and installations to make daedalus a dominant distro in the world.
Best regards.
Here are some wallpapers:
Website, download: https://vendefoulwolf.wixsite.com/descarga/
#2 2023-08-26 14:00:07
rickNS
Re: New Vendefoul Wolf Re-spin | Devuan 5
That is some pretty cool artwork on the wolf, I'm guessing you did that yourself?
I just joined to same day as you.
#3 2023-08-26 16:28:35
Welcome to Devuan! While I appreciate your contribution, I am puzzled by the title.  I have no idea how to pronounce it, can't remember how to spell it so not in my memory bank and "Vende" as in the French verb "Vendre" which means "to sell" has me confused as to your intentions. Please enlighten me. Thanks!
#4 2023-08-26 22:13:35
vendefoulwolf
The intentions are to spread and propagate Devuan, the name occurred to me while watching a movie about wolves... just like that.
#5 2023-08-26 22:14:43
vendefoulwolf
Created by an AI
#6 2023-08-26 22:24:18
Did the AI write that non-answer also? LOL! I surrender . . .
#7 2023-08-27 05:52:00
charliebrownau
Gday
Thanks for your hard work
BTW
Whats the default root password
I clicked on Install/Intatar
toor
Didnt work for the password
PS
Check out
* Sourceforge for free linux iso hosting
    https://sourceforge.net/
* sourcehut for free linux project hosting
    https://sourcehut.org/
* ZeroSSL for a free SSL cert
   https://zerossl.com/
* Vultr VPS for a free teir VPS
  https://blogiestools.com/vultr-free-plan/
  https://news.ycombinator.com/item?id=35183971
  https://lowendbox.com/blog/the-vultr-fr … e-details/
* Otherwise Racknerd have an VPS cheap package
  - USD$23 per YEAR - https://www.racknerd.com/kvm-vps
Also for crowd funding
Subscribe instead of ((( Pateron)))
LibrePay
Entropy
Cointr.ee
Good Luck
#8 2023-08-27 07:46:21
vendefoulwolf
charliebrownau wrote:
Gday
BTW
toor
PS
Check out
LibrePay
Entropy
Cointr.ee
Good Luck
Password user: vendefoulwolf
Password root: 1234
#9 2023-09-12 10:47:58
vendefoulwolf
Updated the ISO so that in the future whoever installs the VWolf23 re-spin can change init easily with a small script from the desktop. In addition, programs have been added and the xfce menu has been modified to make it more visual and easier to see, I leave you screenshots:
#10 2023-09-12 10:50:27
vendefoulwolf
new password live:
user: devuan
password: Vwolf23
root: root
password: toor
#11 2023-10-06 21:03:33
vendefoulwolf
Added squid for easy installation and maximum spread of Respin and therefore Devuan 5.
#12 2023-10-07 01:24:17
alexkemp
That *is* an awesome graphic!
#13 2023-10-09 20:45:01
vendefoulwolf
The effective Calamares test
#14 2023-10-14 15:40:48
vendefoulwolf
A new 32-bit version of Vendefoul Wolf 23 with lxqt flavour is available for very low-resource machines, also installs with Calamares.
photo-2023-10-14-17-31-30.jpgphoto-2023-10-14-17-38-22.jpgphoto-2023-10-14-10-15-04.jpgphoto-2023-10-14-12-54-43.jpgphoto-2023-10-14-17-38-06.jpg
As can be seen in the screenshot with libreoffice open, its consumption is only 444mb. It can be downloaded from the Re-spin website.
#15 2023-10-22 17:22:20
yemuyin
Genial tongue Estoy en lo mismo con antiX , tendré que probar con Devuan
#16 2023-10-23 08:32:20
vendefoulwolf
Devuan esta muy bien, con la instalación con Calamares no tendrás ningún problema. Además luego una vez instalada la versión Vendefoul Wolf, que va con sysvinit por defecto podrás cambiar a Runit u openRC sin mayores problemas que ejecuntando el icono que hay en el escritorio (usuario del respin) y será aplicado a todo el sistema incluyendo tu usuario creado en la instalación. Si quieres tenemos grupo de telegram para ayudarte en los problemas que puedan surgirte así cocmo hay contenido, fondos de pantalla, etc... Te esperamos en https://t.me/vendefoulwolf y tambien tenemos un wiki para consultar lo que más se puede necesitar del respin https://vendefoulwolf.wordpress.com/indice/
#17 2023-10-23 12:16:26
yemuyin
Gracias, tengo una instalación de devuan con runit que hice desde el net-install, me refería que estaba intentando hacer un respin de antiX, este con sysVinit, pero me queda por aprender tongue
Gracias tb por los enlaces
#18 2023-10-29 21:45:33
vendefoulwolf
I leave you the address of the YouTube channel where I explain the secrets of respin
https://www.youtube.com/@vendefoulwolflinux
#19 2023-11-25 22:45:15
vendefoulwolf
Integrated into the system through a .deb package for all Vendefoul Wolf 64 bit users with a menu that brings together all the scripts created with utilities.
Integrado en el sistema mediante paquete .deb para todos los usuarios de Vendefoul Wolf 64 bit de un menú que aglutina todos los scripts creado con utilidades.
Demo video:
https://video.wixstatic.com/video/9700f … 4/file.mp4
