#1 2023-08-16 23:18:41
semil
Daedalus, seatd, can’t have multiple X sessions
I startx on one vt (pretty minimal, starts up a window manager).
I try to startx again on another vt — same user or different user — and it fails. seatd says "Could not add client: seat is VT-bound and has an active client".
Since I don’t know whether being VT-bound is good or bad, I found SEATD_VTBOUND=0 and tried that on the seatd invocation. But seatd is still unhappy because it still sees an active client regardless.
I presume switching away from a vt is supposed to make an X session become *not* active somehow.
#2 2023-08-17 15:27:30
Re: Daedalus, seatd, can’t have multiple X sessions
But you did something like startx -- :1, right?
#3 2023-08-17 19:35:34
semil
I have always been using a plain startx in each, but using startx -- :1 for the second one fails in the same way.
#4 2023-08-19 14:43:47
semil
Would it be more appropriate to have this topic moved to a lower-level subforum where more of the right people might see it, since, strictly speaking, this subforum suggests being about things running on X and not about getting X to run.
If this forum is even capable of moving topics, that is.
#5 2023-08-19 15:08:58
I'm not sure there is a bug report, but that particular issue of having multiple Xorg (in different VT) with seatd, is currently being worked on, and I believe an update is coming fairly soon.
#6 2023-08-19 15:47:23
Yes. If appropriate.
#7 2023-08-19 23:30:19
semil
I’m glad to know that!
I don’t see a bug report, but I’m not experienced with the bug tracker.
#8 2023-08-20 15:27:01
semil
Given that I won’t be using that Daedalus system regularly until this has been fixed, what is the most efficient way to check periodically from somewhere else whether the fix has happened yet?
#9 2023-08-21 15:39:53
semil
One possibility might be to look at
https://pkginfo.devuan.org/cgi-bin/policy-query.html?c=package&q=xorg
https://pkginfo.devuan.org/cgi-bin/policy-query.html?c=package&q=*seat*
each day. I would have to recognize when version numbers had changed.
#10 2023-08-22 19:11:47
semil
Another possibility is probably within the infinitude of git.devuan.org. Maybe something will happen on some branch in https://git.devuan.org/devuan/xorg-server/branches as an indication of code getting into Daedalus. Or maybe not. That might be not the right region of git at all.
#11 2023-08-22 20:29:52
I remember being able to have more than one GUI running on different tty's... but that went away and couldn't be done the same way.
Hoping for innovation.
#12 2023-08-22 23:34:50
Yes, https://git.devuan.org/devuan/xorg-server is where it happens. The review process of a fix is in full swing so you may hold your breath. well, maybe not... breath easy, but expect there's something coming soon.
